1000 euro upgrade - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By cyberdrakon
  • 2 Post By Lioninstreet
  • 1 Post By Delucas
  • 3 Post By Lioninstreet
  • 1 Post By mrtheedge2u2
#1 Old 07-24-2016
Vehicle: 2005 SLK 200
1000 euro upgrade
Ladies and Gents,
I will be handing over the SLK to the misses once my new car arrives but I want to give it a bit more growl before I do as she likes the sound of an engine.....
Therefore if I was going to spend 1k euro on upgrade(s) what would you recommend - I do not need to have an engine that has enough torque to pull the Earth out of orbit but a nicer more growling engine noise if the aim of the game....
Any recommendation is welcome.
mrthe
mrtheedge2u2 is offline
#2 Old 07-24-2016
Quoted: 6443 Post(s)
search will find
xpipes
removal of cat or cats
or resonator
https://www.google.com/?gws_rd=ssl#q...rld.com+xpipes
#3 Old 07-24-2016
Thanks, Jeff
Would a sports filter box be a recommended update also?
#4 Old 07-24-2016
Imho, they don't add much hp wise. Get some green filters or spend some dough
BMC High Performance Air Filters
#5 Old 07-24-2016
As Jeff recommended:
1. Remove resonator and replace with X-pipe, and
2. Remove secondary cat (catalytic converter) and replace with short section stainless steel pipe of appropriate diameter
IIRC, with completion of the above 2 procedures, the vehicle will still pass MOT (several members in the UK have done this to their 55's).
#6 Old 07-24-2016
Moderator/RoTMorganiser
Quoted: 2199 Post(s)
Once you've got the sound fit a smarttop if you haven't already.
It gets almost as many looks as the sounds but is also very satisfying pressing 'open' from the point you leave a building
to have an open top by the time that you reach the car.
Avel Du is online now
#7 Old 07-25-2016
cyberdrakon's Avatar
Vehicle: SLK55 2006 widebody
Chats: 7
Quoted: 55 Post(s)
I don't think X pipes would help the SLK 200, which has a Y-pipe in place, I think the best option is to change the muffler.
Delucas likes this.
cyberdrakon is offline
#8 Old 07-31-2016
DAS/STAR Registered Owner
Lioninstreet's Avatar
Vehicle: '06 SLK55
Other Toys: Legos, Play Doh, TinkerToys, Hotwheels
Quoted: 71 Post(s)
OP has a r171 slk 200.
Correct me if I'm wrong but the 200 only has a single exhaust pipe coming out of the motor. How would you setup an x-pipe?
On the other hand it supercharged, maybe someone makes an overdrive pulley for the 200 like they do for the r170 slk32's. That, an ECU mod, and some good flowing air filters and the little I4 should sound much more snarly.
And I'm sure your wifey wont mind some extra ponies...
bumpa2 and #FullDragon like this.
Lioninstreet is offline
#9 Old 08-01-2016
Delucas's Avatar
Quoted: 1133 Post(s)
A smaller pulley / belt etc upgrade would give a bit more power
And ecu mod .
But the op is after growl noise so best bet is a modded back boxes or removal of wadding in rears .
Or removal of center exhaust section .....?
mrtheedge2u2 likes this.
Delucas is online now
#10 Old 08-01-2016
Vehicle: '06 SLK55
Quoted: 71 Post(s)
And ecu mod .
I presumed that with a budget of 1k, OP's wife would want results that offered an aggressive growl and a car that was more fun to drive. He should be able to get both for that kind of coin.
jbanks15, bumpa2 and mrtheedge2u2 like this.
#11 Old 08-02-2016
#FullDragon's Avatar
Vehicle: R171 2006 SLK 200 kompressor
Quoted: 89 Post(s)
If I were you I'd choose a variation of Kleemann tuning which pass my budget.
#FullDragon is offline
#12 Old 08-03-2016
We live in Holland so do not really use the hood that often
#13 Old 08-03-2016
Thanks for the tips guys. As Delucas said, the growl is more of the aim.....but of course ball crushing acceleration is never to be sniffed at
Delucas likes this.
#14 Old 08-03-2016
Delucas's Avatar
There are company's here that will make / fabricate or allready have rear sections for your slk id imagine from 350.00 - 600.00 on make and look .
But add a K&N air filter as there quite cheap .
Ive been using one for a year or two now .
And no issues at all in fact bumped my mpg .
#15 Old 08-06-2016
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
Always got compliments about the exhaust note from our 2008 (facelift) SLK200. That had the stock exhaust system and did sound better than earlier SLK 200s. Don't know if the later exhaust fits the pre-facelift model, the trapezoid tailpipes would dictate some mods for the rear bumper.
GeeJay is offline
BAT Auction Euro 1979 Mercedes-Benz 450SEL 6.9 Berliner Heckflosse Off Topic 0 05-10-2016 12:03 AM
Stereo Upgrade 2009 SLK350 crowec22 General Modifications R171 3 03-14-2014 12:02 AM
New Nav/Sat?HD/Tel/Video/everything upgrade ERS113 General Modifications R171 2 12-31-2012 12:15 PM
