Bilstein B6/ stock spring combo - Mercedes Benz SLK Forum
#1 Old 11-01-2014
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 32 Post(s)
I put Bilstein B6s all around last year but on stock springs. I had a 350 with sport suspension.
Unfortunately, I am finding the ride to be too firm mainly due to crashing on potholes, more tramlining and more rattling in the cabin. Handling is fab during a spirited drive in the local countryside.
My car has done 65k when i changed the shocks. My questions is - Would Eibachs offer better ride quality with B6 dampers than what i have now, or shall i cut my losses and make everything stock again? I may get new OEM shocks all around and may change the rear springs too....
Opinions please...
nakulan7 is offline
#2 Old 11-02-2014
Vehicle: 2013 SL63
Other Toys: Audi SQ5 (with all the toys), Kalkhoff Pro-Connect 'leccy bike
Chats: 2
Quoted: 61 Post(s)
Hi Ram, long time no speak!
I doubt that fitting Eibachs as opposed to "sport" springs would make much difference. I've not tried them on an SLK but I did use them on my old Z3M and they were pretty stiff. Although they were described as "progressive", ie softer at the beginning of their travel but firming up as they compressed, I found them to be a lot stiffer than stock all the time.
I think that you'll have to go to standard, softer springs to improve the ride but at the expense of more body roll. You can play around with the rubber spring pads to change ride height to a limited extent.
Tyres/wheels can also make a big difference. When I changed my 17" 350 wheels to 18" AMGs it made the ride crashier (but it did look nicer!).
Hope you manage to get it sorted.
Russ
russj is offline
#3 Old 11-02-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Yeah, I also don't think it's going to make much of a difference. You already opted for B6 instead of B8. The non-Sport-Pack springs from Eibach might result in *somewhat* smoother ride, but you are probably going to be better off going back to a stock setup.
Durkatlon is offline
#4 Old 11-02-2014
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
I have the same car, and the ride is a little stiff. I think the B6 Bilsteins would be my choice of shocks although Bilstein makes OEMs for this car.
The problem is the front has a 0.5" drop compared to the non-AMG. This requires a shorter spring with a higher rate(stiffer) to prevent bottoming on bumps.
Changing to Eibachs won't cure the problem, since they are a lowering spring. What you want to do is get rid of the drop which is easy to do. Just replace the front springs with the non-AMG spring.
Your ride height will increase by 0.5", and you have more front clearance for the chin spoiler and a less harsh ride. BTW, the back is fine.
DSSG is offline
#5 Old 11-05-2014
nakulan7's Avatar
Chats: 2
Quoted: 32 Post(s)
Thanks Guys. I am really torn up about this as it rumbles and rattles on broken roads but absolutely sublime through corners. Even roundabouts are fun!
What to do...what to do...?
nakulan7 is offline
#6 Old 03-16-2015
Vehicle: R171 slk 200
hey mate i am having the same issue however i am on stock shocks and springs now. so did you solve your rumble and rattle on uneven surfaces? if u did solve, what setup did u use? thanks!
wrx_sti10 is offline
#7 Old 03-24-2015
Vehicle: 2006 SLK55 AMG
Other Toys: G35, Eagle Talon Tsi
Quoted: 19 Post(s)
I solved some of my rattles and crashing by running tires with a little more profile (sidewall) and installing a front strut bar. The strut bar helped a lot!
CLyons0203 is offline
#8 Old 03-26-2015
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 17 Post(s)
Try to avoid the broken roads. Maybe lube your roof and trunk to make sure those aren't rattling. I'd probably ask Bilstein about this since the sport shocks are designed for sport springs. Personally I'd upgrade the springs to the Eibachs for the look and performance.
jameslk55 is offline
#9 Old 03-26-2015
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
Opinions please...
Best suggestion of the thread..
Hal Adams is offline
Spring is here stock up on your detailing gear @ DetailersDomain.com DetailersDomain Caring for your SLK 0 03-19-2013 08:35 PM
supercharger pulley spring -2004 slk200 zeusthegreatest Where to get R171 SLK Items 7 11-24-2012 06:52 AM
Bilstein B8 s and stock springs lowinsure Performance MODS for the R171 27 05-08-2012 02:12 AM
Spring for R171 ? mrl0n3ly714 General Modifications R171 4 10-31-2011 01:25 AM
