2nd cat delete on 200k - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By Terminal
  • 1 Post By Padgett
  • 1 Post By i860
#1 Old 05-22-2018
Vehicle: 2008 SLK 200kompressor Obsidian Black
Quoted: 17 Post(s)
did someone try this on 200k (I saw you did on 350 or 55amg)? Any performance gains (I plan to do do puley+remap too)?
I deleted 2nd cat few days ago (swap with straight pipe for now). I like the sound now, it is little louder between 3000-4500rpm. I don't know if it is better to put sport cat (100cell or 200cell) or some resonator now instead of just straight pipe?
Does this harm the engine or any other parts on the long run?
Will I pass next year CO emission test without 2nd cat, does primary cat do enough ''job''?
nikon93 is offline
#2 Old 05-22-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Could someone please explain what the purpose of the second catalyst is (or is it a CC ?). The secondary O2 sensor is between the two catalysts and on three cars I have never seen the second vary more than one point off center. If the first stops working it set a code. They do not check the second one. So what is it for please ? Would not surprise me if just a resonator.
Padgett is offline
#3 Old 05-22-2018
mike350's Avatar
Vehicle: SLK350 r171, 2007, factory fitted sports/AMG body kit & suspension, Airscarf, S200 Android head unit
Other Toys: Triumph Spitfire/GT6, Lexus IS250
Quoted: 205 Post(s)
My understanding is as follows (on unmodified cars) - please feel free to correct this if I'm wrong!
@i860 corrected me and so I've updated this post with the upstream o2 sensors and marked the resonators as secondary Cats/resonators as he's confirmed that these are used to help warm up the main Cat from cold.
V8 (AMG)
Manifold - o2 sensor- Cat - o2 sensor - secondary Cat - Xpipe* - rear boxes
*I think the 172's have a Xpipe as std where the 171 don't.
V6 (350,280)
Manifold - o2 sensor - Cat - o2 sensor - secondary Cat/resonator - Xpipe - rear boxes
Not sure if this is the same on the 170
4cyl (200) supercharged
Manifold - o2 sensor - Cat - o2 sensor - secondary Cat/resonator - Y pipe - rear boxes .
Now, I think the 'resonator' should really be called an 'anti- resonator' as, since I've had mine removed, I get a much better exhaust note but the pipes do resonate (or rasp) a little when you put your foot down hard at low revs.
I still really like this mod and think they should have done it as a standard option.
Mike
It's the journey that matters, not the destination.
Modifications ..
Tinted rear lights, Chrome bonnet fins, LED DRL/fog lights,
S200 Android head unit, Paddle shift installed, dash cam,
Resonator boxes (2nd Cats) removed, smart top.
mike350 is online now
#4 Old 05-22-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 531 Post(s)
The second cat is there to control emissions during warm-up of primary cats. It's not checked, presumably, because at present all tests are performed on a hot engine.
mike350 and nikon93 like this.
Terminal is online now
#5 Old 05-22-2018
Quoted: 6443 Post(s)
My O2 sensor locations
Front cat now missing
#6 Old 05-22-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Mike: Really the sequence on my Merc (and XF and Jeep) is manifold-O2-cat-O2-cat-muffler.
The first O2 is used for feedback to the mixture control. The second sensor is to determine how well the cat is functioning and should not deviate from the midpoint. The second cat does not seem to do much or trigger a code.
My past experience is a single cat makes a good muffler if you like to hear your exhaust.
On the whole I like Mercs and while they do a lot of neat things, others seem really strange (e.g. in an electronic world, a suck/blow door lock ? They had a bunch left over from the 1950s ?).
mike350 likes this.
Padgett is offline
#7 Old 05-23-2018
Quoted: 17 Post(s)
Are you sure that 200k has resonator and not 2nd cat? Because inside it looks just like the cat?
If I put sport cat, will the sound be quieter than now with just straight pipe?
nikon93 is offline
#8 Old 05-23-2018
Quoted: 17 Post(s)
I’’ll probably empty 2nd cat box and put perforated pipe trough it, so it won’t be visually noticable. Or do you have any other suggestions what to do?
nikon93 is offline
#9 Old 05-23-2018
mike350's Avatar
Quoted: 205 Post(s)
The simple answer is 'no', as I'm basing my comments on what I've read on this Forum and what's on page 89 here... https://books.google.co.uk/books?id=...system&f=false
Mike
Modifications ..
