Anyone Ever Retrofitted Early R170 with Rear Sway Bar? - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By MBDiagMan
  • 1 Post By Nicholas Christopher
  • 1 Post By LeonardoDaBenz
#1 Old 06-13-2013
MBDiagMan's Avatar
Vehicle: '01 SLK320 6 speed manual
Other Toys: Modified Cessna 140, 300E 5 speed manual
I have not yet picked up my '99 so I cannot verify that it has no rear sway bar. From what I've read, the rear sway bar didn't come along until the 2000 model year.
Has anyone ever retrofitted a rear sway bar? If so, what did it involve in the way of brackets and fittings?
Thanks for your help.
Doc
MBDiagMan is offline
#2 Old 06-15-2013
Vehicle: 1999 SLK 230
Would it be easier to swap a 2000 and up rear sway bar? I have a 99 and am climbing under it tonight to see about the sway bar issue. A rear sway is a huge improvement if there is none. Theres also aftermarket options for the 00-03 rear and front. I plan to Auto-x so this would be a great improvement.
jonbonesjones is offline
#3 Old 06-17-2013
MBDiagMan's Avatar
Yes, I have learned over the years, that on almost ALL production cars, if you are going to make only ONE handling modification, adding or stiffening the rear sway bar is the one to make. It takes out some of the ever present understeer.
I still haven't taken delivery of my car, but from what I've read, I fully expect that it will have no rear sway bar. I will get one in one way or the other. From what I've been able to determine there are studs for the upper bar mounts. Hopefully a bolt can be inserted from the top and tacked in place. Failing that I will remove the rear suspension as attached to the subframe and weld or other wise fix up the upper mount.
All the pictures I can receive underneath an R170 with a rear sway bar mounted, will be helpful.
I'll know more once I got my new baby home and on the lift.
BTW, I fully expect the 00-03 rear bar to be the correct shape and configuration for the earlier R170 cars.
gringott likes this.
#4 Old 10-21-2013
gringott's Avatar
Vehicle: 1998 SLK230 R170 Stock
Other Toys: 350Z TT
Any update on this early no rear swaybar issue? I.E., an easy fix?
gringott is offline
#5 Old 10-22-2013
MBDiagMan's Avatar
No, I haven't gotten enough information to feel comfortable dropping the rear suspension to put a bar in place. I'm sure that a 2001 bar would work, but the variable is exactly where to place the body mounts. If I knew exactly where to locate them, I would buy a bar and all the pieces, drop the rear suspension and MIG the body brackets in place.
A non car guy neighbor told me that he found an article on the internet that showed exactly how to do it. I have been unable to find it, and he has not answered my requests to forward a link. He is kind of full of it, so I don't think he really found anything useful. He might have found something that he thought was useful.
Sorry for the lack of information. I sure would like to add a rear bar.
The Following User Says Thank You to MBDiagMan For This Useful Post:
#6 Old 10-22-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
For us Brits, is a sway bar an anti-roll bar? I'm guessing it is from what you've written about removing understeer.
ajberrow is offline
#7 Old 01-16-2014
AlienHack's Avatar
Vehicle: 2000 R170 Slk 200 Mediterranean compressor
So is there a way to install a facelifts sway bar to a prefacelift?
AlienHack is offline
#8 Old 02-12-2014
If anyone has a parts diagram of the facelift vs rear facelift it would help. Im guessing they didnt change the rear subframe design other than just adding a sway bar. Id say there are two options
1 - find wrecked facelift SLK
- pull rear subframe
- rear sway bar
- rear control arms where sway bar connects
- any other misc. parts like links and hardware
2 - weld mounts up for one
This is going to require measurements and great welding skills.
Option 1 shouldnt be that hard if you can get a good donor car or even just a subframe with the mounting provisions. In theory the frame should bolt right up. Facelifts are more cosmetic upgrades than huge chassis modifications.
#9 Old 11-20-2018
Vehicle: 99 Slk230 Blk/Blk 5Spd, 99 Slk 230 Silver/Blk-Tan Auto, 03 Slk 230 Silver/Blk Auto
Other Toys: 99 318ti S52 Swap, 99 318ti Dinan Tune ,99 C43 AMG, 01 Ml55 AMG, 02 C230k Coupe 6Spd, 99 C230k
- rear sway bar
It requires, the subframe, the control arm and the rear control arm bits. Easiest way is to find a donor or wrecked parts car.
LIL DON SLK likes this.
Nicholas Christopher is offline
#10 Old 11-20-2018
LeonardoDaBenz's Avatar
Quoted: 1015 Post(s)
@Nicholas Christopher thread is 5 years old and OP has not been back for 2 years
Please have a read here about how not to post in old threads
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#11 Old 11-20-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 252 Post(s)
But I love old threads!
The Toy
Idiot101 is offline
#12 Old 11-20-2018
Old thread, but still a relevant question that was not answered. Now when someone searches they will know.
r170 rear speakers harv SLK R170 General Discussion 14 03-04-2014 09:46 AM
R170 Black rear lights in UK + free black side repeaters SimonLockwood SLK Parts For Sale 1 04-06-2010 04:47 PM
slk r170 heated rear screen problem monkxtreme SLK R170 General Discussion 0 04-24-2008 01:21 PM
Remove rear bumper Zeiser50 SLK R171 General Discussion 1 08-18-2007 12:14 PM
