Bilstein B12 - Pro-Kit Suspension Kit - Mercedes Benz SLK Forum
  • 1 Post By Avel Du
#1 Old 10-19-2017
Vehicle: 2006 SLK280
Quoted: 9 Post(s)
At present my 280 is factory fitted with the sports pack and has covered 78k miles.
I should imagine by now the suspension has taken a fair beating on our wonderful UK roads, so
I'm toying with fitting a Bilstein B12 - Pro-Kit Suspension Kit, my questions are, has anyone
had experience with this set up, did you notice a significant difference, and do you think
it would be worth the 650 outlay ?
silky280 is offline
#2 Old 10-20-2017
Moderator/RoTMorganiser
Quoted: 2191 Post(s)
These any good? B14s though.
https://www.slkworld.com/slk-parts-sa...lover-kit.html
dbgrn likes this.
#3 Old 10-20-2017
Quoted: 9 Post(s)
Thanks for the link, I'm not sure yet, just testing the water so to speak.
Already having the sport kit, the car is lowered with quite a stiff suspension, I have heard of spring failures etc and having covered 78k miles I'm not sure whether or not it would be prudent to overhaul the suspension.
I was amazed how reasonable the Bilstein kit was, the single Ohlins rear shock on my bike would cost over 1200 to replace.
Last edited by silky280; 10-20-2017 at 12:57 PM. Reason: removed inaccurate information
silky280 is offline
#4 Old 10-28-2017
Tullamoredew's Avatar
Vehicle: SLK r171 2005 200 kompressor
I upgraded to bilstein b12 kit and didnt have factory sport pack.
With 225/45/17 tyres it is very stiff for my taste. In my country roads are pretty bad and i am constantly avoiding potholes. But i like it, car feels more connected to road and shocks perform very well when driving to the limit.
Tullamoredew is offline
#5 Old 11-23-2017
Beekster's Avatar
Quoted: 164 Post(s)
I have the B12 on Sunhilde, which was a base-spec SKLK280 manual transmission without Sport package. I kept the 16" rims when I did the upgrade. The B12 kit is noticeably stiffer than the stock suspension. It is tiring on poor pavement and does induce rattles on those surfaces. On smooth roads it is comfortable enough, and the cornering ability is dramatically improved over stock. When I go out for a romp on roads I've driven for decades, Sunhilde will carry more speed into corners than is sometimes prudent. She could probably use more tire, but I don't want the expense of 17s or a still-rougher ride. When the Continental ContiExtremeContact DW tires wear out I will fit Michelin Pilot Sports instead for more grip.
Beekster is offline
#6 Old 12-26-2017
DAS/STAR Registered Owner
Lioninstreet's Avatar
Vehicle: '06 SLK55
Other Toys: Legos, Play Doh, TinkerToys, Hotwheels
Quoted: 71 Post(s)
I had a different experience than Beekster but I'm running 19 tires. I went from the '55 suspension to the B12.
Yes the ride is still stiff, but even my wife said she preferred the ride over the OE ride as it was actually softer.
And the low profile sidewall tires really make a gargantuan difference in cornering. Definitely worth the stiff ride. I just go slow over speed bumps.
Lioninstreet is offline
#7 Old 12-27-2017
Storminnorm1's Avatar
Vehicle: SLK280 2006
Other Toys: BMW R1200GS, Honda CRF250L
Quoted: 16 Post(s)
I only recently became the owner of an SLK and never had experience of the standard suspension. One of the shocks was shot when I got it so I changed both to Bilstein B8's. It's not on the road yet but I have had it round the industrial estate where I work and boy is it hard. If the roads where you live are bad I'd think twice about it. Bilsteins might be ok round Goodwood but on poor roads I'm not so sure !
Storminnorm1 is offline
#8 Old 12-27-2017
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
The Bilstein B8s Shock/Struts are the correct replacement for the Sports Pkg. I don't see any real advantage to the B12s.
When mine wearout, if ever, I'll replace them with the Bilstein B8s. I agree the OEM and the Bilsteins are way to hard, but one must remember the fault is with the springs. The shocks simply match the rate of the springs. There isn't much one can do about it.
To soften the ride, you can go to a smaller wheel for more sidewall height, and a different brand of tire can help. My car came with Pirelli P-Zeros which rode hard and wore out fast! I switched to Michelin A/S +3s for a greatly improved ride.
And we have pot holes in Ohio! Some are so big those who fall into them are never seen again! I lost a tire hitting one recently. The sidewall had a big bulge in it. Fortunately the tire was nearly worn out. BTW, save your take off tires when you get a new set. You might need them as an emergency replacement.
SilverSLK2010 is offline
#9 Old 03-24-2018
Vehicle: Slk 200 kompressor 2008 sept
Other Toys: Electric biker
I seem to have gleaned from reading offers online Bilstein b12 consists of b8 shocks and pro kit (Eibach) springs. Is that correct?
Patrick264 is offline
#10 Old 03-25-2018
Yes its correct.
stevebis1
Drive Kit Plus -- Practical Experience & Review BertL SLK R172 General Discussion 3 06-13-2015 08:33 PM
Bilstein B12 Suspension Kit jameslk55 Performance MODS for the R171 25 12-02-2014 11:46 PM
