New lights - Mercedes Benz SLK Forum
 4Likes
#1 Old 07-12-2014
wineprovider's Avatar
Vehicle: 2007 SLK 200 AUTO
New lights
I`m a great beleiver in DRL`s and have found these.
I wonder as they are not standard if the DRL fitting will be a problem. I haven`t looked yet but I presume that the fitting will not be the same.
Has anybody fitted something like them and is there any major difficulties.
Regards to all,
Martyn
wineprovider is offline
#2 Old 07-12-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
Those are the Spyder/Sonar lights:
https://www.slkworld.com/general-modi...eadlights.html
Lots of people on this forum have them. They are a drop-in replacement of the stock lights. Come in chrome, chrome/smoked and black/smoked versions. Your picture shows the chrome.
You have to make sure you get the right version. If your car has the Bi-Xenon headlight option, you should get the HID version (ballasts and headlight washer hardware must be transplanted over from your OEM lights after you take them out and before you put the new lights in). If your car does not have the Bi-Xenon option, get the Non-HID version, even if you plan to add a HID kit: the HID version of the Spyder lights expects precisely the Mercedes OEM equipment, so for an aftermarket HID kit, you need to get the Non-HID Spyders, and bolt on the ballast to some other part of the car.
Woolly likes this.
Durkatlon is offline
#3 Old 07-12-2014
Thanks for your reply and help.
How can I find out what version of lights the 2007 SLK200 r171 that I want to convert.
In addition......I`m concerned how the DRLs work if they are plugged into the parking light connector?
Thanks again & kind regards,
Martyn
#4 Old 07-12-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
You can post your VIN here to get a datacard which will show whether you have the BiX option or not.
The DRLs are indeed hooked up to the parking light. You can turn the master light switch to Auto to get DRLs and automatic headlights (based on ambient conditions), or to Parking (one click to the right of Auto) to get just the DRLs.
#5 Old 07-12-2014
Vin
Here is the VIN.....WDB1714422F163975....
You have been very kind and responsive Durkatlon and must take this opportunity to thank you again.
Kind regards,
Martyn
#6 Old 07-12-2014
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Stand by for your datacard
Woolly is offline
#7 Old 07-12-2014
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Here you are :-
Woolly is offline
#8 Old 07-12-2014
Thanks Woolley..............Can you help me to see what spec the lights are please?
I`ve looked but can`t see any reference.
Thanks again and kind regards,
Martyn
#9 Old 07-12-2014
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
As on your datacard, you do not have any additional headlamp codes, your car will be fitted with standard halogen bulbs and reflectors by default.
Woolly is offline
#10 Old 07-12-2014
Vehicle: 2007 SLK55 AMG R171
Buy the Spyders! They are fantastic, and OEM-quality in every way. I just had mine installed recently. The DRL's are bright and will increase your safety on the road.
Good luck!
Boris_Balkan is offline
The Following User Says Thank You to Boris_Balkan For This Useful Post:
#11 Old 07-13-2014
Connection
It has been suggested that the new lights be connected to the perking light plug connector.
My son has been helping me work things out and we have come to the conclusion that when the ignition is turned on there is no power to the parking light.
Is the suggestion meant to say "sidelight"?
Regards to all,
Martyn
#12 Old 07-13-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
If the headlight switch is in *any* position other than OFF, there is power to the DRLs on these things.
#13 Old 07-13-2014
In reply
I may not have explained myself clearly.
When the ignition is on the parking light does not operate (on my car) regardless if it`s set to left or right,so, if I connect the new lights to this (parking light) connector/plug they will not operate.
If there is an easier way of explain it I can`t think of one.
Thanks for the help.
Kind regards
This is my switch
#14 Old 07-13-2014
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If you are meaning that the lights do not come on when you turn the switch to the "11 O Clock" position, you have to use that position in conjunction with the indicator switch lever.
Turn the switch to that position, press the indicator switch lever down, and the LH "side position markers" (front & rear tail lights ) will illuminate, press the indicator lever up and the right hand side position markers will illuminate.
Woolly is offline
#15 Old 07-13-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
Here we go, hope this makes it clear:
bumpa2 likes this.
#16 Old 07-13-2014
I rest
I`m gonna sleep on this as I`m following the forums help and my sons and I have now become completely confused.
I will say this once more and reply to any further help tomorrow.
The forum says.....with the supplied socket on the new lights I will plug the DRL fitting to the existing parking light socket. Then the DRL`s will come on when the switch is in any of the positions above.
Thanks to all.
Regards,
Martyn
#17 Old 07-13-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
I have had these lights on my car for 2 years, and I did the install myself. I don't know how I can make it any clearer than the picture.
There is only one way to hook up the lights to the car. There are 4 connections between the OEM headlight housing and the car. There are the same 4 connections between the Spyder headlight housing and the car.
If you make these 4 connections, the lights will behave in the way I indicated in my marked up version of your picture.
#18 Old 07-13-2014
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
Remember, side markers are a 'merricun thing .... we don't have them in the UK...
I'd hook the DRL's up to either their own switched supply, or the side lights .... (option 1 preffered )
Sean
Seanhump is offline
#19 Old 07-13-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
Sean
True, but the sidemarkers have nothing to do with how these are hooked up. They reuse all the existing connection to the headlight housing, which is separate from the leads going to the sidemarkers.
Hooking them up to their own power supply is certainly possible, but would require modification to the wiring harness that the lights come with. It is simply not necessary to do this. They work fine out of the box.
AZ SLK likes this.
#20 Old 07-13-2014
Seanhump's Avatar
Quoted: 423 Post(s)
See what you mean ..
Liking the look of the black/smoked set ...
Sean
Seanhump is offline
SPYDER Headlights Durkatlon General Modifications R171 374 08-27-2018 08:33 PM
how to get fog lights on without main lights... wedge357 SLK R171 General Discussion 23 11-23-2016 04:08 PM
How to have the main lights + the LED lights on at the same time? addictive SLK R172 General Discussion 7 08-09-2012 05:29 AM
lights stay on, key remote not working, code on radio jvbutter SLK R171 General Discussion 0 01-15-2011 11:24 PM
Finally installed Projector Lights. SLKman SLK R170 General Discussion 6 05-18-2009 01:42 PM
