All right, got an ASP pulley on the way. :) - Mercedes Benz SLK Forum
#1 Old 08-04-2011
Vehicle: 2001 SLK 230 Sport
My ASP will be here by next week. I plan on installing it, then taking it straight to Powerchip to get the ECU retuned. They've assured me that with the remapping of the ECU, I will not need to go through all the other stuff. The plugs, FPR, or the MAF relocation. I may get one step colder plugs either way just to be safe, but other than that, that's about it.
I'll keep the crowd up to date on power results!
Koru_Kinshi is offline
#2 Old 08-04-2011
If you have any questions i may be able to help, i installed my pulley a couple months ago.
#3 Old 08-05-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Hey! Are we going to see your car on a local meet-up at some point? Your mailbox is perennially full .
Durkatlon is online now
#4 Old 08-05-2011
Yeah, I get it buddy. I do live in Aliso Viejo. The places you guys go aren't necessarily the closest, heh. But I will do my best.
As for livefreeordie... I *can* throw the transmission into 5th to keep the pulley in place right? I did the same thing for my C230...only put it in 6th gear. Buellwinkle and Linh from back in the day told me to do it like that.
#5 Old 08-06-2011
I don't see why not, i have an auto trans so my method was a bit different.
#6 Old 08-19-2011
What belt am I going to need to use for the bigger pulley? Is a gatorback ok to use or just a regular style belt?
#7 Old 08-19-2011
I found the best place to get the belt you need is from napa, i will get you the part number when my shift is over tomorrow.
#8 Old 08-21-2011
Sorry it took so long to get back to you with the part number. Micro -V 060560
13/16" x 56 - 5/8" oc 20mm x 1439mm oc i don't remember how much i paid for it. (napa)
#9 Old 08-26-2011
Thanks. I'm going to try and do it today. How long did it take you to do yours?
#10 Old 08-26-2011
The whole job took about two hours, i took my time removing the rad fan and hoses. The crank bolt was a bit of a pain also.
#11 Old 08-29-2011
Was it worth the cost and trouble? I know it's only a few hours, but is it a noticeable difference in HP? Thanks.
Klonny is offline
#12 Old 08-29-2011
It was worth the cost to me and there is a noticeable difference. Keep in mind there are other things that should be done to complement the pulley. Replacing the inter-cooler with a larger one will keep the air intake temps lower, replacing all the inter cooler hose's with larger ones adds to the cooling. Just to mention a few mods.
#13 Old 08-31-2011
I torqued the crank bolt to 195 ft lbs. That was the best we could muster. That's still good, right?
#14 Old 09-01-2011
That's plenty, how did the job go for you? Any problems?
#15 Old 09-01-2011
Well, I'll be honest. The bolt size was wrong. Was supposed to be 27 mm, and the belt was WAY too long. 1439 was too much. It fit with a 1390. But other than that, everything else was fine. I posted the vids up on the other thread.
#16 Old 06-18-2012
Vehicle: 1999 slk230 kompressor 170
Other Toys: BMW R1200c motorcycle, ML350 mercedes benz
Quoted: 9 Post(s)
Send a message via Skype™ to rogermursick
ASP pully
I plead ignorance on this one, but what is an
ASP pully?
thanks,
Roger
rogermursick is offline
#17 Old 06-18-2012
Quoted: 6451 Post(s)
Google
asp is a company that makes pulleys. above is search for asp pulleys - slk
#18 Old 06-18-2012
ASP pully?
thanks,
Roger
Its a performance overdrive crank pulley, it spins the S/C faster producing more boost which in turn creates more horse power.
#19 Old 06-18-2012
Some people might not even know what boost is. How about..... "Its a performance overdrive crank pulley, it spins the S/C faster that pump in more air which in turn creates more horse power
Klinh is offline
The Following 2 Users Say Thank You to Klinh For This Useful Post:
#20 Old 06-19-2012
Quoted: 9 Post(s)
I'm curious, If you change out the pully it seems to me that you have to change out the s/c and other pullies because the system is engineered for the current specs. I would think that you would end up burning out the s/c bearings (running faster) and other pully shafts for same reason. just saying.
Best,
Roger
ASP no longer making pulley kits? mavrick77 Where to get R170 SLK Items 8 10-17-2011 03:18 AM
ASP Pulley install question Koru_Kinshi Performance MODS for the R170 13 08-04-2011 04:53 AM
Serpentine belt idler pulley Oberon SLK R170 General Discussion 2 06-22-2011 10:02 AM
98 slk230 for sale, ASP pulley, Koni Yellows, Eibach Springs pdubq SLK Cars For Sale 7 10-01-2010 12:43 AM
