Lowering my SLK, a tricky question - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Gork
  • 1 Post By nadnerb
  • 1 Post By Boris_Balkan
  • 1 Post By vinnypt
  • 1 Post By OffLineR
#1 Old 06-24-2014
Gork's Avatar
Vehicle: SLK 200 Kompressor ´05
Other Toys: Sold the kart, now it´s ****
Quoted: 27 Post(s)
Hi all mods,
I have a tricky situation. I would like to lower my SLK (´05 200 Kompressor),
But due to the spacers front, I have only a margin of max 20mm. H&R and Eibach lowers the car 25-30mm, and that is too much. My front tires will then hit the fender.
Rear, it is no problem with lowering 25-30mm.
So, anyone know of lowering kits, that only lowers 20mm?
Should I go for a mixed set, using the 350 lowering springs front? I guess that they are stiffer, so they will not lower as much with the small engine, but then, they might be too stiff to drive with.
Does the SLK have a Spring seat on the front suspension, like on the rear, so it could be possible to lower it 25mm on the spring, and then raise it 5mm using the rubber seat?
vinnypt likes this.
Mods done:
SLK350 Brakes.
18x8" CMS 5-spoke rims.
10mm spacers.
John's 3rd brakelight
Curro101 metal plate
UltraRacing Tower Strut Bar
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#2 Old 06-24-2014
DAS/STAR Registered Owner
Vehicle: 2012 White SLK250
Quoted: 30 Post(s)
My opinion for what it is worth is that a poorly lowered car is PITA. I can not stand a car with a modified suspension.
Either don't do it, or really research all the options, and drive a car lowered in the same manner.
Good Luck
jerryt is offline
#3 Old 06-24-2014
Gork's Avatar
Quoted: 27 Post(s)
I also don't like cars that have been lowered to an extreme, with the tyres dissapearing behind the fenders.
But if you look at this picture, specially the rear tyre looks almost idiotic small in the wheelhouse. So minimising the gap a bit would not hurt.
Mods done:
SLK350 Brakes.
10mm spacers.
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#4 Old 06-24-2014
MarkR171's Avatar
Vehicle: '07 SLK55 030
Quoted: 12 Post(s)
Find out which spring pads your car has from the factory. IIRC, there are 4 different spring pads you can use to add/remove some ride height. Do a search for spring pad part numbers on this forum. They're around somewhere.
Sold: '07 SLK280 | 18" TSW Bremmas | Toyo T1-R 225F/245R | SmartTop V.3 | Green Filters
Sold: '07 SLK55 AMG | 030 Package | Custom X-Pipe | Secondary Cat Delete | SmartTop V3.33 | Mod R170 Antenna | BC Racing Coilovers | Racingbrake Two-Piece Rotors | Enkei Pf-01, Michelin Super Sport 245F/275R
Current: '15 Alfa Romeo 4C | Black on Red | Track Package
MarkR171 is offline
#5 Old 06-24-2014
Quoted: 30 Post(s)
That does not look correct. Are the tires in the rear smaller then factory, or has the rear suspension been modified?
jerryt is offline
#6 Old 06-24-2014
Hyy
Vehicle: SLK 200K 2005
This is mine lowered on Eibach springs, prehaps the amount of height you seek.
Hyy is offline
#7 Old 06-25-2014
Gork's Avatar
Quoted: 27 Post(s)
The rear tires are as defined in the manual. 245/35-R18
The suspension should be stock. I have not checked the pads. Maybe I can lower it just a bit in the rear, by changing them, but that will not be enough.
@Hvy, Yes, your look is what I'm after. The problem is the front, since I have 10mm spacers on. Otherwise, the spokes on the wheel interfere with the brake caliper. But that also mean that the tire is flux with the fender, which means that when the suspension is working hard, the tire will hit the edge of the fender, instead of be on the inside of it.
The ideal would be to lower it 15mm in the front, and 25mm in the rear.
I could clear the fender by adding camber kit on the front, but then I'll get tire wear instead.
Mods done:
SLK350 Brakes.
10mm spacers.
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#8 Old 06-25-2014
Vehicle: 2013 SL63
Other Toys: Audi SQ5 (with all the toys), Kalkhoff Pro-Connect 'leccy bike
Chats: 2
Quoted: 61 Post(s)
Could you get the front wheel arches "rolled" by a bodyshop to give a little more clearance?
