Well poo :( (aka I am an idiot - AGAIN!) - Mercedes Benz SLK Forum
 14Likes
  • 1 Post By waylander
  • 5 Post By Avel Du
  • 1 Post By S/RConcepts
  • 3 Post By waylander
  • 2 Post By Berliner Heckflosse
  • 1 Post By ZeroZero
#1 Old 04-17-2017
Vehicle: 2005 R171 SLK55.
Other Toys: 2019 GLC 250, 2013 SS Camaro. 2009 Renault Clio <le sigh>
Quoted: 156 Post(s)
y'all have heard the saying about fools rushing in where angels fear to tread? Guess what... as if more proof were needed I am a fool
The headers I bought look lovely - however they are not shorties (which although not necessarily as good make fitting (and other bits 'n' bobs) a lot easier. Turns out my bright idea to try and get the primary cats jury rigged up to the long(ish) tubes is a non-starter. Just to make sure that you can all laugh at me my secondary idea was to use secondary cats instead.... except I don't have any and they're not exactly common-place on fleabay (or indeed cheap).
Luckily I'm able to return said headers without too much of a loss (c.Ł50). So short-term it's likely to be standard AMG manifolds back on
Now where did I read about an SLK55 rear muffler delete.....
CHELZEE likes this.
waylander is offline
#2 Old 04-17-2017
Moderator/RoTMorganiser
Quoted: 2191 Post(s)
On the other hand...
Takes a big man to cough to a mistake.
May even have saved others trying this route.
#3 Old 04-17-2017
Vehicle: '02 SLK32 AMG
Quoted: 52 Post(s)
I agree wholeheartedly. I have posted a couple of my own mishaps/misadventures on here in hopes of others not making the same errors. Although, most of them have been because of manufacturer misinformation or faulty parts, so that feels a bit better than my own human error
S/RConcepts is offline
#4 Old 04-17-2017
Quoted: 156 Post(s)
easy there tiger - you callin' me fat?
#5 Old 04-17-2017
Vehicle: 1999 slk 230
Quoted: 510 Post(s)
Glad you can return the parts otherwise the Misses would have more "JUNK" in her beloved garden.
Personally I thing it would pretty cool using engine parts in the garden.
Avel Du and waylander like this.
Berliner Heckflosse is offline
#6 Old 04-19-2017
Quoted: 156 Post(s)
ok then - I really don't want to start about a dozen threads all about the same thing soooooo I'll try here first!
Due to non-communication from the seller of the headers it looks like I'll be keeping them (not a total disaster in all honesty) but that does mean I'll need to lose the primary cats. No problem with this in principle however it's now what to do with the cats that has me stumped. There're loads of threads relating to this from 2009/10 but at that point it's more "what happens if" stuff - 7 years down the line I would imagine that there are a lot more answers....
For example can a set of secondaries be fitted back in with an O2 sensor behind them or will that throw a code?
Will a set of 200 cell universals fit in (with pre-fitted O2 sensor)?
Will either of these options need an ECU upgrade? I figure the answer to this is that it would be better with an ECU mod but would it actually be needed?
#7 Old 04-19-2017
LeonardoDaBenz's Avatar
Quoted: 1009 Post(s)
Originally Posted by waylander View Post
Luckily I'm able to return said headers without too much of a loss.
Ya know, you tried. You learned. Nothing !! to be apologetic for.
You went a lot farther in your efforts than I ever would so good on you
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#8 Old 04-19-2017
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 256 Post(s)
Hi All
Ok my set up is Kleemann headers to long down pipe with lambo plug to main pipe with second lambo plug to secondary cats to Xpipe to rear boxes . Yes with no front cats removed you require an ECU flash to turn off error code . Your only problem is you need two new cats in front of the Xpipe .
Andy
waylander likes this.
2005 Obsidian Black 55 AMG
Black Power Coated Rims with Diamond Cut Edge
Magnaflo Xpipe kept all 4 Cats (now two removed)
Shorty Antenna (no signal type)
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
AMG Puddle Projectors
Kleemanns Headers
Eurocharged tune
Spyder Black Headlamps
AMG Logo Lower grille
G Paddles
ZeroZero is offline
#9 Old 04-20-2017
Quoted: 156 Post(s)
Hi All
Andy
I'm here with a set of (what look like) kleemann clones and a nice sounding large bore system. I guess I need to find out if it's only places like Kleemann can do an ECU or if my local rolling road can do this....
if I could ask a favour... do you have any pics of the underside of yours?
#10 Old 04-20-2017
ZeroZero's Avatar
Quoted: 256 Post(s)
Hi All
https://www.slkworld.com/performance-...s-started.html
That my post when I got this work done .
There are a kleemann agent down your way
Specialists in Mercedes & AMG | SKG Performance
Have a word with them ,not sure they will like your clone headers.
Andy
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
Kleemanns Headers
Eurocharged tune
G Paddles
ZeroZero is offline
Road rage idiot. Gordosoar Driving Stories 20 04-22-2016 04:07 PM
14 Dangerous Emails That Could Be in Your Inbox jbanks15 Off Topic 5 07-13-2013 01:37 PM
Poo Poo You Sprint Booster ! Steve Karr General Modifications R170 11 07-10-2013 10:26 AM
Parking Lot Idiot garylight Off Topic 0 09-06-2009 04:11 PM
