What spring pads come stock? - Mercedes Benz SLK Forum
  • 1 Post By Jake230
  • 1 Post By Jake230
#1 Old 11-29-2015
Jake230's Avatar
Vehicle: 1998 SLK230 AMG Sport Package
When I bought the car I noticed the previous owner had done some strange things with the suspension.
The rear springs were really short. The front springs looked stock, but there was evidence of rubbing on the tires from previous springs that were far too short. Also, the tires were the wrong size (the rears were 1 inch shorter than the front causing havoc with the Traction Control and Cruise Control.)
Anyway... I've got new tires in the proper sizes and Eibach Pro-kit springs. I just want to make sure I have the right size spring pads. I'm afraid the previous owner might have been mucking about with those as well.
Thanks!
Jake230 is offline
#2 Old 11-29-2015
Quoted: 6435 Post(s)
post your vin
we get you your free datacard and the spring part number which would be oem
then you can proceed from there I would think.
#3 Old 11-29-2015
This is from a 1999
#4 Old 11-29-2015
Jake230's Avatar
Thanks Jeff,
Going by the parts list you posted it appears I have...
9mm on the front (A2103210284)
13mm on the rear (A2103250384)
The problem is, I don't know if those are the stock sizes, or were they supposed to be the same thickness in stock form?
The front seems to sit slightly lower than the rear. I'm o.k. with that if that's the way it's supposed to be.
- Jake
Jake230 is offline
#5 Old 11-29-2015
Hi Jake, I am not the expert. Do you want your datacard? supply your vin.
then what you see is what came with your car.
edit: i see you got your datacard already
#6 Old 11-29-2015
Jake230's Avatar
Wdbkk47f1wf017690
I got my data card, but I can't decipher from it what spring pads came stock.
Jake230 is offline
#7 Old 11-29-2015
it won't tell u that stuff but i can see if the part numbers you posted are the same
#8 Old 11-29-2015
same numbers i believe
#9 Old 12-02-2015
Years ago when I replaced my springs and pads the OEM pads were #4 .
#10 Old 12-03-2015
Jake230's Avatar
Hmmm, that's interesting.
I wondered if they came from the factory with the same pads front and rear.
I might have to think about changing my front pads up one.
Jake230 is offline
#11 Old 12-04-2015
Both front/rear pads were the same from the factory. I went with #2 pads f/r when I installed the sport springs.
#12 Old 12-07-2015
Jake230's Avatar
Thanks for the information guys!
Think I'm going to swap the front pads out and put in #3 's so I have the same all around. The front seems just a tad low to me now, and that will bring it up 4mm.
By the way, I really like the Eibach springs. If anyone is thinking about doing the swap I highly recommend them. Not too harsh. Just a nice firm ride. And they don't lower the car too much. Even with #2 pad in the front I have not touched down on any speed bumps.
Jake230 is offline
#13 Old 12-07-2015
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
You're not trying hard enough, maybe?
#14 Old 12-08-2015
Jake230's Avatar
Ha. You're probably right.
Jake230 is offline
Jae's SLK32 Build Thread 9021Jae General Modifications R170 80 03-04-2019 05:26 PM
Aftermarket amplifier that fits R170 stock location - and speaker upgrade Mancuso General Modifications R170 28 08-01-2016 04:26 PM
Bilstein B6/ stock spring combo nakulan7 Performance MODS for the R171 8 03-26-2015 04:28 AM
Spring pads help needed Oszy Performance MODS for the R171 1 02-20-2013 03:56 PM
tech specs of stock brake pads Adamantium Performance MODS for the R171 3 07-21-2009 10:32 AM
