Brake upgrade - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Stinger
  • 1 Post By Stinger
  • 1 Post By Stinger
#1 Old 09-17-2014
Fanatical Owner
Oszy's Avatar
Vehicle: 2005 Mercedes SLK 200 Kompressor
Other Toys: Mercedes ML 320 CDI
Quoted: 15 Post(s)
Brake upgrade
Hello everyone!
Ive been thinking of doing a brake upgrade for a while now and just came across some really nice AMG calipers on ebay.
2005 2006 Mercedes Benz AMG SL55 SL65 Brembo Brake Caliper Set Genuine Gold | eBay
Could anyone here tell me if these will fit the SLK or not?
I believe they are from a S-class
Mod list:
- Real carbon fiber hood vents and fins
- 19" Rial Lugano Glossy Black wheels
Front: 235/35 R19
Rear: 255/30 R19
- Carbon fiber diffuser
- Carbon fiber rear spoiler
- Carbon fiber interior
- Carbon fiber wing mirrors
- Upgraded stereo
Pioneer AVH-8400BT double DIN head unit
2x DLS Ultimate UP8i 8" mid and 1" tweeters
2x Hertz HL70 4" full range
DynaBel 6channel amplifier
Mosconi 6to8 DSP
Possible sub install behind seats later
- Vertical doors(Vertical Doors Inc.)
- Matt black vinyl on hood and roof
- H&R Coilovers
- Custom built quad tail pipe exhaust system
- Kleemann header and sports cat
- Sprintbooster
- Modified supercharger
Oszy is offline
#2 Old 09-17-2014
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
Yes, they will fit. But only after you have carried out a host of other modifications!
1. You will need new discs of the correct size.
2. You will need the correct bracket carriers.
3. You will need longer flexible pipes
If you are going down this road, I would advise you look at buying a 'GT Big Brake Kit' from Brembo specifically for your model and year. This way, you will know it will fit first time.
Here is an example (you can specify the colour of the calipers at point of sale). But shop around as there are many outlets selling these where deals are available.
Mercedes SLK Class, Excl AMG Front (R171) Brembo GT 6 Pot Front Brake Conversion - Slotted 1M2.8022A Only 3221.64
Hal Adams is offline
#3 Old 09-17-2014
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
I know I will need new discs, pads and so on. My concerns are mostly as to if they will fit on the SLK caliper mounts and if the distance to the discs will be okey. I know some calipers was too far in to fit on the rotors when another member tried to do a brake upgrade.
I have looked at other big brake kits earlier, but just came across these nice looking AMG calipers and they were cheap as well.
Do not want to spend more than 3K for the fronts alone from brembo(overpriced)
Mod list:
Front: 235/35 R19
Rear: 255/30 R19
- Upgraded stereo
Mosconi 6to8 DSP
- H&R Coilovers
- Sprintbooster
Oszy is offline
#4 Old 09-17-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
I looked into this a while back because I also had a line on a set of cheap OEM brakes from a different model. There are a very large number of brake component part numbers used by Mercedes, which mostly appear to differ in terms of the bracket that they use. Ultimately I decided against it because I didn't want to deal with having to get this part and that part in addition to the brakes just to get things to fit correctly.
Durkatlon is offline
#5 Old 09-18-2014
Quoted: 271 Post(s)
So you want cheap brakes, then Brembo are definitely not for you. The SL ones you are looking at on ebay are Brembo, as are all SL models. Mercedes - and all other major marques - will only use Brembo.
You should be looking at the cheapo ones, eg:
Mercedes SLK R129 R170 R171 Front 356mm 6-Pot PB Brakes Big Brake Kit BBK | eBay
If you want to fit the ones from ebay, you will need a friendly MB dealer who is happy to give you parts on sale or return so that you can try various combinations until you find the right one.
The calipers you see are a Brembo standard that are used on MB, Jaguar, Porsche etc - they do not necessarily fit directly to the stub axle, but have a carrier bracket as an interface - my point No2.
Same with the discs, these are available in combinations of OD and offset. You need to find the right one.
Now, the ebay calipers say they are off an SL65. It could well be that the brackets and discs may well suit, but it will be trial an error - hence the need for your friendly dealer.
Happy days if you think you can get all the parts under 3K...!
#6 Old 09-18-2014
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thanks for your reply.
