power chip slk 200 K - Mercedes Benz SLK Forum
 19Likes
  • 1 Post By jbanks15
  • 2 Post By Gork
  • 2 Post By curro101
  • 2 Post By Hyy
  • 4 Post By Gork
  • 2 Post By PaPaGriM
  • 3 Post By Hal Adams
  • 1 Post By fredyslk
#1 Old 06-08-2014
fredyslk's Avatar
Vehicle: slk r 171 200 k
hello friends .I was interested in purchasing a power chip for slk 200 k 171.
I would like to know your opinions.
The chip name is : "speed box benzpower" and is online shopping.
In the installation instructions they say that it has to be connected to the intake air temperature sensor. The chip comes with two connectors that are inserted into two other female MAF. I have heard there are IAT that come with five cables.
Anyone know where is the AIT in the slk 200K? How to istal chip power in slk 200? Do you have experience with chip power in slk 200K?
here you have the link
http://www.chipdepotencia.info/?zeni...q3&language=en
fredyslk is offline
#2 Old 06-08-2014
Delucas's Avatar
Quoted: 1133 Post(s)
Cant say much about it but its cheap !!
Trouble is there so many ecu remaps etc about its finding a good one .
But its a bit cheap for my liking .!!??
Delucas is online now
#3 Old 06-08-2014
fredyslk's Avatar
yes Delucas. It just cost only 100 euros. It has a 50% discount.
fredyslk is offline
#4 Old 06-08-2014
Quoted: 6443 Post(s)
The majority of these power chips promising great increase in horsepower are just scams or known as snake oil. A couple members have had stated success. do a 'search' top right for 'power chip' and see if you can find the threads/posts where members have had success and where they got their chip from. Good luck
Dickinson1994 likes this.
#5 Old 06-08-2014
Gork's Avatar
Vehicle: SLK 200 Kompressor ´05
Other Toys: Sold the kart, now it´s ****
Quoted: 27 Post(s)
Totally bogus. You can't fool the system without getting into other problems. I worked with Engine Sw. development for nine years, so I know what I'm talking about.
The only way to increase power, is total remapping of the software in the ECU itself.
OffLineR and vinnypt like this.
Gork is offline
#6 Old 06-08-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I'm with Gork on this one !
vinnypt and Gork like this.
curro101 is offline
#7 Old 06-08-2014
Not me? wahhhhh!
#8 Old 06-08-2014
curro101's Avatar
Quoted: 528 Post(s)
Sorry , and especially with El señor Banks !!!
jbanks15 and vinnypt like this.
curro101 is offline
#9 Old 06-08-2014
Delucas's Avatar
Save your money and go for ...........
Kleemann manifold
K & N air filter
And a supercharger kit
Then a remap !
#10 Old 06-08-2014
Hyy
Vehicle: SLK 200K 2005
Please do not put that crap on your car. Please do not be cheap when it's about your ECU as well.
For power increase I would recommend a custom remap (not copy paste ECU files). Either change to a smaller pulley + remap, or just a remap, but please stay away from those junk. "Cheap" isn't a good reason.
Woolly and OffLineR like this.
Hyy is offline
#11 Old 06-09-2014
Gork's Avatar
Quoted: 27 Post(s)
Engine Control Systems 101
Here comes a short explanation why "Inline Sensor tricking systems" don't work.
Todays diagnostic systems are built in a robust way, so you can in most of the cases continue to drive, even if a sensor or component fails.
Basically, you have following "Input sensors"
MAF, Mas Air Flow
MAP, Manifold Air Pressure
AT, Ambient Temperature
AP, Ambient Pressure
Then you have lot of system sensors, like Crank Position, CAM positions, Fuel pressure, Oil pressure, Oil temp, Lambda value etc.
Using values from those sensors, together with internal parameters like engine displacement, rpm, manifold displacement, crankshaft position etc.
You can determine the airflow trough the engine, and together with the Lambda sensor, adjust the fuel injection.
None of the components above are exact, so the ECU allows for an adaption of the value from the sensor.
In other words, a sensor that should have a nominal value=1.0 can actually have any value between 0.8 and 1.2
The ECU starts with value 1 as a reference, and then measures the outcome.
