More negative camber desired - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Durkatlon
  • 1 Post By xopher
  • 1 Post By Nikken
  • 1 Post By xopher
#1 Old 12-06-2016
Vehicle: '06 SLK 55 with 030 package
Other Toys: '09 Taco
Quoted: 8 Post(s)
Does anyone have any experience with adding crash bolts to get a little extra negative camber? Is only one per side required? Or two? I知 looking to stay in the SCCA street class for autocross. I知 not aware of any other allowed way to get some more negative camber. Any ideas are appreciated.
Chris
xopher is offline
#2 Old 12-06-2016
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
Chris
I had K-Mac adjustable bushings on my previous SLK to allow camber to be set. Would those not be allowed in autocross?
etyu likes this.
Durkatlon is offline
#3 Old 12-06-2016
Quoted: 8 Post(s)
Those are not allowed in Street/Stock SCCA classes. Only adjustments that can be made with standard OEM parts is allowed. Crash bolts are OK. To quote from the rule book:
Both the front and rear suspension may be adjusted through their deャsigned range of adjustment by use of factory adjustment arrangements or by taking advantage of inherent manufacturing tolerances. This encomャpasses both alignment and ride height parameters if such adjustments are provided by the standard components and specified by the factory as norャmal methods of adjustment. However, no suspension part may be modiャfied for the purpose of adjustment unless such modification is specifically authorized by the factory shop manual.
Suspension bushings, including but not limited to those which carry the weight of the vehicle and determine ride height, may not be replaced with bushings of a different material or dimension.
etyu likes this.
xopher is offline
#4 Old 12-09-2016
Vehicle: Slk r171 200 kompressor 05
Quoted: 20 Post(s)
i'm using the bolts, you need one on each side. highly suggested, steering get a better weighting and the preload of the inner wheel (while cornering) increase the front grip and increase oversteering...expect -1,5 degrees per side. go for it
etyu likes this.
Nikken is offline
#5 Old 12-10-2016
Quoted: 8 Post(s)
Thanks for the feedback. There are two different struts on the front axle that can have the crash bolts installed. Is it the aft one? Bolt number 200 for strut item 160 in the attached diagram? Or item 2 in the attached picture?
I知 thinking of changing the bolt and having the front toe changed to 0 degrees.
xopher is offline
#6 Old 12-10-2016
Vehicle: 2006 SLK 280 Black
Other Toys: None
Quoted: 101 Post(s)
Mine needed a minor adjustment to the camber on the right (just for street use) when it was measured on the alignment rack (and a new lower-right-rear control arm replaced due to a worn-past-spec ball joint). The adjustable bolts for the front suspension are an optional factory part number and should pass any inspection if I read those rules correctly. They cost about $18 each.
Since it's the same amount of labor to replace two as it is to replace four (both have to be undone to replace any on each side), I saw no point in not outfitting the suspension with all four adjustable bolts. Now my car has fully adjustable camber, caster, and toe-in on the front suspension should I ever want to experiment with different settings. ... When they re-setup the front end, they were able to dial-in all the adjustments to be right on the money on both sides.
(The reason they don't put the adjustable bolts in straight from the factory is cost of manufacture. It's MUCH less expensive to pick from a set of stock, fixed length bolts based on an individual car's measured chassis/suspension bits' variances rather than having to assemble then set the adjustment values individually, and at the factory they aim to get the adjustments within the acceptable range, not necessarily right on the money.)
G
Godfrey is offline
#7 Old 12-10-2016
Quoted: 20 Post(s)
it is the number 2 in the left pic, the other one is for caster adj
these http://www.ebay.com/itm/CAMBER-CORRE...-/321423006118
Nikken is offline
#8 Old 12-11-2016
Quoted: 8 Post(s)
I ordered a package of 4 bolts. I'll give an update when I get them installed then take the car in for an alignment. I'm assuming they are pretty easy to install.
Durkatlon likes this.
xopher is offline
Check your tires esp. the inner side walls etyu Tires, Wheels, Brakes & Suspension 74 07-05-2019 01:06 PM
Front camber adjustment joebajoe SLK R171 General Discussion 6 02-01-2015 11:39 AM
Removing Negative Camber Roadfly General Modifications R171 30 08-18-2014 11:58 AM
Negative Camber? SLKrazy Performance MODS for the R171 5 03-21-2010 02:21 PM
Negative Camber Angle... diclehana General Modifications R171 22 09-11-2007 02:26 PM
