Polyurethane bushings - Mercedes Benz SLK Forum
#1 Old 01-23-2015
Fanatical Owner
Oszy's Avatar
Vehicle: 2005 Mercedes SLK 200 Kompressor
Other Toys: Mercedes ML 320 CDI
Quoted: 15 Post(s)
Hello everyone.
Most of my bushings are ready for a replacement, and I wanted to go with polyurethane bushings all around.
I remember looking at a set of bushings on cksperformance.co.uk a while ago, but now I cant find them anymore...
I have tried looking everywhere online and cant seem to find any that fits the slk r171.
Can you guys be of any help on this subject?
Thanks in advance
Oszy is offline
#2 Old 01-23-2015
Quoted: 6430 Post(s)
Mercedes-Benz SLK-Class (2005-2011) R171 - Suspension, Shocks & Springs - Page 1
Hedgehog Tuning and Motorsport Blog: Product Pictures: Polyurethane Bushing for Mercedes Benz
any of these do?
#3 Old 01-24-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you.
Unfortunately none of the bushings on the first link you sent me were polyurethane. Just standard oem rubber.
I sent hedgehog motorsport an email with some questions
Oszy is offline
#4 Old 01-24-2015
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If you can find any for a CLK or C class from 2004-2008, they should fit, as it's virtually the same running gear.
Woolly is offline
#5 Old 01-24-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you so much!
Hoping to find some more for those as it is damn near impossible to find any for the slk specific.
Do you know if the rear bushings and suspension arms are the same or uses the same bushings?
Oszy is offline
#6 Old 01-24-2015
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by Oszy View Post
Thank you so much!
I'm pretty sure they do - and there are a lot more options for the CLK / C.
If you find a supplier for poly bushes for those cars, check what year they are for, then I can check against your VIN if they are compatible - if the bush manufacturers can't do it for you.
Woolly is offline
#7 Old 01-24-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
I checked up Powerflex - Performance Polyurethane Bushes - Black Series - Road Series and they have for C-class(2008-2013) and E-class(2010-2013)
Do you know if these will fit maybe?
I dont have the datacard for my car in specific, but i found one for another 200k slk.
https://www.slkworld.com/attachments/...421f007232.pdf
Mod list:
- Real carbon fiber hood vents and fins
- 19" Rial Lugano Glossy Black wheels
Front: 235/35 R19
Rear: 255/30 R19
- Carbon fiber diffuser
- Carbon fiber rear spoiler
- Carbon fiber interior
- Carbon fiber wing mirrors
- Upgraded stereo
Pioneer AVH-8400BT double DIN head unit
2x DLS Ultimate UP8i 8" mid and 1" tweeters
2x Hertz HL70 4" full range
DynaBel 6channel amplifier
Mosconi 6to8 DSP
Possible sub install behind seats later
- Vertical doors(Vertical Doors Inc.)
- Matt black vinyl on hood and roof
- H&R Coilovers
- Custom built quad tail pipe exhaust system
- Kleemann header and sports cat
- Sprintbooster
- Modified supercharger
Oszy is offline
#8 Old 01-24-2015
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
I think they might have to be the series before - the R171 was based on the running gear of the C class (and CLK ) that were in production in 2004.
Post up your VIN, and I'll get you your datacard.
Woolly is offline
#9 Old 01-24-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
turns out they only had the camber adjustment bolts for the cars i mentioned...
Okey, I will look out for any if I can find them.
At the moment I dont have acces to my car, but will get a hold of the VIN once I get back home
Oszy is offline
#10 Old 01-25-2015
Vehicle: Slk r171 200 kompressor 05
Quoted: 20 Post(s)
same situation here oszy, had powerflex on my previous bmw and i had a huge improvements......
Nikken is offline
#11 Old 01-29-2015
bac
DAS/STAR Registered Owner
bac's Avatar
Vehicle: 2004 SLK350
Other Toys: RS Megane 225
Quoted: 40 Post(s)
Hello everyone.
Hope you like mice in your car! (squeak, squeak...) There are good reasons why most manufacturers still use rubber in their OEM bushings. Polyurethane may be trendy but generally does not outperform rubber especially if the car's suspension was not originally designed for it.
