Lowering my R170 - Mercedes Benz SLK Forum
#1 Old 03-07-2013
quikdraw's Avatar
Vehicle: 01 slk 230 amg sport
Lowering my R170
Okay so I wanted to lower my 2001 R170.... ordered k-mac bushings, eibach springs and B6 bilsteins. Dropped in the springs and shocks and was advised against using k-macs they are squeaky, and you can only adjust them for .5 degrees so i ordered MB Arts camber arms. Anyway so far only put in the springs and shocks and to my dismay.....nose up -.- gonna use 4 pads in the rear and 1 in the front and try that out. by the way I found out the front pads go 1-5 5mm-9mm-13mm-17mm-21mm and rear 1-4 5mm-9mm-13mm-17mm. I pray this levels it out because I am embarrassed to drive atm -.-
quikdraw is offline
#2 Old 03-07-2013
quikdraw's Avatar
Btw if it doesn't work can anyone recommend some adjustable shocks?
quikdraw is offline
#3 Old 03-07-2013
You should be OK with #1 pads all the way around. Once the shocks and springs settle down it will look good.
#4 Old 03-07-2013
quikdraw's Avatar
Thx for the reassurance and will do on the pads
quikdraw is offline
#5 Old 03-07-2013
Food for thought, if your not running the OEM 16 wheels #1 pads will get you tire rub.
#6 Old 03-07-2013
quikdraw's Avatar
Just thought I'd mention about a 1 inch difference in gap on front from back
quikdraw is offline
#7 Old 03-07-2013
Thats about right, less gap in front because of engine weight. You can adjust that with different spring pads.
#8 Old 03-07-2013
quikdraw's Avatar
hmm im running 18s and there's like an 1-1.5 inch gap still I cant really imagine the tire rubbing with a 5mm pad
quikdraw is offline
#9 Old 03-07-2013
quikdraw's Avatar
Logic says less gap in front but the gap is in the front not the rear.
quikdraw is offline
#10 Old 03-07-2013
That's correct; the front springs are heavier than the rear's so the gap will be different until they settle.
#11 Old 03-07-2013
quikdraw's Avatar
so you are saying that the gap in the front is natural until it settles? that is a relief
quikdraw is offline
#12 Old 03-07-2013
that's correct, it took some time before mine settled down and looked right.
#13 Old 03-23-2013
quikdraw's Avatar
update: it did not even out so i changed the spring pads 2 in front and 4 in rear, FYI stock pads for my R170 was 5 in front 2 in rear. now it looks clean and very nice. I also put in the MB Arts Rear camber arms. easy to correct to within tolerance but using the 2 pads in the front put it .1 out of tolerance on negative camber. without an adjust ment. tolerance is supposed to be -1.5 in front camber.
quikdraw is offline
#14 Old 06-15-2013
Hi guys, i wonder if its possible to remove permanently pads and not installing any there or it will be dangerous and suspension will not work correctly. Sorry for bad english
castillo20 is offline
#15 Old 06-15-2013
Quoted: 6432 Post(s)
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Post your vin in the Vehicle Datacard Request section to get a datacard (window sticker of options)
#16 Old 06-15-2013
Welcome from New Hampshire, pads are there for a reason. Metal on metal will destroy your shock towers.
Eibach lowering Springs R170 hormoth SLK Parts For Sale 5 02-18-2013 06:44 PM
How to strengthen signal with the R170 Antenna dsb SLK R170 class DIY 5 02-12-2013 05:56 PM
FS: Used R170 Brabus Lowering Springs sightless SLK Parts For Sale 5 11-21-2012 04:37 AM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
