Speers oversize pulley - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Paulwirral
  • 1 Post By geordielad
#1 Old 05-25-2015
Vehicle: slc 43 2016
Quoted: 82 Post(s)
I've just fitted it , took about half an hour , rad cowl off and access the tensioner pulley , cleaned off the existing bottom pulley and bolted on the oversize one over the top and installed the new supplied belt .
There's a definite improvement in low down torque and better mid range pull but it does run out of puff towards the red line , more so compared to standard . Hopefully a remap should help this , as should a bigger inter cooler and an extra inlet into the factory air box .
If I've got time I'll also see if I can get larger down pipe and maybe dump the cats and make up a better exhaust system , although I don't want any more noise so this may prove difficult !
clown likes this.
Paulwirral is offline
#2 Old 05-25-2015
Quoted: 82 Post(s)
I've no idea when it comes to computers , posting a message here is the limit of my skills . I live on the Wirral in England and it's a 2002 230 6 speed slk , that's honestly the best I can do , I'm better with spanners than computers , if it's a problem just delete as you see appropriate and cancel the membership , I just thought some members may be interested in the results of what I'm doing .
Cheers Paul
#3 Old 05-25-2015
Vehicle: 1999 Mercedes SLK 230 Kompressor 5sp Manual
Quoted: 50 Post(s)
Hi Paul and welcome to the forum.
I think it's much more useful to be good with a spanner than it is with a computer 😊
Can I ask exactly which bigger inter cooler you would use for this? And any info on the extra inlet? Any part numbers or manufacturers?
We had a Speer pulley put on in March this year, so - nearly 3 months ago - along with an ECU remap. So far, so good. No problems, touch wood, and loving the difference it has made. We live only 2 hours or so away from Speer in Heilbronn and dropped in there one day and had it done. She doesn't "run out of puff" at the top end so maybe the remap makes the difference.
Thinking it won't hurt to upgrade the inter cooler, though not seen nor had any indication that we need to. So far.
Sorry to pick your brains. Would be nice to hear your input.
Thanks,
Jo
clown is offline
#4 Old 05-25-2015
Quoted: 82 Post(s)
Thanks,
Jo
No probs Jo , I've found a couple that should fit without to much modification , tx auto sport and universal inter coolers both make one classed as medium sized , £70 to £105 , looks to be half as big again as standard .
There will be minimal power gains from the inter cooler , it's more of a reliability issue to me .
As for the intake mods I'm 40 mins away from demon tweeks so they have some generic intake trumpets that I should be able to feed into the air box with a short length of heat reflective pipe .
I'll keep a track of part numbers and suppliers and post the details when I've fitted them .
I have a holiday home in the dordogne region of France and I'll be driving up to the nurburgring in July so I can make a short detour on my way to have the re map done . Then it's on to the track and see if the mods work and hold up
If they make a decent difference I'll sort the suspension after , I replaced the discs , fitted red pads and higher temp fluid as a matter of course when I serviced the car , all filters inc fuel , plugs idler pulleys and supercharger oil , I've always found it best to start with a good base .
I'll post my thoughts on the results as and when I carry out the mods if that's ok with the guys that run the site , sorry for my computer ignorance but it's just not that important to me .
Paul
The Following User Says Thank You to Paulwirral For This Useful Post:
#5 Old 05-25-2015
Quoted: 6432 Post(s)
Paul, Our administrator, Livefreeordie updated your profile for you
Vehicle: 2002 slk 230 6 speed
#6 Old 05-26-2015
Quoted: 82 Post(s)
Thumbs up
Thanks for that
#7 Old 05-28-2015
Quoted: 82 Post(s)
Update
I've managed to modify the intake system with a universal duct and a short piece of ducting attached to the existing air box , the part is available from demon tweeks , it's the offset intake duct no. 6 cut at the 76 mm step and trimmed to suit in front of the rad .
I've also fitted a larger inter cooler , medium size from universal inter coolers.co.uk , it's half as big again as standard , welded end tanks and decent quality . It's as near as a replacement fit as possible , fits straight into the existing space once all the factory ducting is removed . If anyone's interested you need the medium size inter cooler , 2 silicone bends and 2 alloy pipe joiners , £135 all in . It's easy mounted by 2 straight bar brackets off the engine under tray bracket and bolted to the cooler , one bent alloy strip bracket under the bonnet catch bracket and bolted to the cooler , it comes with 6 threaded fixing points .
