Coil Springs and Fuel Pumps - Mercedes Benz SLK Forum
  • 1 Post By mchild
#1 Old 07-11-2017
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
I have 2 questions that hopefully somebody can answer. We'll start with the easy first:
1. What lb coil springs are on the front of an SLK230?
2. It appears the 230's have a return fuel line (say vs. an E320). is this a true statement? Does anyone know where the return line 'returns'? (tank or back into fuel pump)?
The reason I ask is because after doing my V8 conversion and blocking off the return line, I hear some gurgling in the tank when I turn the engine off, which to me sounds like pressure bleeding back through the pump?? in other words: I'm dead-heading the pump. not good. however, after some research, the E430 and E320 etc have the same fuel pump and filter, yet they dead-head them.
Thanks.
Turdo2 is offline
#2 Old 07-11-2017
Star/DAS Registered Owner
Quoted: 499 Post(s)
Thanks.
Assuming you have a R170.447 I have linked the parts list and picture of the fuel lines. Yes, there is a return line.
https://drive.google.com/file/d/0B1W...ew?usp=sharing
Idiot101 likes this.
mchild is offline
#3 Old 07-11-2017
Quoted: 499 Post(s)
I have made some assumptions as to the models of the E320 and E430. If I assumed correctly, then this link will show the fuel lines for those two cars - which and the same between them but different then the R170. I hope this is helpful.
mchild is offline
#4 Old 07-11-2017
Turdo2's Avatar
Quoted: 346 Post(s)
Very good information!! Thank you!
Turdo2 is offline
#5 Old 07-12-2017
Vehicle: 1998 Slk 230
Quoted: 7 Post(s)
Not much help from the WIS
"The color marks in the middle of the spring are the manufacturers inspection marks. They are of no significance related to the spring length.
The various spring lengths and the various axle loads, resulting from the individual vehicle models. are compensated for by the installation of spring rubber mounts of different height.
The part number and Daimler trademark are stamped on the last lower coil of each spring.
Assignment of the spring rubber mount to the vehicle model can be determined with the aid of the EPC."
Hand off to someone with access to the EPC
Silverster is offline
#6 Old 07-13-2017
Quoted: 499 Post(s)
I have EPC and can look up (will need the VIN) the stock springs and pads but that does not seem to answer the question of how many pounds to move the spring an inch. It may be the only way to know is to have them tested. I am not aware of MB providing this info.
mchild is offline
#7 Old 07-13-2017
Pictor's Avatar
Quoted: 217 Post(s)
Is that where they break?
Is that why they break?
Pictor is offline
#8 Old 07-13-2017
Turdo2's Avatar
Quoted: 346 Post(s)
Very interesting thoughts.
so the spring strength does not change between an SLK230 and SLK320 is what that tells me, they just add a taller pad to compensate for the less ground clearance... sounds very "un german" to me. I should have EPC with my Star system, but that still doesn't get me the pounds/inch.
I recently learned that the R170 SLK is based on the W202 chassis, which also shares very similar suspension design to the W210 (if not the EXACT parts). Therefore I wondered if I installed coils from a E320, then it would be enough to offset the weight of my V8...??
Turdo2 is offline
#9 Old 07-13-2017
Quoted: 499 Post(s)
I understand the spring color markings differently than Silverstar. In the link is the EPC page for springs for the 170.447. There are two springs (one is a 210 chassis spring) with a total of five lower pads. The pads are used to help offset the compression of the spring due to the weight of the options on the car. There are upper pads too with different thicknesses. Let me know if there is anything else that would help you from EPC.
mchild is offline
#10 Old 12-07-2017
Vehicle: 2002 SLK320 in Black
Quoted: 14 Post(s)
I might be wrong but it looks as though the upper pad comes in 5 different thickness's. My car has no lower pad at all and I don't see one
in the parts catalog.
I am in need of a pair of front springs, does anyone have any input on Bilstein springs, Peloquin has a listing for them for a good price.
While on the subject, any advice on a lowered spring set? I really love the ride and handling now but the car would look better a inch lower.
I just don't want a super stiff ride..
STeve
Racerstev is offline
#11 Old 12-07-2017
Other Toys: Ginetta G32
Quoted: 92 Post(s)
I think if you lower it by an inch you may end up riding on the standard shock absorbers bump stops too much. This was how my 32 was when I first bought it. You would have to replace them with Bilstein B4 or similar which have the travel to allow for it.
stu32 is offline
#12 Old 12-08-2017
Quoted: 14 Post(s)
How was it after the shock replacement? I'm leaning towards a stock replacement spring right now.
Steve
#13 Old 12-09-2017
Quoted: 92 Post(s)
Steve
I replaced all 4 corners, springs and shocks. Bilstein shocks and Kilen springs to achieve the desired ride height and comfort. The original springs on mine were cut down so had no choice but can recommend this conversion.
stu32 is offline
UK - Eibach springs + Bilstein B6 dampers (5 months old) ademk SLK Parts For Sale 4 04-21-2013 01:52 AM
