Here it is ! - Mercedes Benz SLK Forum
 20Likes
#1 Old 06-18-2014
vinnypt's Avatar
Vehicle: 2006 Mercedes SLK 200 Kompressor
Other Toys: Audi A6 V6 2.5L 203 BHp
Quoted: 46 Post(s)
Send a message via Skype™ to vinnypt
Here it is !
Here it is ! Just landed . . .
vinnypt is offline
The Following User Says Thank You to vinnypt For This Useful Post:
#2 Old 06-18-2014
vinnypt's Avatar
Quoted: 46 Post(s)
I Hope I can do the JOB !
vinnypt is offline
#3 Old 06-24-2014
Delucas's Avatar
Quoted: 1129 Post(s)
Think it needs a pulley extracter to remove ?
And i take it its held on by a allen key / bolt ??
Ive not looked at mine .
Looks pretty straight forward job to do .
Keep us updated and do you feel the difference in power ??
Oh what was the cost ?
Delucas is online now
#4 Old 06-25-2014
Vehicle: R171 '07 SLK 200K
Other Toys: 1969 MGB GT (modded), 1966 Land Rover Series IIA
Quoted: 12 Post(s)
Is it installed?! Please keep us posted on this!!
Dickinson1994 is offline
#5 Old 06-25-2014
vinnypt's Avatar
Quoted: 46 Post(s)
So . . .
. . . Time to uninstall, and clean all the intake system :
And Here it is . . .
vinnypt is offline
#6 Old 06-25-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Here is the "Job" . . .
Uninstalling of the Puley:
New Puley Already mounted:
Cleaned injectors . . .
Mounting Process !
Dickinson1994 likes this.
vinnypt is offline
#7 Old 06-25-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Yes, I have removed it with a pulley extracter.
Mine don't have any bolt !!!
The most difficult part of the JOB is to install the new pulley !!!
I have a new ENGINE !!!
The compressor is making 0,9 Bar peak, and the engine response is awsome.
vinnypt is offline
#8 Old 06-25-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Job Done.
vinnypt is offline
#9 Old 06-30-2014
Gork's Avatar
Vehicle: SLK 200 Kompressor 05
Other Toys: Sold the kart, now its ****
Quoted: 27 Post(s)
Is the pulley just press-fitted? No locking screw?
Then maybe temperature treatment will help.
Aluminium expands much more when heated, than steel does, so putting the pulley in an oven, heated to 120-140 degrees Celsius, should expand it enough for it to slide on the axle.
Just to make sure, you can at the same time treat the axle with coolant spray, or dry ice, shrinking it a bit.
doctorpimp likes this.
Mods done:
SLK350 Brakes.
18x8" CMS 5-spoke rims.
10mm spacers.
John's 3rd brakelight
Curro101 metal plate
UltraRacing Tower Strut Bar
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#10 Old 06-30-2014
Vehicle: slk r171 200k
this pulley should be carbon steel made..it want splip any time soon (if it is aluminium, slipping is just a matter of time...and you dont want that while spinning at 18.500 rpm). Did you also remapped the ecu?
GOLDFISH is offline
#11 Old 06-30-2014
Gork's Avatar
Quoted: 27 Post(s)
Looked like black anodized aluminium on the pic. Even a steel pulley could be heat treated on.
Mods done:
SLK350 Brakes.
10mm spacers.
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#12 Old 06-30-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Yes, mine it's just press-fitted. No locking screw.
I have tried that.
I heated the pulley with a torch, but it only helps on the first centimeters.
The rest of the way, I could not get it to go without screwing a nut !
vinnypt is offline
#13 Old 06-30-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Of course the pulley is Carbon Steel made .....
I don't remapped the ECU ! YET !!
aykayross likes this.
vinnypt is offline
#14 Old 07-01-2014
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
Well done, good job.
I really wonder the results.
Keep us posted.
  • AirMadZ Air Suspension
  • Accuair eLevel Suspension Management
  • 19" OZ Superleggera IIIs
  • Michelin Pilot Super Sport
  • Wheel Setup Front: 225x35x19 - 8,5J - ET30
  • Wheel Setup Rear: 245x30x19 - 9,5J - ET20
  • SLK350 Brake Upgrade
  • Smarttop
OffLineR is offline
#15 Old 07-01-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Keep us posted.
vinnypt is offline
#16 Old 07-11-2014
Vehicle: R171 200 Kompressor - 2005 model
Other Toys: Jeep Wrangler Sport 2.8CRD 200HP
That looks fantstic.
Wherre did you get your pulley from?
aykayross is offline
#17 Old 07-11-2014
how did you clean your injectors?
vinnypt likes this.
#18 Old 07-11-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Hi aykayross,
I got my Pulley from "IBF", a Polish manufacteur.
You can buy it from Ebay.
vinnypt is offline
#19 Old 07-11-2014
vinnypt's Avatar
Quoted: 46 Post(s)
I remove the complete injector ramp.
I fill it up with gasoline and put some pressure on it with a syringe.
Then I apply 1,5V with a "AA" battery and 2 wires, at the 4 injector one by one.
IMPORTANT: apply this 1,5V to the injectors with short blasts.
And there you go.
If you search on Youtube I am sure you'll find some videos with the process.
vinnypt is offline
#20 Old 07-16-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
With a lot of help and advice from vinnypt , I bit the bullet and bought and installed the smaller pulley ( 70 inc postage direct from the seller ) . With the extractors I had , I found it impossible to remove the original pulley , but luckily I know some guys that do reprogramming etc and they changed them over for me ! There are a couple of hard to get to bolts and screws and some of the Mercedes jubilee clips are a pain , but worth it in the end .
I must say I had my doubts , as you never really gain what the sellers claim etc , it's still early days , but I have to say the car seems to really notice the difference !
As the revolutions of the Kompressor are up , the characteristic " supercharger Whistle " is slightly stronger when you put your foot down , which I personally like , very MadMax , jeje .
Delucas, vinnypt and Dickinson1994 like this.
curro101 is offline
