Cold Air Intake - Mercedes Benz SLK Forum
#1 Old 08-18-2012
Vehicle: 2002/3 SLK 230 Black
Cold Air Intake
Is there any reason why the supercharger needs to vent any unwanted boost back in the air intake?
This appears to me to result in hot supercharger air being feed back into the supercharger, only to make it a bit hotter, and then the process just keeps repeating itself. I find this is most noticeable in peak hour traffic, where you are constantly starting and stopping in short bursts. It's also present in other situations as well!
The power loss due to the high air intake temperatures is very noticeable
What happens if we vent the hot supercharger air out the bottom of the car using a separate air filter and seal up the hole in the air intake box? Has anyone tried doing this? Did the air intake temperatures remain low?
Luc
luc256 is offline
#2 Old 11-26-2012
onixxf's Avatar
Vehicle: 2001 SLK 320
Other Toys: 2005 Toyota X-Runner, 99 Pontiac Trans LS1
This is what I've done to my 2000 SLK. I never thought about the hot air making things hotter, i only did it to get the whine from the SC and to try and get cooler air in the intake.
onixxf is offline
The Following User Says Thank You to onixxf For This Useful Post:
#3 Old 11-27-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
What did you do with the s/c actuator flap? Can you upload more pictures?
Bradley61496 is offline
#4 Old 12-06-2012
Barchetta's Avatar
Vehicle: 1999 SLK230
How about eliminating the recirc bypass flap all together and have the supercharger bypass outlet go to a waste gate that opens/dumps when the boost psi exceeds a determined (adjustable) amount. I think the boost is around 6-8 psi with a stock crank pully and around 12-14 psi with an oversized pully. You could also convert from the stock air to air intercooler to an air to water for better cooling of the supercharger air. I haven't researched any of this....just some things I've thought of doing.
Barchetta
Barchetta is offline
#5 Old 02-11-2014
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
anyone have any more details on this thread?
SirClass is offline
#6 Old 05-27-2014
Vehicle: 98 SLK230
A cold air intake, and blocking off the recirculating air system would probably improve performance.
vinhtvu2 is offline
#7 Old 08-31-2014
Vehicle: '02 SLK32 AMG in "naked" MB color that was used for getting a car's weight to be under a HIGH number
Other Toys: bike as in road bike, 13lbs. A beautiful machine!
Quoted: 46 Post(s)
Originally Posted by luc256 View Post
Luc
I believe the bypass valve keeps pressures on both sides of the SC equal and only operates when there is no boostyo, such as in a decelleration. Situation. It eliminates cavitation and you'll have to look up that word in regards to supercharger operation. I am just looking for a SLK but my Mustang Cobra had a bypass valve. I believe if it is disabled hotter air will enter the motor. Just want all to,have happy motors. mark
Sweet04 is offline
#8 Old 11-06-2014
Vehicle: 98 SlK 230
Hey, Ive been interested in putting a CAI on my 98 slk 230, and haven't been seeing any recent posts about it. I had a few questions...1 How did you secure the filters/inlets in place after removing the box? 2 is there a third mini cone filter as i've seen in other pics? (I have no idea what that one is for) And 3 what did you use to attach the filter to the sc?
hogdog is offline
#9 Old 11-06-2014
Quoted: 6432 Post(s)
hogdog, please post an intro
SLK32 AMG Cold Air Intake question Reckless Enjoi SLK R170 General Discussion 0 12-07-2011 08:23 PM
Spring Cleaning: Get your HVAC ready for with 1Z einszett Klima Cleaner DetailersDomain Caring for your SLK 0 04-09-2010 02:25 AM
cold air intake ideas jameslk55 Performance MODS for the R171 52 04-23-2009 11:50 AM
R-170 Cold air intake? hellfire Performance MODS for the R170 0 02-25-2008 12:42 AM