I know it will be trial and error and that i most likely will need brackets to make them fit 100%.
I am in no ways looking for cheap brakes or have the lack of money.
Money is not the issue, it is simply a matter of principal... Why pay more for less?
I know that I am most likely going to spend more than 3K for the brake upgrade. But I dont want to buy those overpriced brembo kits for just the front for the same amount that I can get all four brakes from an AMG for the same price while knowing that merc brakes are brembo as well.
I have several friends that work at the merc dealership here and can provide me with part numbers and so on. I will buy the parts from outside Norway since even with my friends employee discounts the price for parts still is 500% of what they cost in germany.(because of norwegian salary and cost they overprice everything)
Mod list:
Front: 235/35 R19
Rear: 255/30 R19
- Upgraded stereo
Mosconi 6to8 DSP
- H&R Coilovers
- Sprintbooster
Oszy is offline
#7 Old 09-19-2014
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
On a 200, I think the brakes from a 350 would be a better upgrade.
The big AMG units would be overkill and pads would probably end up glazed and squeal badly on low speed braking. The big callipers add to the unsprung weight of the wheel/hub assembly too. In addition, because you have non OEM rims, you would need to check that the AMG callipers will clear on radius and offset.
The bigger brakes will look nice of course and for sure with 19" rims on the stock 200 brakes will look a bit puny. So if it's looks you're after and that's what you're doing the mod for, fair enough knock yourself out... I guess.
GeeJay is offline
#8 Old 09-21-2014
Some body need to jump on these SLK55 PERFORMANCE Calipers and rottrs.
Mercedes SLK55 AMG Package Front and Rear Calipers 2008 2009 2010 2011 | eBay
Klinh is offline
#9 Old 09-21-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
Hi Oszy. I can't speak highly enough of my Ceika BBK upgrade. Complete kit was $3160.00 usd, came with EVERYTHING you need. The difference is amazing. I went with Front Small 8 pot 356x32mm and Rear Small 6 pot 356x28mm combo, but they offered me four different packages starting at $2875.00 usd. Both performance and looks are stunning, rotors are huge, and all at half the cost of Brembos.
HERE is a link to my modification thread and HERE is a link to their website.
Akonion likes this.
Steven
Stinger is offline
#10 Old 09-23-2014
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you for your input. I will put that into consideration.
Here in Norway, almost all modifications that you do to a car here have to be aproved by a err... not sure how to put it in english, but its a government "company" that have to look at the car, look at the documentation and then decide if it is street legal or not. (Had to look it up out of curiosity, and the norwegian-english dictionary calls it "Public Roads Administration")
If you get pulled over by either police or by them and the cars modifications is not in the vehicles registration they will take you plates and you basicly have to walk home and get the car towed, converted back to stock and show it to them in order to get your plates back.
I know that huge AMG brakes will be overkill on the 200K. BUT most of my mods so far have been done with future power upgrades in mind.
If I go for the smaller 350 brakes I am afraid that they might be too small and not get approved by the "Public Roads Administration" for street use when/if I get a engine swap next year like planned.
If I go for overkill brakes now, I dont have to upgrade them once more when/if my engine gets swapped. Because the bigger brakes will have the stopping power to stop the car.
Regarding your thoughts about the rim clearence. This will not be an issue as I am using spacers and in a little while I am getting my new wheels on the car as well and they have plenty space for the bigger brakes
Thank you Stinger! I have looked(and drooled) at your thread earlier and I love the look of them! Its great to hear that they deliver what they promise.
Do you know how durable they are to different environments?
Do the pistons have a "dust collar" like the Brembo's do?
We have alot of road salt from the winters and dust on our roads here. Together with a wet and cold climate.
I think that these Ceika BBK will be my solution to the brake upgrade.
Quick question; If your calipers are "Small 8pot"... They look pretty big. How does the "Big" version look like then?
Is it possible to get them without the Ceika logo also?
Oszy is offline
#11 Old 09-23-2014
Quoted: 271 Post(s)
Be careful what type of calipers you use in Northern Europe.
As you point out, salt is the issue. The sets such as PB, K, Wilwood, Ceika etc are made from anodised aluminium to keep the costs down. trouble is though they are a magnet to salt!