You can even cut the old ducting down and utilise it with the new cooler .
I didn't take pics as I've no idea how to post them , and once it's all fixed in there's nothing to really see .
It's made a small difference driving wise , the car doesn't run out of breath so quickly , re map and exhaust next !
#8 Old 05-28-2015
#9 Old 08-07-2015
Vehicle: 1999 230SLK - Manual
Other Toys: Honda's: 08 CBR1000rr, 05 CBR600rr, 1970 CB350 Boats: Fareast 23R, Laser Truck: 08 Chevy Colorado
Quoted: 19 Post(s)
Just Kidding!
But if you can it would be good for people to estimate whether they could do it themselves...
overdraft is offline
#10 Old 09-30-2015
Vehicle: 02 SLK230
Other Toys: 06 C230
can you show some photos of your upgrade
thanks
Neil619 is offline
#11 Old 09-30-2015
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
i would be highly interested in seeing the intake that you made, im in the process of trying to figure out a better flowing and more heat resistant one myself. as of right now, i just have a giant cone filter in the place of my factory airbox, i like that i can hear the supercharger a lot more, but ive noticed the car now runs a little warmer (visually on the thermostat gauge in dash)
SirClass is offline
#12 Old 10-01-2015
Quoted: 82 Post(s)
I've no idea how to post pics , it was just an offset trumpet intake directly behind the grill connected to a larger diameter hose the I butchered onto the original air box . I'm not sure it made any difference .
I've since been looking into making an air box like you say . I'm thinking an alloy heat shield above the blower then a cone filter in an open air box behind the head light .
I'll probably end up cutting out the slam panel support to enlarge the intake mouth as much as possible .
I found an old redline magazine article on a 230 c class they modified with stuff they had lying around , I've yet to find out what they did exactly what they did as it was the last article on that car but it made 238 bhp on the rollers .
SirClass likes this.
#13 Old 10-01-2015
Quoted: 34 Post(s)
that's exactly what i've done so far, minus the heat shield, im working on drawing up the sizes and shapes needed to have a shield fab-ed up. im PM-ing you now for the pictures since you can't post them here
SirClass is offline
#14 Old 10-01-2015
geordielad's Avatar
Vehicle: SLK230 R170 2001
Hi Paul who are you using for the remap. I live 5 mins from demon tweeks so not to far from you. Will be interested to see the results
geordielad is offline
#15 Old 10-01-2015
Quoted: 82 Post(s)
I got your email address , I'll send a pic tomorrow of the intake . I'll include one of the oversize pulley and the larger intercooler . My logic says that with a bigger pulley the blower is working harder and therefore needs more airflow ? I reckon cutting out the slam panel support between the headlight and grill is going to be the way forward .
#16 Old 10-01-2015
Quoted: 82 Post(s)
I'm guessing by your name your also from the north east ? I'm from Durham originally .
I bought the pulley from speers in Germany and actually called in to his place on my way to the nurburgring from my place in France , I believe he can send the re map by some sort of internet black magic to your computer but for me it was easier to make a 3 hour detour ! I really must drag myself out of my cave and into the same century as everyone else
I'm just up in Heswall on the Wirral , your welcome to try my car out before you commit to buying .
I reckon there's still good gains in the exhaust area yet .
clown likes this.
#17 Old 10-02-2015
geordielad's Avatar
Originally from Newcastle been down here 30+ years. Would be intrested in seeing her when she is done thanks
overdraft likes this.
Larger Crank Pulley vs Smaller Super Charger Pulley Erok Performance MODS for the R170 19 1 Week Ago 06:35 AM
SPEER Crank Pulley upgrade and remap extra 45bhp clown Performance MODS for the R170 123 02-08-2019 02:32 AM
ASP Crank Pulley and belt overdrive boost pulley foilman SLK Parts For Sale 3 08-21-2014 10:28 PM
$68 Pulley Upgrade DIY WCFD2509 Performance MODS for the R170 11 08-20-2014 11:29 PM
Serpentine belt idler pulley Oberon SLK R170 General Discussion 2 06-22-2011 10:02 AM