I'm not sure exactly how its done but I know its a popular modification to avoid bigger tyres rubbing.
Russ
russj is offline
#9 Old 06-25-2014
Gork's Avatar
Quoted: 27 Post(s)
Russ
Might be a possibility. I´ll have to check out if there are any bodyshops that could do that modification.
Mods done:
SLK350 Brakes.
10mm spacers.
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#10 Old 08-15-2014
vinnypt's Avatar
Vehicle: 2006 Mercedes SLK 200 Kompressor
Other Toys: Audi A6 V6 2.5L 203 BHp
Quoted: 46 Post(s)
Send a message via Skype™ to vinnypt
I think Mercedes don't have that rubber seats, but . . .
You can make them in Fiber, on a Machine Shop with whatever height you want.
My Audi A6 came with 4 of those when I bought it.
Of course I took them off right away.
vinnypt is offline
#11 Old 08-15-2014
nadnerb's Avatar
Vehicle: SLK 200 172 2013 Black
Quoted: 65 Post(s)
Have a read of the thread below, its my car in the pictures. The front did not lower very much but it is noticeable at the back. You will also need aftermarket camber rods for the back.You then have to get wheel alignment done. I will probably remove my springs and rods and put it back to stock in the next couple of weeks in anticipation of a car change. I was going to put them up for sale here but you can have first refusal if you are interested. I actually prefer the car lowered.
I think H&R are the only springs rated for the 200.
There is also a thread titled Camber which may help
https://www.slkworld.com/general-modi...t-springs.html
vinnypt likes this.
nadnerb is offline
#12 Old 08-15-2014
Vehicle: 2007 SLK55 AMG R171
Roll your front fenders. Easy fix. When I had my shocks and camber kit installed, I had the shop get out the fender roller and make room for the possibility of lowering later-on... Which I am now going to do.
Other solution? New wheels that fit properly without spacers.
Dickinson1994 likes this.
Boris_Balkan is offline
#13 Old 08-15-2014
vinnypt's Avatar
Quoted: 46 Post(s)
That's exactly the same problem that I have.
I would like to lower the Front 1/2" more.
I Have Eibach Pro-Kit and they are rated for the SLK(R171) 200K
Ref. E10-25-013-01-22
vinnypt is offline
#14 Old 12-04-2014
vinnypt's Avatar
Quoted: 46 Post(s)
I have made a little Adjustment on the Rear Suspension.
Replaced the OEM 9 mm Rubbers for the 13 mm Rubbers
Before:
After:
OffLineR likes this.
vinnypt is offline
#15 Old 12-05-2014
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
Looking nice.
Why you gave up on 9mm ones?
  • AirMadZ Air Suspension
  • Accuair eLevel Suspension Management
  • 19" OZ Superleggera IIIs
  • Michelin Pilot Super Sport
  • Wheel Setup Front: 225x35x19 - 8,5J - ET30
  • Wheel Setup Rear: 245x30x19 - 9,5J - ET20
  • SLK350 Brake Upgrade
  • Smarttop
OffLineR is offline
#16 Old 12-05-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Originally Posted by OffLineR View Post
Looking nice.
Thanks,
Because with the Eibach Springs the car was more lowered on the Rear that was on the Front.
With this 13 mm Rubbers it's more linear in my opinion.
vinnypt is offline
#17 Old 12-05-2014
OffLineR's Avatar
Quoted: 62 Post(s)
I agree with you. Now it looks even.
I have replaced rear shocks with shorter ones for improving handling as well.
Rears were stretching more than I like, now it handles awesome
vinnypt likes this.
  • Smarttop
OffLineR is offline
09 slk 300 front side marker and parking bulb question zymotix3 SLK R171 General Discussion 3 03-18-2015 03:25 PM
SLK 55 AMG question airali2001 AMGs 9 01-10-2013 07:42 AM
Lowering a 2005 SLK 200K JazzanovaSLK SLK R171 General Discussion 10 01-05-2013 10:25 PM
Lowering question Oszy Performance MODS for the R171 4 10-31-2012 02:50 PM
SLK 320 subwoofer question ||SLK320|| SLK R170 General Discussion 10 06-16-2008 07:50 PM