If it is not according to the expected outcome, it adjusts/adapts the sensor value by adding or subtracting 0.01 from the measured sensor value.
It will continue so, until the outcome is as expected. This takes several driving cycles, but normally you are within the correct range after 5-10 cycles.
(You can test this by lifting the battery for 10 minutes. You will probably get the feeling that the engine is more harsh, during the first one or two drive cycles)
This also allows for the sensors to drift during their lifespan. The ECU simply compensates for the drift.
Even if a component fails, it's value can be calculated by using the data from the remaining sensors, to create a backup value and allow you drive the car, often with reduced power and rpm, so you can take the car to the workshop.
So if anyone tries to fool the system, by connecting some other electronics to the MAF, MAP or AT, the engine will smell the rat, for instance by checking the Lambda value, and just compensate.
If you go outside the area of compensation, (0.79 or 1.21 in the example above), you will get a component failure lamp, and in worst case, end up in "Limp Home"
Woolly, jbanks15, fredyslk and 1 others like this.
Gork is offline
The Following User Says Thank You to Gork For This Useful Post:
#12 Old 06-09-2014
Yeah! What Gork said!
#13 Old 06-09-2014
One Man, One Engine
PaPaGriM's Avatar
Vehicle: 2012 SLK55
Other Toys: 2012 Lexus RX350, 2004 BMW 325i
Quoted: 12 Post(s)
Originally Posted by Deafy View Post
And I'd recommend an SLK55.
I had the same dilemma until I settled for the advice given above.
jbanks15 and Deafy like this.
2012 SLK55 AMG
PaPaGriM is offline
#14 Old 06-09-2014
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
It has all been said above. I echo them and implore you not to do it.
Do not try to uprate the power of a 200, other than a smaller s/c wheel, you will not achieve anything at all - other than heartache. Even then, with a Kleeman kit at 1000€, it is only another 30hp max.
The 200 is what it is and does the job very well. I am afraid you purchased the wrong car if you want quicker. You and I do not have to drive quickly down here! Why not just relax and enjoy what we have and others do not..!
Woolly, jbanks15 and Gork like this.
Hal Adams is offline
#15 Old 06-10-2014
fredyslk's Avatar
Dear Friends: I knew that in slk world I will find the answer to my queestion.
I am impressed of the level of your comentaries.
All the questions are resolved when anyone has a question.
Gork congratulatios. Your answer is like of an aerospace Engineer coment.
Friens it was just curiosity, and I wanted to know your opinios.....
fredyslk is offline
#16 Old 06-10-2014
fredyslk's Avatar
anyway , could you tell me where is the intake air sensor? or if it is integrated on the MAP?
fredyslk is offline
#17 Old 06-10-2014
Gork's Avatar
Quoted: 27 Post(s)
The MAF usually also measures the intake air temperature, since that value is used to calculate the mass flow. The MAP, or the Manifold Air Pressure, is located on the intake manifold itself (somewhere)
Mods done:
SLK350 Brakes.
18x8" CMS 5-spoke rims.
10mm spacers.
John's 3rd brakelight
Curro101 metal plate
UltraRacing Tower Strut Bar
Short Antenna
S160 Head Unit
SmartTop
Mods to come:
LED Lights
WindRestrictor
Rain Sensor
Gork is offline
#18 Old 06-10-2014
Quoted: 271 Post(s)
I think you mean, for the intake air sensor, the mass flow air sensor. This is the first sensor on the intake, with the manifold air pressure (sometimes called manifold absolute pressure) being the next.
Do be careful with these as the ECU is constantly monitoring the ratio between these two. If it suspects anything - especially with the manifold pressure, it will slap you into limp-home mode.
It is difficult to describe, and I really do not want to pull my intake system apart to photograph things! Luckily, there is a post in the archive that will help you:
https://www.slkworld.com/slk-r171-gen...af-sensor.html
Pull the airbox cover off and underneath, you will see the MAF - further back on the manifold is the MAP, it is partially hidden, but you are looking for a component that looks like this:
http://www.ebay.ca/itm/Mercedes-r171...-/151301866824
The Following User Says Thank You to Hal Adams For This Useful Post:
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 3 4 Days Ago 12:50 PM