#10 Old 05-23-2018
Delucas's Avatar
Quoted: 1133 Post(s)
The op car if he has a 1.8 petrol has got a resonator not a second cat .
So cat - resonator and then rear twin back boxes .
So if he wanted to can remove it but it will sound diff and poss a performance hit in certain areas .
His best bet is do the back boxes replacement for sound and poss performance tweak
If he has the facelift version he allready has the pulley upgrade done .
But unclear as he is on the year change for the start of facelift .
Delucas is online now
#11 Old 05-24-2018
Vehicle: 09 slk 200 black
Would the removal of the resonator cause any performance issues. I thought it's sole purpose was to reduce vibration an noise ??
Chrispoddy is offline
#12 Old 05-24-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Resonators usually reduce a drone at certain speeds. They usually do not have much restriction. Putting a muffler at the back of a car is where the exhaust has already cooled and slowed down a bit. Have run cars with just a cat and turbos with a straight pipe, both sound good to me.
Padgett is offline
#13 Old 05-24-2018
Quoted: 17 Post(s)
Mine is pre-facelift model. I plan to do custom made mufflers in the future, but for now I am satisfied with the sound I got from just 2nd cat delete. I'll just put smaller pulley and do a remap to get a bit more power from my slk.
So if this is resonator and not cat, than it definitely won't take any effect on emission test. But I really thought that I've had 2nd cat, because of the appearance (it has ''cells'' inside of it).
nikon93 is offline
#14 Old 05-25-2018
davest4s's Avatar
Vehicle: Sept 2007 SLK55, now sold
Other Toys: 2008 Triumph Tiger 1050, 2019 Leon Cupra.
Quoted: 201 Post(s)
We had this done to our 2010 350, and were told they looked like cats from the outside but were in fact resonators, so had no secondary cats only primary. May be your model is the same.
Above photo is a breakfast meet in the inner courtyard at Wilton House.
Upgrades: X pipe and secondary cats delete, smart top, John's 3rd brake light module, DRLs, carbon rear spoiler wrap, black vinyl roof wrap, rear window tint, chrome front indicator bulbs, led number plate bulbs, white fog light bulbs, extra bright led reversing bulbs, stubby antenna, refurbished wheels in chrome silver rims and anthracite sparkle centres, remapped by GAD Tuning.
davest4s is offline
#15 Old 05-25-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 896 Post(s)
V6 (350,280)
Manifold - Cat - o2 sensor - resonator - Xpipe - rear box
V6 350 r171
Manifold -o2 upstream (regulates stft ) -1st cat -o2 downstream ( ltft ) -2nd cat ( used on cold start to speed up the temp in 1st cat, some country require cold emission test, not like in UK) - resonators - x pipe - back boxes.
mike350 likes this.
i860 is offline
#16 Old 07-10-2018
Vehicle: Thinking about an SLK
Quoted: 11 Post(s)
Hey folks, alternative for resonance, a J-pipe resonator. It's just a tube attached to the exhaust (1 for each line) that bends in a J, capped at the end. Lightweight, and is what the manufacturers are using these days to control resonance. This link has information on how to properly tune a J-pipe to maximize dampening, if anyone wanted to look into it to solve a resonance problem. According to this link they are popular in Europe, so there may even be folks in Europe who make a kit for these cars.
Vimes is offline
#17 Old 07-10-2018
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
May I suggest a study of Helmholtz resonance ?
Padgett is offline
#18 Old 10-04-2018
Taipan's Avatar
Vehicle: 07 SLK 200
Other Toys: Triumph Thruxton 900 EFi
Quoted: 7 Post(s)
I was reading about how the J pipe admits sound waves, but not exhaust gases, then bounces them back again, negating the ones coming down and cancelling the drone, or suchlike. I couldn't help but think about what effect, if any, putting a lipop baffle in a tail pipe would have?
Taipan is offline
SLK55 2005 (UK) X-Pipe and 2nd Cat Delete - MUST DO !! rgv250ads AMGs 286 2 Weeks Ago 05:37 AM
Another UK MOT passed with x-pipe & 2nd cat delete! dbgrn United Kingdom Region 32 08-29-2018 04:50 AM
Remap 2nd Cat Delete X Pipe ! Zenman 63 Performance MODS for the R171 32 09-13-2017 12:00 PM
bad cat... replace or delete? 99SportSLK SLK R170 General Discussion 1 06-09-2013 12:45 PM
CAT delete or mufflers? sajibaba Performance MODS for the R171 2 11-09-2011 05:37 PM
