SLK 32 supercharger info - Mercedes Benz SLK Forum
 6Likes
  • 1 Post By wislk32
  • 1 Post By jbanks15
  • 3 Post By TFP
  • 1 Post By Idiot101
#1 Old 12-14-2018
wislk32's Avatar
Vehicle: 2002 SLK 32 AMG with full SL55 air intake system, EC TCU and ECU tunes, 65mm SC pulley
Quoted: 12 Post(s)
Hi all,
I am looking for some info on the SLK 32 supercharger. First the brand and model of it? (i think the brand is IHI) And the diameter of the crank pulley sheave used for the SC belt ?
I f any one can help that would be amazing
Wislk32
wislk32 is offline
#2 Old 12-14-2018
Quoted: 6460 Post(s)
Until someone responds
Apparently the early 170 superchargers [pre FL 2001] were driven by a magnetic clutch. It engaged the supercharger at around 2700 rpms. Then in 2001, Mercedes phased in a constant driven supercharger with a 'pressure relief valve for excess boost. depending on the throttle position, the relief valve bypassed pressure from the compressor output tubes back into the air cleaner. Not all 2001's have the constant driven charger, . . you need to look at the compressor drive pulley and see if it's direct drive pulley or clutch driven pulley . . . After talking with a dealer mechanic about getting more preformance, I sort of question the pulley modification line of thinking . . the pressure relief valve won't allow too much pressure, so if you drive the charger faster, the increased pressure is bled off and not used for manifold boost . .
Pre facelift is sports a M62, facelift sports a M45. The M62 is larger/moves more air but spins slower and engages at 2700rpm. The M45 moves less air but is always engaged, they are not interchangable. By adding the pulley kit on the facelift years you can gain around 15 - 20 hp. Best to check with asp dot com and get the right numbers on that.
https://www.slkworld.com/slk-r170-ge...rchargers.html
#3 Old 12-14-2018
wislk32's Avatar
Quoted: 12 Post(s)
Thanks for the quick input, but this is for the slk 32. is the blead off still the case for the 32?
wislk32 is offline
#4 Old 12-14-2018
I'm not the expert
let's summon some
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
wislk32 likes this.
#5 Old 12-14-2018
TFP
TFP's Avatar
Vehicle: 02 SLK32 AMG
Quoted: 150 Post(s)
Hi Wislk32
Here's some info from a company on your side of the pond who rebuilds these things .......
SLK-32 Roadster AMG. V6 Supercharger Made for Mercedes-Benz by IHI Corp. Model M271 Eaton P/N 307960. AMG's use Lysholm and not Eaton. 2646 lbs of air per hour, converted over to CFM's its about 560, with the size in pulley difference on a G60 its about 470 cfm's or something like that.
2002-04 Mercedes-Benz AMG S55; SL55;AMG;C32 Supercharger A1120900080
They sound like the people who could help you out if your s/c is playing up
jbanks15, Idiot101 and wislk32 like this.
TFP is offline
#6 Old 12-14-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 252 Post(s)
Not a techie, but Jon Bond Performance Supercharger is another professional source. They do complete rebuild on YOUR SLK32 supercharger for about $900 last time I looked. They can probably provide pricing and expertise if you are wanting to put a smaller pulley on it to increase horsepower. 😈😈😈. 😈😈
wislk32 likes this.
The Toy
Idiot101 is offline
From mild to wild. My SLK 55 AMG transformation and swapped motor story. C63edition507 Performance MODS for the R171 53 12-19-2018 01:22 PM
Supercharger / Turbos for an SLK-350 linuxpro SLK R171 General Discussion 12 09-08-2017 05:20 PM
Great Article from Auto Bild Klassik (Classic). Desert_SLK SLK R170 General Discussion 3 06-26-2014 11:02 AM
