SLK 55 AMG 2013 Sport mode - Mercedes Benz SLK Forum
 35Likes
Old 03-13-2013
Vehicle: SLK 55 AMG 2013
hi guys
just got my SLK 55 AMG 2013 2 weeks ago, and i love the roar of the engine especially in the sport mode, was wondering if the setting can be changed so you can start the car directly in the sport mode or it is always that you have to start in the comfort mode then shift it to the sport mode
thanks
Docmarwan is offline
Old 03-20-2013
Vehicle: '13 SLK55, '12 CLS63
Always starts in C mode. Some tuners, Renntech comes to mind, have been able to turn off default Eco mode. They may be able to make it start in S. Worth an ask.
Maranell0 likes this.
JumpinJim is offline
Old 12-05-2017
trkcorp's Avatar
Vehicle: 2014 SLK55 AMG Mars red, designo platinum white leather, Black basswood trim, loaded!
Other Toys: 1998 Jaguar XJR
I haven't an answer but I would like my car to "remember" the mode I set... I also set my car to sport when I start it and drive it that way until it is warm. My reasoning? Well, I want even wear on the cylinders and it seems like a good idea, it will make it warm up faster, it won't cut off on a stop anyhow until it's at running temp anyhow. I believe and those are my reasons. Someone tell me if I am just full of "it".
55russamg likes this.
trkcorp is offline
Old 12-05-2017
LeonardoDaBenz's Avatar
Quoted: 993 Post(s)
Nope.
Asked many times and always the same answer
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Old 12-05-2017
Quoted: 6358 Post(s)
Get a r171. It remembers
dbgrn, 55russamg, Avel Du and 1 others like this.
Old 03-01-2018
Vehicle: SLK 55 R172 2013
Some workshops/coding specialists here in Germany are able to set "last Mode" in 7G-Tronic and "last Mode" in Eco Start/Stop.
Avel Du and Eeyorewolf like this.
sassa is offline
Old 03-01-2018
Russ1's Avatar
Vehicle: SLK55 AMG R172 2013 and SLK 280 R171 2005
Other Toys: Previous Toys; Southern Roadcraft Cobra 1973. Honda VFR 800, Suzuki GSX750
Quoted: 11 Post(s)
Talking
Do you have any links to said workshops??
Russ
Russ1 is offline
Old 03-01-2018
Moderator/RoTMorganiser
Quoted: 2143 Post(s)
If it's DAS/STAR settings maybe these folks can chip in (although the 172 is still being learnt, I think):
@i860 @nimbusgb @Seanhump @mchild @JudgeMing @Zenman63 @Sneaky Pete
DAS/STAR should mean you can get it done in the Midlands, I'd have thought.
Russ1 likes this.
Old 03-01-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 860 Post(s)
I believe it can be done with Vediamo.
Russ1 and Avel Du like this.
i860 is online now
Old 03-01-2018
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
I've not hooked up to a 172 yet .. would need the steps listed out if anyone has them ..?
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
Old 03-01-2018
Vehicle: 2013 SLK 55 amg (all-black)
Other Toys: 2006 E280 CDI (tanzanite blue) ecu optimized.
Quoted: 29 Post(s)
Most likely pressing the C/S/M button creates a canbus message.
This'd be quite a good candidate for a canbus device, such as smarttop, to listen to and recreate on power-on.
They have something similar to this on R231 model smarttop.
I'll see if a feature request ticket to them (mods4cars) could be opened on this. Unfortunately, I don't have a canbus scanner, so I can't provide them with the exact messages.
os62 is offline
Old 03-01-2018
Mensra's Avatar
Quoted: 329 Post(s)
I would like that firmware upgrade for my Smarttop! They can put me down as a beta tester.
Mensra is online now
Old 03-02-2018
Quoted: 29 Post(s)
Originally Posted by trkcorp View Post
I want even wear on the cylinders and it seems like a good idea... Someone tell me if I am just full of "it".
