DIY SLK32 (R170) Paddle Shifters Install with pics - Mercedes Benz SLK Forum
 5Likes
#1 Old 08-22-2011
Vehicle: 2003 SL55 & 2002 SLK32
I previously looked around for instructions on this and found none. So I did it and here is the how to. This DIY is not for the timid, and probably far more trouble than it is worth .... but this will get you there.
NOTE: This is primarily a work-around for cars without factory installed paddle shifters (and their wires) and should work for any model with a "5G-tronic" (also know as NAG 1) auto.
Background :
SO, there I was,, I had my (2002 slk32) shifter apart for another reason and noticed how simple it would be to tap into the up and down functions (so I added the wires while I had it apart). Shortly after, I was talking with Rob @ needswings about something else and this topic came up. He told me some guys on the crossfire forum had done this, so I went looking there. It seems that a few had been done, but they were switching to paddle shift equipped wheels and then using a small remote transmitter (as there are too few available circuits in the clockspring).
Having an extra steering wheel (and a basic understanding of digital and analog electronics) I decided to do this in my SLK32 with the stock wheel (without the wireless interface) using the AMG aluminum paddles. Instead of using the wireless remote and receiver , I put all of the switch signals (horn, shift down and shift up) on to the horn line and then decoded them under the dash with a module that drives the horn relay and the up and down switches in the floor shifter.
Using the paddle shifters on the wheel shifts Identically as the - and + on the floor shifter.
Sorry, I did not take pics of the floor shifter dis-assy. I would strongly recommend starting there. This part is not rocket science, but it takes patience. ... I may post some pics of that part later as i will be helping a local 2002 s55 owner do this mod to his car shortly and plan on taking pictures of the floor shifter dissasembly, mod and reassembly.
the part number for the aluminum paddle switches I used is 1712670046. This is for a set (right and left) $99 at parts.com
(I opted to install 8-32 helicoils in mine ....)
WARNING:
DON'T turn your car on with the airbag unplugged (this will cause your SRS system to require a dealer reset.
I have been running this set up for more than a month now and the only complaint I have ... is that I didn't do it years ago!!
Chris
Simon cliffe likes this.
latemodel21 is offline
The Following 2 Users Say Thank You to latemodel21 For This Useful Post:
#2 Old 08-22-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 270 Post(s)
Wow, that is a mod that is not for the faint of heart. Looks great though, and paddle shifters are definitely a nice feature.
Durkatlon is offline
#3 Old 08-22-2011
Vehicle: 2006 SLK55
Looks like a nice project. I like your paddles better than the built in ones on the '55. I'm constantly hitting them when not intended.
Todd157k is offline
#4 Old 10-15-2011
complete install instructions
Here are the complete instructions for installing paddles shifters in a Crossfire or an R170 SLK.
I wrote it for crossfires as there seemed to be a lot more interest on their forum (more than 20 of them have done this Mod already or are doing it now).
The directions for installing this on an SLK only differ slightly in that the rear center console does not have to be fully removed, the front center console does not have to be modified, and the SLK steering wheel already has the through holes in its horn-base so it needn't have any holes drilled in it. (all in all, quite a bit easier in an R170). The rest of the install is identical (2 of the guys on the crossfire board are installing this Kit in R170's).
Chris
The Following User Says Thank You to latemodel21 For This Useful Post:
#5 Old 10-15-2011
Quoted: 104 Post(s)
Very nice, would you mind if i place this in the new R170 DIY forum?
#6 Old 10-15-2011
wouldn't mind a bit, I guess ....
Chris
#7 Old 01-07-2012
Vehicle: 1998 SLK230
never mind, answered my own question....
mauinate is offline
#8 Old 03-29-2013
Vehicle: SLK 3.2 AMG 2002, Kleeman pulley and remap, adjustable Bilstein dampers.
Other Toys: Whyte 46, 09 Rangerover, Ducati Multistrada, Aprilia V4 Tuono.
This looks awsome....
I am making enquiries to do this... Anyone out there lived with this mod for a while?
Please join in this thread if you have.
Ric.
Ukmongoose is offline
#9 Old 03-30-2013
Ric.
