Chrome-Tec Pulley kit - Mercedes Benz SLK Forum
#1 Old 10-03-2010
Vehicle: 2017 Yellow 718 Boxster
Other Toys: 2018 Tesla Model 3, 2018 Toyota Tacoma
Anyone have any experience with this pulley kit?
http://www.chrome-tec.com/shop/Merce...ssor::367.html
atebit is offline
#2 Old 10-03-2010
Don't buy it. It looks like the pulley is attached with set screws, bad idea.
#3 Old 10-06-2010
Elite1
Guest
Posts: n/a
Chats:
Quoted: Post(s)
You can see that the wheel has inside insert screws with this screws you fix the wheel over the OEM wheel, the screws must be secured with locktide special metal glue
#4 Old 10-06-2010
cyberdrakon's Avatar
Vehicle: SLK55 2006 widebody
Chats: 7
Quoted: 55 Post(s)
Wow...so i CERTAINLY wouldn't buy or use those on my car, or recommend them. Locktite is strong, but set screws on pulleys going several thousand RPM without pre-drilled holes? can you imagine the wobble if the balance is just slightly off? Not to mention the negative effect on power from ADDING weight to the pulley.
cyberdrakon is offline
#5 Old 10-07-2010
Ok so that kit is right out...what's recommended for an 03 230?
atebit is offline
#6 Old 10-07-2010
The only place i know of is ASP Raceing, if anybody else know's of another source please post it.
#7 Old 10-07-2010
Vehicle: 2002 SLK 230 Silver, 2003 SLK 32 AMG Red. 2006 SLK 55 AMG Black All Options
How about forum sponser...
Elbert55 is offline
#8 Old 10-07-2010
If Anthony has the overdrive crank pulley that would be my first choice.
#9 Old 10-08-2010
Just to follow up i dropped Anthony (TVT Design) an email about the overdrive pulleys for the slk230's, he said he can get them from asp depending on his stock of cores. If you have an extra pulley or if you can live without your's for a bit they run $350, keep in mind that you will need a larger belt.
#10 Old 10-19-2010
Vehicle: Whatever is in the shop
Other Toys: 05 Crossfire, 90 Corvette, 67 Camaro, 02 Prius, 89 Cushman Ice Cream Truck
This is a scary modification to say the least. These are actually made by a larger more well known company as an alternative to the ASP pulley. We received one of the first production units about 2 yrs ago and never installed it due to balance issues and worries of the pulley seperating. If you weld the pulley together and have it professionally balanced, then this is an ok mod, but the cost for that would put you way over the ASP ones.
TVT_design is offline
Pulley Kit bazzle Performance MODS for the R170 35 09-24-2014 11:29 PM
exhaust and pulley kit sonic02stang Where to get R170 SLK Items 12 09-24-2011 05:02 PM
pulley kit wanted davids7 SLK Parts Wanted 4 11-10-2009 07:08 AM
