BBK brake for R172 - Mercedes Benz SLK Forum
  • 1 Post By wja96
#1 Old 12-11-2012
BBK brake for R172
hi I am looking for BBK like brembo for my R172 but no one has it in the market.
anyone know if our brake are they the same as the w204 2012 or the 2012 e class so I would be able to get the kit from their car model.
phuture is offline
#2 Old 12-11-2012
Quoted: 6359 Post(s)
phuture,
In addition, if you haven’t, please post your question in the appropriate discussion forum for a quicker response. Be patient and a knowledgeable member will address your question.
New members should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
#3 Old 01-13-2016
Vehicle: Alpine White SLK200 R172 2012-Present
Quoted: 13 Post(s)
+1 on this, would love to get more info of BBK for SLK
superbogel is offline
#4 Old 01-13-2016
FYI, This thread is 4 years old and op has not been back since posting
#5 Old 01-17-2016
Vehicle: Audi TTRS MY2017
Other Toys: Whyte Prst-1, MY2017 Audi A6 allroad Competition, 1/50th Twin Squirrel, 2006 Fabia vRS Hybrid
Quoted: 619 Post(s)
The easiest way for you to get a big brake kit on your car is to fit the bigger discs and calipers from an SLK55.
If you want aftermarket Brembo sell a 355mm 4 piston kit for the front and 324mm 4 piston kit for the rear in the GT range and AP Racing offer 4 and 6 piston kits in their Formula range.
Demon Tweeks have both in their current catalogue. They are not cheap though. The AP Racing setup is £3500 front and rear. Ouch!
And having been through the youthful exuberance of fitting big brakes in the past I now genuinely query their usefulness. They add weight, which is bad. And all most of them do is let you lock up the wheels quicker which triggers the ABS which knocks them off. So what was the point? Fade resistance? Possibly. But when did you last repeatedly brake so hard you had brake fade? I can't remember a time that happened to me on the road. If you track your car then fine, but I don't so big brakes are a bit pointless for me. They look great behind an open alloy wheel though
bastivock likes this.
wja96 is offline
#6 Old 01-18-2016
Quoted: 13 Post(s)
for price of £3500 is not worth it for me, I probably going to look for 2nd used amg disk brakes for the looks, do you know where I can look for that kind of parts?
thank you!
#7 Old 01-18-2016
Quoted: 619 Post(s)
Well, if you start out with a set of 360mm discs/rotors off the SLK 55
R172 SLK 55 AMG '12-on Vented/Drilled Front Brake Disc - Mintex 360mm - that's £115
You'll then need a set of pads
Mercedes-Benz SLK (R172) SLK55 AMG (5.5) Brake Pads & Shoes from EBC is another £60
The big difficulty is locating the calipers. You may also need other parts eg. Carriers (but it doesn't appear so from the diagrams).
You might try PMing Judge Ming as he's VERY good at this sort of thing.
wja96 is offline
#8 Old 01-18-2016
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
Brembo make front brake kits for the 172, they are not widely advertised but are made up from kits for other MB models.
If you propose to make up a set, do make sure that the calipers and discs are a correct match.
If you buy 4, 6 or 8 piston calipers, they are complete, ie they do not need carriers. Carriers are only for single piston calipers.
The only option to match up the rears with larger discs is the TRW single piston caliper and disc from the M Class. No one makes a multi piston caliper for the 172 rears (D Brakes claim they have a 4 piston caliper, but requires their proprietary handbrake servo that is not compatible with the SLK electronics, so be careful)
Hal Adams is offline
#9 Old 02-14-2016
Quoted: 13 Post(s)
where can I find the rotor/caliper if the diskbrake for SLK55 is available, does it fit right in to our slk200? as I understand the caliper and rotor is different..
please enlighten on this
#10 Old 02-15-2016
Quoted: 271 Post(s)
What exactly do you want to do?
Go to your local MB dealer and s/he will give you the part numbers for the bits you need - ask them to look up the SL55 parts list. For the rears, you only need the SL55 disc, calipers and pads, likewise for the fronts. Do not try to use the oem SL55 disc with another caliper - they have to be matched. They bolt onto the 200.
#11 Old 02-15-2016
Quoted: 271 Post(s)
Sorry - it is the SLK55 parts you should look at, not the SL - and make sure it is the R172. Version. The. Earlier rears are different.
#12 Old 02-16-2016
Quoted: 13 Post(s)
my local dealers are not responding very well, can I have a list of parts please so I can look at the part numbers and calculate all I need.
thank you Adams!
#13 Old 02-16-2016
Quoted: 13 Post(s)
here is the list I found:
is this enough for me to just plug and play with out any modifications Adams?
Mercedes Disc Brake Caliper Front Right (SLK55 AMG) - Genuine Mercedes 1724210898 $529.99 $529.99 ×
Mercedes Disc Brake Rotor Front - Genuine Mercedes 221421181207 $159.99 $159.99 ×
Mercedes Brake Pad Front (SLK55 AMG S550) - Textar 2521901 $119.49 $119.49 ×
Mercedes Disc Brake Caliper Rear Left (SLK55 AMG) - Genuine Mercedes 1724230381 $257.99 $257.99 ×
Mercedes Disc Brake Pad Rear (SLK55 AMG) - Genuine Mercedes 0064206820 $153.99 $307.98 ×
Mercedes Disc Brake Caliper Front Left (SLK55 AMG) - Genuine Mercedes 1724210798 $529.99 $529.99 ×
Mercedes Disc Brake Caliper Rear Right (SLK55 AMG) - Genuine Mercedes 1724230481 $257.99 $257.99 ×
Mercedes Disc Brake Rotor Rear (SLK55 AMG) - Genuine Mercedes 1724230112 $122.99 $122.99 ×
#14 Old 02-16-2016
Quoted: 271 Post(s)
I was given the part numbers by another member, Judgeming, but sadly I have lost his mail to check your numbers, but from my invoices, the rear discs and caliper numbers are correct, however, you will need two carriers for the calipers added: p/n 172 423 01 06. With these you are ready to go. Pluig and play is a loose way to describe it. Do you know the procedure to change the rear pads?
I recognise the number for the front disc - this is used a lot across the MB range. However, check out what the calipers look like. There are two types, and I have a feeling that the number you have, as it starts with 172, might be the standard single piston TRW type from the ML. The four pot Brembo type [I think] starts with a 221 if I remember correctly. Have another word with your dealer and ask to see the spec drawings for the SLK55 fronts.
#15 Old 02-17-2016
Quoted: 13 Post(s)
sure thing, let me check on it, the one installing will be a workshop that is own by my friend. so to say if I bought single piston instead of the 4pot will that be okay or not okay?
#16 Old 02-17-2016
Quoted: 13 Post(s)
are you also saying that I need to buy a different calipers and not this list?
#17 Old 02-17-2016
Quoted: 271 Post(s)
No. I am saying that there are two types - I do not know which one the part number you have refers to. I think it is the TRW type, but you need to see the illustration with those part numbers to determine which it is.
#18 Old 02-17-2016
Quoted: 13 Post(s)
sorry mate, bad english, I did not follow on this one
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > Performance MODS for the R172
SLK 200 UK Rear Brake Strip and Rebuild johnnyg SLK R171 Class DIY 3 04-17-2017 03:37 AM