While designed for the R170, this mod has been done in more crossfires (arounf only 10 R170s ... while more than 40 crossfires have it now).
here is a link to a thread with more info and end user feedback
http://www.crossfireforum.org/forum/...completed.html
this thread (starting aroundt post #63 ) also has a lot of info , user feedback and install pictures.
http://www.crossfireforum.org/forum/...e-shift-4.html
Mods, if posting links to another forum is a no-no, I apologize, feel free to edit if required.
Cheers,
Chris
#10 Old 03-31-2013
Thanks Chris,
I am already making enquiries to have this done.
I will keep the thread alive.
Ric.
#11 Old 04-01-2013
Thanks Chris,
Ric.
There are several vendors that you can get this kit from (or directly from me, the manufacturer). I am not sure which if any of these may be SLKworld sponsors. but it is available thru DCTmotorsports (USA) and srt-6.com (sweden). Closer to you, another retailer I work with, comandonlineUK may be able to point you to an installer or do the install themselves. ComandonlineUK stocks other products that I manufacture and could certainly line this up for you (Talk to Richard).
Cheers,
Chris
#12 Old 04-02-2013
Thumbs up
Yabbadabbadoooo!
I will call them. Comandonline here I come.... Do you have the contact details?
Cheers,
Ric.
EDIT : I have contacted them, all systems green to go.
#13 Old 11-24-2013
Vehicle: 2003 SLK320
Other Toys: '86 560SL (sold), '04 SL55 (sold)
Hey Chris,
I sent a PM wanting a kit, buy my "Sent" is empty.
Please contact me DR. Steve Karr @ g mail . com
Thanks!
Steve
Steve Karr is offline
#14 Old 04-22-2016
Vehicle: '04 SLK32 AMG
Other Toys: '01 M5 Imola Red
Quoted: 15 Post(s)
Paddle Shifter
Do you know anyone in the bay area who can install this paddle shifter? My email is [email protected]. Thank you
imola red is offline
#15 Old 04-22-2016
Quoted: 6425 Post(s)
This thread is 2 years old
also, who are you asking?
please use the 'quote' button at the bottom of any post you wish to reference or ask a question of so we know who you are talking to
https://www.slkworld.com/new-members-...d-how-fix.html
#16 Old 04-23-2016
Well, I am in the bay area and I have installed this for some customers in the past. More often though, customers (I've sold more than 60 of this particular kit -mostly to Crossfire SRT6 owners) install it themselves or have their favorite INDY install it. The instructions are detailed and complete.
Having said all of that, the kit is currently out of stock and I'm not sure how soon I will make more.
Send me a PM if you want more info or want to be added to the list (to be notified when the nest batch is ready).
Cheers,
Chris
Elmer Fudd likes this.
#17 Old 04-23-2016
Quoted: 15 Post(s)
R170 Paddle Shifter
Cannot PM yet. However, please include me in your waiting list. Please email me more info. Thank you
#18 Old 04-23-2016
you have 11 posts
you need 15 posts to pm anyone else
go welcome 4 new members
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#19 Old 06-24-2016
Vehicle: 02' SLK32 AMG
Other Toys: Procharged 95' e34 540/6
I am absolutely blown away with this install. Sorry for being so late to the party but I got my slk32 recently and it's damn near perfect and I think paddles would be a fine touch not for real world gains just driving pleasure!
I am very interested in a kit and possibly install if your another mender which experience is avialable.
Please email me or pm at anytime if you can still help with this.
Thank you!
SLicK AF is offline
#20 Old 02-20-2018
Vehicle: SLK R170 230 1999
May I ask
what is this ?
what this function for?!
have not seem this before
LIL DON SLK likes this.
svoips is offline
The Following User Says Thank You to svoips For This Useful Post:
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 55 03-22-2019 12:58 PM
DIY : R171 : Denison Gateway 500 / Escort 9500ci Install UK-C200 SLK R171 Class DIY 18 10-10-2017 03:54 PM
New Wheels and X-Pipe install With Pics! themizz039 Performance MODS for the R171 23 08-17-2009 08:25 AM
Sterring Wheel Paddle Shifter (SLK230 - R170) gummozebra Performance MODS for the R170 6 05-21-2009 10:35 PM
DIY: rear spoiler removal and install, part 1 dltslk SLK R171 Class DIY 0 03-12-2009 12:55 PM