Wear is accelerated by high loads and undersquareness of engine, resulting in block bore turning oval on thrust side.
Cylinder cutoff nicely turns off in any load above raw-egg-between-pedal-and-boot, and M152 has 98mm against 90.5mm bore/stroke, thus being oversquare.
Might not see much of uneven wear in practice, although, it would've made me happier, if resting cylinders would alternate, which they don't.
os62 is offline
Old 03-03-2018
trkcorp's Avatar
" it would've made me happier, if resting cylinders would alternate" - Me too...
trkcorp is offline
Old 03-03-2018
Col
Col's Avatar
Quoted: 709 Post(s)
I don’t believe it makes any difference to wear in the deactivated cylinders due to the fact that the pistons being attached to the crankshaft still reciprocate! The deactivation just cuts fuel injection and spark to those that are switched off.
That said I run mine on 8 until warm also. My reasoning for this being that the engine will get up to temp quicker and it will promote a more uniform heating of the cylinder head so distortion due to temperature differences should be minimised.
I'm not mean... but I am 'roofless' at every opportunity!
- SmartTOP
- Blacked Out Front Grille
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
- Vath X-Pipe and Modified Rear Silencers
- Ispiri ISR6 Alloys Wheels
Col is offline
Old 03-03-2018
CHELZEE's Avatar
Vehicle: 2012 SLK 55 AMG
Quoted: 130 Post(s)
Cool
Which is more than I can say for a certain moderator ........just saying
Mensra and Col like this.
CHELZEE is offline
Old 03-05-2018
i860's Avatar
Quoted: 860 Post(s)
At the moment you have C-S-M when starting the car, in vediamo under vgs you can change to cycle to S-C-M, assuming you have the right cbf, reset tcu, swich off and on the car.
Col likes this.
i860 is online now
Old 03-05-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 08Edge SE AWD, 08Ridgeline XL 4x4
Quoted: 99 Post(s)
Excellent thinking Mr. Col.
Eeyorewolf is offline
Old 03-05-2018
Quoted: 99 Post(s)
Question
I don't believe my 2005 55 AMG has this issue but if it did I would be looking for a way to defeat it permanently. The reason for MDS is fuel economy in an attempt to meet CAFE standards. I don't know if Mercedes got this idea from Chrysler with the Hemi engine or if it was the other way around but it's a horrible idea, if people who bought a performance car wanted a four cylinder they would buy a Focus ST at least that car has a turbo, @Col brought up an excellent point in regard to uneven heating of the cylinder heads but I don't think uneven wear would come into play as much as issues with the dead cylinders tending to develop carbon buildup due to running cooler than the live cylinders. The best way to save fuel is to keep your foot out of the skinny pedal on the right (in US anyway). I don't really see how cutting half your potential horsepower saves you anything since it takes the same amount of energy to move the mass of your vehicle up inclines, against wind resistance and always gravity no matter what, it's not like when you shut down four cylinders the other four somehow magically become more powerful, in fact they just have to work twice as hard to make up for the slackers and even drag them along. What % of fuel is this design supposed to save anyway does anyone know? I read that for the average driver MDS is active only 5 to 8% of the time, it seems an awful lot of trouble and potential issues for such a small fraction of time the system would be active. I searched and I can't find anything on actual results for fuel savings on cars with MDS. I drove my 2005 to work and averaged 24.3 MPG, what are the vehicles with MDS averaging I wonder?
Old 03-05-2018
Mensra's Avatar
Quoted: 329 Post(s)
I have gotten as high as 33MPG (American) driving 60 mph exactly on the highway.
Eeyorewolf likes this.
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > Performance MODS for the R172
SLK History SLKman General Discussion 42 05-19-2015 04:12 AM
SLK 171 350 by Tzitzos tzitzos General Modifications R171 86 11-02-2012 06:34 PM
Change for MY2011 Twisted General Discussion 2 05-12-2010 02:29 PM
MB Official Release of 2009 SLK Cold Shot SLK R171 General Discussion 208 10-13-2008 02:35 PM