Brembo products are cast in an expensive alloy to withstand all that is thrown at them. I know I will be shot down in flames for supporting them, but stop and ask why MB, when they lower performance engines into their cars, they choose Brembo over the others...
#12 Old 09-24-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
Ceika's calipers are made from 6061-T6 aerospace grade aluminium with
6061-T6 aluminum or stainless steel caliper pistons and also use Anti-corrosion coatings prior to their custom color finishes. 6061 remains resistant to corrosion even when the surface is abraded. 6061 is commonly used in the construction of aircraft as well as yacht construction, including small utility boats. If it can hold up to the salt water in the ocean I would be comfortable having them on your roads.
@Oszy They DO have a dust collar including using high temperature resistant dust seals. I'm not sure about getting them without the logo as it is embossed in the casting. However, you have the choice of having the logo in a contrasting color or not. Of course keeping the logo in the same color as the rest of the caliper will make it less noticeable. I figured what the heck, why not give them credit for their product. You will also be able to select the color of the hat which allows you to do some fairly wild combinations. I don't believe the large 8pots. are an option on our cars but they must be HUGE. But just as impressive as the size of the calipers is the size of the rotors. But you can rest assured, these brakes are very high quality with replacement parts readily available and you can also use many different brands of pads if you want to vary from their own proprietary brand which by the way are very good and produce very little dust. I am extremely happy with the purchase.
Oszy likes this.
Steven
Stinger is offline
The Following User Says Thank You to Stinger For This Useful Post:
#13 Old 09-24-2014
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
6061-T6 is a great product. We and quality coilover manufacturers use the same material for our\thier products. You do not need to worry about corrosion at all.
  • AirMadZ Air Suspension
  • Accuair eLevel Suspension Management
  • 19" OZ Superleggera IIIs
  • Michelin Pilot Super Sport
  • Wheel Setup Front: 225x35x19 - 8,5J - ET30
  • Wheel Setup Rear: 245x30x19 - 9,5J - ET20
  • SLK350 Brake Upgrade
  • Smarttop
OffLineR is offline
The Following User Says Thank You to OffLineR For This Useful Post:
#14 Old 09-24-2014
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you very much for the info and review of the brakes.
Did you go with the aluminium or stainless steel pistons?
Could you please share some more pictures of the brakes on your car so that I can use as a referance point when making an order with them?
Do you have 19" wheels?
And what pads did you choose for your kit?
Oszy is offline
#15 Old 09-24-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
I'm not sure but I think I remember reading they were the Stainless Steel Pistons. I will have to gather up my receipts to verify.
Sure, as soon as I can get a chance.
I have 18" wheels.
And what pads did you choose for your kit?[/QUOTE]
They have three varieties, Street, Sport and Race. I went with the Street pad for ease of cleaning and longevity.
I would advise sending an email to Ceika, you will be answered by Cedric who is the owner/founder of the company. He will work with you on your custom project and help you every step of the way.
Steven
Stinger is offline
#16 Old 09-28-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
@Oszy Per your request, here are a couple more pics. I took today of the Ceika BBK's.
Fronts:
Rears:
OffLineR likes this.
Steven
Stinger is offline
#17 Old 09-29-2014
Fanatical Owner
Oszy's Avatar
Quoted: 15 Post(s)
Thank you very much for the pictures.
Which calipers do you have on the rears?
Looks like your kit fills out the 18" wheels nicely.
I'm mostly looking for something that will fill out a 19".
Mod list:
Front: 235/35 R19
Rear: 255/30 R19
- Upgraded stereo
Mosconi 6to8 DSP
- H&R Coilovers
- Sprintbooster
Oszy is offline
#18 Old 09-29-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
I went with Front Small 8 pot 356x32mm and Rear Small 6 pot 356x28mm combo. Send them an email and they will fix you up. They have large 8 pot as well with rotors that go up to 405x36mm but they will recommend the proper size for your 19" wheels.
Steven
Stinger is offline
New Disc Brakes, for my Brake Upgrade ! vinnypt Performance MODS for the R171 44 09-22-2014 03:50 AM
brake upgrade ... peZonator Performance MODS for the R171 12 07-06-2014 02:41 PM
Brake Upgrade for 200K MrKompressor Performance MODS for the R171 17 11-27-2011 04:30 PM
SLK55 Brake Upgrade Help ckovach AMGs 7 06-16-2009 01:53 AM