Cheers,
Brian
bac is offline
#12 Old 02-02-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
I finally managed to source a manufacturer that makes bushings for our SLK!
They have three options... Could anyone tell me the benefits of the two options that differs to oem mounting?
The options are:
Standard
One offset and one standard
Two offset
LINK
Mod list:
Front: 235/35 R19
Rear: 255/30 R19
- Upgraded stereo
Mosconi 6to8 DSP
- H&R Coilovers
- Sprintbooster
Oszy is offline
#13 Old 02-02-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
Offset bushings will have the centre moulded off centre. Appropriately rotated, they have the effect of altering the geometry. Used in competition environment where small adjustment changes can be quickly made.
Be very careful using them as their rotational fitting can make a difference between right and left if not monitored/measured.
Edit:
I looked at your link since posting the answer to your question - the ones in the link are for the strut only and not for the swing arms. The offsets on these two bushes will effectively alter the length of the strut and are not as critical to the main geometry.
Hal Adams is offline
#14 Old 02-05-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you for the answer.
What does that mean in practical terms that they alter the length of the strut? From installing the coilovers, I cant recon any bushings of that kind on the struts?
Oszy is offline
#15 Old 02-05-2015
Quoted: 863 Post(s)
Are you just replacing bushings on a factory suspension or has the suspension been modified?
efair is online now
#16 Old 02-05-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Hopefully replacing bushings on factory suspension arms.
Oszy is offline
#17 Old 02-09-2015
Quoted: 271 Post(s)
Hey Oszy - I owe you a big apology. In my last post to your question, I got my mind muddled up between BMW and Mercedes, so there were a couple of mistakes. I suddenly remembered them and asked Jeff to delete the post and I start again:
Offset bushes are meant for strut bars that connect to the hub, such as BMW E96 type. By rotating the offset, the bar is longer and reduces the camber.
However, and here was my error, the MB strut bar connects to the rollbar and not the hub. Therefore the camber is set. It can only be changed by playing around with the top mount.
The Aiustralian link you gave earlier shows offsets for the SLK. Wrong, they will not do anything meaningful so leave them be.
Again, sorry. Next time I will try and engage brain first...
The Following User Says Thank You to Hal Adams For This Useful Post:
#18 Old 02-14-2015
Quoted: 20 Post(s)
have a look on this ones, polyurethane, they claim to be made for the w203 but they should fit on r171 http://www.superflex.co.uk/products.php?cat=249
Nikken is offline
#19 Old 02-19-2015
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Originally Posted by Nikken View Post
have a look on this ones, polyurethane, they claim to be made for the w203 but they should fit on r171 SuperFlex: Advanced polyurethane suspension bushes
I took a look at the parts diagrams and part numbers for the two cars on getmercedesparts.com and found that the part numbers for the control arms and torque arms are identical. Even though they are differently shaped on the diagrams(drawings)... So I guess they should fit.
Question now is... How do I choose which to get? What are the benefits of the eccentric ones vs the standard ones?
My car is very lowered, so I'm thinking the more adjustability the better?
But what do they adjust, and how do I adjust them?
Oszy is offline
#20 Old 02-19-2015
Quoted: 271 Post(s)
Go back to one of my earlier posts - you adjust them by moving the bush around in its mounting.
Again, I would urge you not to get the eccentric ones unless you have the means to measure your geometry. These will not help lowered suspension other than altering the wheel camber, and without the ability to measure, possibly the camber and toe-in/out.
Why are you so averse to the standard rubber bushes? With 19" wheels AND polyurethanes, you must be desperate to increase your dentist bill !!
Control Arm Bushings MercedesOwner230 SLK R170 General Discussion 0 01-25-2014 03:33 AM
R170 K-MAC front and rear bushings for sale quikdraw SLK Parts For Sale 1 03-23-2013 01:18 AM
Found a possible supplier for front eccentric camber bushings. maxcichon Tires, Wheels, Brakes & Suspension 1 04-18-2012 01:11 PM
Swaybar bushings replacement needed nmslk SLK R171 General Discussion 3 11-26-2011 04:41 AM
