Piecha/Sprint Booster-like device for brakes? Brake tuning? - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By Sneaky Pete
  • 2 Post By mchild
  • 1 Post By Serious
  • 1 Post By mchild
#1 Old 10-17-2015
LeftyS7's Avatar
Vehicle: 2010 SLK350, Moda MD20 rims, Deflectair, Clearbra, SmartTop, Piecha accel Mod, B6 shocks
Other Toys: '95 Suzuki Sidekick
Quoted: 67 Post(s)
Unhappy Piecha/Sprint Booster-like device for brakes? Brake tuning?
Two things that bother me about the SLK is its slow response to accelerator and brake pedals. There is a fix for the accelerator, is there a similar fix for the brakes? When I hit the brakes I want them to start braking NOW, not after I've pushed them half way to the floor. Pads are fairly new, as is brake fluid. It's not that they don't start engaging right away, it's that they don't engage enough. I want them "grabbier".
Any suggestions? Adjustments? After market products other than brake upgrades?
LeftyS7 is offline
#2 Old 10-17-2015
Quoted: 532 Post(s)
The accelerator pedal is connected with the ECU with a wire. The "fix" for the slow response is a device that amplifies this signal, thus fooling the ECU by letting it think you pushed in the pedal more. Same result btw can be achieved by just doing that, pushing in the pedal more, but let's not start that discussion again.
Brakes are a whole different story as you can imagine. There is no easy or cheap fix for this afaik. If you're not satisfied with the brakes as they are than the only remedy is a brake upgrade with kits from Brembo or Stopptech i.e.
jbanks15 and u_2504 like this.
Sneaky Pete is online now
#3 Old 10-17-2015
Beekster's Avatar
Quoted: 164 Post(s)
As noted, the only solution for brakes is to upgrade components. But you already have "drilled" rotors (actually cast in place on M-B parts) and four-piston calipers up front, if I'm not mistaken. That's a pretty good foundation. Mercedes OE pads are quite soft, and so have good initial bite but create a lot of dust. Aftermarket pads like Akebono or Green/Yellow/Red stuff typically don't bite as fast but are better able to tolerate high temperatures such as that seen in track use. So your solution may not actually lie with the brakes...it may be tires instead. What are you running now? Unless it is something like the Michelin Sport Cup, there is always a softer, grippier, shorter-wearing tire out there as an option.
Beekster is offline
#4 Old 10-17-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
I volunteer that you may well have something wrong with your brakes - air in the system, faulty servo or poor friction pads.
If as you say, the brakes only engage after pedal is half depressed, sounds very like some air in there.
The SLK brakes are no worse than any other car of its type in that it is classed as a small sports car where the feel of driving is inbuilt. Be careful with larger brake kits, they are not the panacea to everything and lead to brake grabbing and can suffer from brake squeel if they are too big for the car.
Hal Adams is offline
#5 Old 10-18-2015
LeftyS7's Avatar
Quoted: 67 Post(s)
I realize that the gas pedal is electronic and by wire and I did not believe there was an electronic fix for the brakes but hoped that possibly some company made some kind of mod like a booster, or something. I'm not racing the car and am not concerned with absolute stopping power. I'm concerned about the brakes engaging more fully once the pedal is depressed. I'm guessing that M-B didn't want that for the average customer, just as it didn't want a quick gas pedal response. If M-B pads are grabbier then replacing them with something else will only make the matter worse. I don't believe that there is any inherent adjustability or my excellent mechanic would have done so. I guess it's something that I'll have to live with.
Thanks for the responses
LeftyS7 is offline
#6 Old 10-22-2015
Serious's Avatar
Vehicle: 2005 SLK350 MT
Other Toys: 2014 Maserati GTS, 2004 Kawasaki 636, 2006 Kawasaki 636, 2001 Honda 929
I swapped out the brakelines with the steelbraided kind. The brakes are not as mushy and I get better brake feel. And like someone said above use higher temp rated brake fluid to help eliminate brake fading.
Serious is offline
#7 Old 10-23-2015
Star/DAS Registered Owner
Quoted: 499 Post(s)
As already noted, the pad material can make a difference in how the brakes feel and how quickly the pads start to slow the movement of the car. Stock OEM pads are typically the softest and most responsive. There is a huge aftermarket of pads with all kinds of pad composition. Many aftermarket pads that are designed to give long life will be much harder than stock pads and will be less responsive to initial brake application.
Replacement of the stock rubber brake lines can make a noticeable difference in the feel of the brakes. Old rubber lines can swell as the hydraulic pressure increases as the pedal is depressed. Other than different pads and stainless steel braided brake lines, there is little that can be done. Remember, that the movement of the brake pedal equates to a relatively small movement at the calipers. There is a lot of leverage between the brake pedal and the caliper. Brake pads only move a fraction of a millimeter from disengaged to fully engaged. If the amount of pedal movement is decreased, you would likely risk the pads not fully disengaging when the pedal is released.
For any brake system the brake fluid has to be fresh, the steel and rubber brake lines can not be compromised, rotors can't be glazed, floating calipers must move freely, pads must move freely, and the caliper piston(s) can not be restricted in it's movement. That's a lot of variables and any or a combination that are not functioning properly can greatly impact the effectiveness of the brakes.
Hope that helps.
etyu and Serious like this.
mchild is offline
#8 Old 10-23-2015
LeftyS7's Avatar
Quoted: 67 Post(s)
For daily driving or track use?
A downside of steel brake lines is that they can corrode in areas with salt (in air or on roads). I put them on my Caterham Super Seven and it did make a big difference.
LeftyS7 is offline
#9 Old 10-23-2015
Serious's Avatar
Daily driving with some track use. I haven't noticed corrosion yet but I live in L.A. and the car is parked in the garage mostly. I do have them on my motorcycles as well and have not noticed corrosion on them either.
Serious is offline
#10 Old 10-23-2015
Beekster's Avatar
Quoted: 164 Post(s)
I had braided stainless lines on my old 190E 16v and they did improve brake feel. I'm thinking about them for Sunhilde, too (any suggestions for possible vendors?). The inside of the lines are teflon, so that certainly won't corrode. The stainless won't either, unless you're driving all winter where they dump a lot of salt on the roads (and I hope you don't drive your SLK in those conditions).
Beekster is offline
#11 Old 10-24-2015
Serious's Avatar
Vividracing.com they are in Arizona. Great customer service.
Beekster likes this.
Serious is offline
#12 Old 10-24-2015
Quoted: 499 Post(s)
StopTech has a set and it looks like that is what Vivid Racing carries.
mchild is offline
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Replace Brake Booster Vacuum Hose SLK 320 DIYGirl SLK R170 class DIY 4 01-31-2018 04:48 PM
Brake Booster Vacuum Hose Replacement DIYGirl SLK R170 General Discussion 8 09-09-2013 11:01 AM
Performance Brake Kits at CARiD - Your Safety Guarantee! carid CARiD.com 1 03-20-2013 08:34 AM
