Pulley change m271 r171 - Mercedes Benz SLK Forum
 4Likes
  • 4 Post By 32xforever
  • 1 Post By Glovepuppet
  • 1 Post By kotsoum
#1 Old 11-14-2017
Vehicle: SLK200 R171 163hp 2005
Hello, I made my mind and I am going for pulley change and remap. Guys where I am doing this told me that this pulley is way easier to change and better. Here are the pictures. They say that you don't have to warm up and all that hard work but to just screw it.
Sent from my SM-G920F using Tapatalk
dikaa_1998 is offline
#2 Old 11-14-2017
Vehicle: 2007 SLK 200 Kompressor Black/Red
Quoted: 15 Post(s)
That silver pulley is easier to install than the IBF one.
Once installed, the IBF looks like stock.
I would not say that the silver pulley is better for your car. It is only better for the installer since he has much less work to do.
IBF pulley is 62mm. Which size is that silver pulley?
32xforever is offline
#3 Old 11-14-2017
I assume it's 62mm, seller didn't wrote info about it. It just says that will add 30hp
#4 Old 11-14-2017
Why, because potential slippage?
#5 Old 11-15-2017
Quoted: 15 Post(s)
I ask because the size of the pulley directly influences the airflow to the engine. Then, the remap adjust the fuel to keep a reasonable Air/Fuel ratio.
1. Stock 200K (163HP version) = Crank 175mm / supercharger 72mm = 2,43 gearing X 6.200rpm = 15.100 -> 163HP
2. Stock 200K (184HP version) = Crank 175mm / supercharger 65mm = 2,69 gearing X 6.200rpm = 16.700 -> 184HP
3. 200K (163 or 184 version) + IBF Pulley + Remap = Crank 175mm / supercharger custom 62mm = 2,82 gearing X 6.200rpm = 17.500 -> 200HP
4. 200K (163 version) + Kleemann Kit = Crank 195mm/supercharger 72mm = 3 gearing X 6.200rpm = 16.792 -> 192HP
5. 200K (184 version) + Kleemann Kit = Crank 195mm/supercharger 65mm = 3 gearing X 6.200rpm = 18.600 -> 215HP
6. 200K (163 or 184 version) + IBF Pulley + Kleemann Kit + Remap = Crank 195mm / supercharger 62mm = 3,14 gearing X 6.200rpm 19.500 -> 225HP
7. 200K (184 version) + Kleemann Kit + Remap with 7000 rpm limit = Crank 195mm / supercharger 65mm = 3 gearing X 7.000rpm = 21.000 -> 240HP
8. 200K (163 or 184 version) + IBF Pulley + Kleemann Kit + Remap with 7000 rpm limit = Crank 195mm / supercharger 62mm = 3,14 gearing X 7.000rpm = 22.000 -> 252HP
For the red ones you need to seriously mod the SC or it will not support that rpm.
#6 Old 01-11-2018
Vehicle: 2004 SLK200 (171)
Other Toys: BMW R1200GS Adventure motorbike
Great info.
Is there benefit for a SC pulley only change without the remap. Remap is pricey will the ECU/Lambda sensors not adjust to suit.
Glovepuppet is offline
#7 Old 01-11-2018
Quoted: 15 Post(s)
In the m271, if you install the pulley (without remap) you will notice an improvement, BUT to release the full potential you do need the remap.
#8 Old 01-22-2018
dandywarhol's Avatar
Vehicle: 1999 SLK 230, 2009 SLK200,
Other Toys: 1967 Yamaha TD1C, 1996 Yamaha TRX850, '08 Renault Lunar Telstar motorhome
Quoted: 24 Post(s)
If you increase the s/c speed which increases the volume of air, how do you fool the MAF to not exceed 5 volts?
On the R170 you had to add a resistor in series with the MAF so it doesn't go past 4.9 volts, even with more air volume.What do you do with the R171? Thanks
dandywarhol is offline
#9 Old 07-10-2018
Slkworm's Avatar
Vehicle: Slk 200k 171, 2010, silver with sports pack
Other Toys: ASTRA VXR RACING LTD, RENAULT Captur
Chats: 2
Quoted: 48 Post(s)
Hi what difference to mpg ?
Slkworm is offline
#10 Old 02-07-2019
Vehicle: SLK 200 R171 2004
Hi, i would like to know how harmful is the pulley upgrade on the engine and overall engine “health”.
LIL DON SLK likes this.
kotsoum is offline
Larger Crank Pulley vs Smaller Super Charger Pulley Erok Performance MODS for the R170 19 1 Week Ago 06:35 AM
DIY Oil Change and Lessons Learned geophysicist SLK R170 class DIY 37 10-29-2017 12:52 PM
DIY: R171 spark plug change (M272 engine) Iridium SLK R171 Class DIY 32 06-22-2016 08:50 PM
$68 Pulley Upgrade DIY WCFD2509 Performance MODS for the R170 11 08-20-2014 11:29 PM
