SLK55 Coil overs - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Terminal
  • 1 Post By jet_fl
  • 1 Post By xopher
  • 1 Post By jet_fl
  • 1 Post By jet_fl
#1 Old 11-13-2017
Quoted: 205 Post(s)
SLK55 Coil overs
So I am not too impressed with the suspension on my SLK55. I had test drove a car that had the Black suspension setup on it and it was very nice. My car has 83k miles and I know the suspension is tired. The front struts were replaced 25k miles ago, but I am still not impressed with them. I am replacing control arms up front too. So, with that said I have searched here and not found too much about suspension upgrades.
I am looking to go Bilstein as they have a good reputation and the price isn't nuts. Has anyone used the B16 (PSS9) in their car or rode in an SLK with them in? Bilstein says you can use them in a 55, but also lists the same ones for the other models. I don't really want to put down the cash for the KW V3 ($3k) as this is just a fun car. I was looking at the V1, but they say it is for the SLK350 on down. H&R are too low, but they also say they fit all models.
So I have it narrowed down to the B16, B14 and the KW V1. The B14 is a non-adjustable B16, but I am worried they may not be optimal for the 55 and the adjustable compression damping on the B16 might help. For $400 less though, it would be nice to go with the B14 since everything else is the same. So, does anyone have some input on these 3 options?
jet_fl is offline
#2 Old 11-14-2017
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
I know that @JazzanovaSLK has Bilstein B14s on her non-AMG R171 until quite recently (they're for sale here, although she says they're not suitable for the SLK55 anyway)... I don't know whether there's any point in asking how they were on her SLK, or not?
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#3 Old 11-14-2017
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
I'd put the Bilsteins on it and forget about it. I believe the B8s are the correct ones, but the Bilstein Tech Guy can advise you.
SilverSLK2010 is offline
#4 Old 11-14-2017
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 531 Post(s)
^ I think B8 are struts only, B14/16 coil over.
Terminal is offline
#5 Old 11-14-2017
Quoted: 205 Post(s)
Yes, this is correct. B8 struts/shocks are ~$750, so I was thinking it isn't that much more to go to B14 for $400. I would like a firmer (but composed) feel than stock shocks, does anyone have the B8's on?
Terminal likes this.
jet_fl is offline
#6 Old 11-23-2017
Vehicle: '06 SLK 55 with 030 package
Other Toys: '09 Taco
Quoted: 8 Post(s)
I have B8’s on my P30 55 on all four corners. I autocross and track my car quite a bit. I went the B8 route to be able to stay in the SCCA BS street class for autocross. I like B8’s for both competition and spirited street driving with minimal additional harshness for commuting type driving. I still dodge the manhole covers as I did with the stock shocks. Installation was pretty straightforward. I didn’t have access to a spring compressor, so I had a local shop swap the front springs from the OEM to B8 struts. It took them about 30 minutes since I brought the removed struts to them.
jet_fl likes this.
xopher is offline
#7 Old 11-23-2017
Vehicle: 2006 SLK55 AMG
Quoted: 47 Post(s)
I have B8's on my 2006 '55 AMG and like them very much. I bought mine from shockwarehouse.com owing to them having the best price around at the time.
Here is what they are asking for B8's today. Local parts stores often loan out spring compressors.
tn
Thomas Nelson is online now
#8 Old 11-25-2017
Quoted: 205 Post(s)
tn
And they are an extra $40 off on BF.... Thanks for the input guys! I have spring compressors already, so that is no issue.
jet_fl is offline
#9 Old 11-25-2017
ps33fount's Avatar
Vehicle: 2005 SLK55 AMG
Other Toys: too many things to take care of and use properly
Quoted: 83 Post(s)
Question for conversion to coil-overs for the rear. Would these give any additional clearance between the inside edge of the wheel/tire as compared to stock suspension?
ps33fount is offline
#10 Old 11-27-2017
Quoted: 205 Post(s)
They use the same top perch, so it looks like the springs are the same size as stock.
ps33fount likes this.
jet_fl is offline
#11 Old 11-27-2017
ps33fount's Avatar
Quoted: 83 Post(s)
Thank you for this response. I will have to pull the rear wheel and do an inspection to see how much clearance I have, and what possible modifications that might give a bit more clearance for wider wheel/tyre (tire).
#12 Old 11-28-2017
Star/DAS Registered Owner
Quoted: 499 Post(s)
Here is a picture of the rear suspension that may be helpful: https://drive.google.com/file/d/1cv0...ew?usp=sharing
mchild is offline
#13 Old 11-28-2017
Quoted: 205 Post(s)
Thanks for this! I hadn't dug in to the rear suspension yet to realize the stock springs are inboard. That means any coilover may actually decrease the amount of tire you can put in the back.
jet_fl is offline
#14 Old 11-28-2017
Quoted: 499 Post(s)
I haven't looked at the car for the actual rear shock mounting location, but from the picture it looks to me that the top of the shock is inboard of the wheel well as the top of the shock appears to be inside of the subframe mounting point 1c. Plus the top shock mounting point is accessed from inside the trunk and what appears to be inboard of the wheel well. Careful inspection of your car is warranted.
mchild is offline
#15 Old 11-28-2017
Quoted: 205 Post(s)
Yes, the top of the shock mounts inside 1c. I haven't been able to find any really good pictures of the rear suspension, but from what I have found it looks like the outside of the shock body is basically flush with the inside of the wheel well. A coil over definitely may limit rear tire width. I will try to get some good pics shortly as I am trying to chase down a vibration and checking out the rear was the next thing to do. I had the front apart already. The front has some quirks, but a somewhat normal multilink setup.
jet_fl is offline
lgaff
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 3 3 Days Ago 12:50 PM
R171 SLK55 vs Corvette C6 specifications jameslk55 AMGs 1 05-08-2014 05:34 PM
Old but good review of the SLK55 AMG by EVO uk alroumi AMGs 0 05-06-2008 01:05 AM
