$68 Pulley Upgrade DIY - Mercedes Benz SLK Forum
  • 1 Post By WCFD2509
#1 Old 08-15-2014
Vehicle: 2000 Subaru Legacy W/ Mercedes M62
I thought you guys would be interested in the pulley I built. This is being used on my Subaru rallyX build. So, I don't need to worry about the ECU codes that you guys may get from removing the OEM clutched pulley. This is only to show you guys another option for the pulley that won't break the bank on an older car. figuring out the ECU mods required is up to you guys. Enjoy...
I measure the O. D. of the face plates steel part that slips on the splined shaft. It was about 17.2 mm. I found out all Powerdyne pulleys are 17 mm ad pressed on design. So I found this site: 928 Motorsports - Porsche® 928 Performance Parts - 6-Rib Power Pulleys for Powerdyne, Vortech®, Superchargers
I did my calculations on what pulley ratios would get me right around 14,500 rpm on the M62.
These calculations are for my Subaru motor with a 5.25" crank pulley:
5.25/2.25=2.33333... pulley ratio.
2.333333x6250 rpm=14,583.333 SC rpm at redline.
14,583.333x1 (liter)x0.03531=514.9375 SC CFM
((514.9375-225/225)/14.7)x100=8.766 psi of boost on an EJ25.
So this pulley combo should yield 8.766 psi at the supercharger and approx. 7.5-8ish psi after my intercooler.
First, you have to cut the shaft cover off to make room for the pulley's position.
Next you have to grind down about .1ish mm off the faceplate portion that the pulley will press onto. (I forgot to take pictures.)
Then press the pulley onto the faceplate portion.
And the end result with extra pictures.
OffLineR likes this.
WCFD2509 is offline
#2 Old 08-15-2014
OEM Pulley vs. Powerdyne Modded.
The OEM Mercedes 3.6"ish vs. the Powerdyne 2.25" supercharger pulley.
WCFD2509 is offline
#3 Old 08-16-2014
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
would you be willing to make ones for users and sell them? if so i'd be interested
SirClass is offline
#4 Old 08-16-2014
I totally could make them. But you guys would have to send me your old pulley. Because the stock face of the pulley would be required for me to press the new pulley on. And you'd have to have the supercharger snout cover cut.
I'm going think it over. It would almost be better for me to have people send there whole supercharger to me and I'll port it and upgrade the pulley to hat ever size you want from the site in the post.
WCFD2509 is offline
#5 Old 08-16-2014
Quoted: 6428 Post(s)
WCFD2509,
Please update your location/vehicle (model and year,ie 2007 SLK 350) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
#6 Old 08-16-2014
Quoted: 34 Post(s)
PM me if you decide to do it, i might be interested depending on price and your location
SirClass is offline
#7 Old 08-17-2014
He only has 5 posts so he cannot pm anyway, fyi
My post above should help him increase his post count to reply to pms.
#8 Old 08-17-2014
Thanks I'll update my profile today.
I know there is not really any pulley options under $200 out there for the M62's. Just want to share the knowledge.
I'll think about making some for other people.
jbanks, are there any rules to making pulleys for people through this forum I need o be aware of?
WCFD2509 is offline
#9 Old 08-17-2014
No rules that we can see at the moment. If you were to be taking business away from a paying sponsor then yes.
#10 Old 08-20-2014
Thanks.
So to clarify,
Because I no official sponsors that I can find on this forum make custom pulleys similar to the one I created I should be good to go?
Thanks,
Thomas Mann
WCFD2509 is offline
#11 Old 08-20-2014
At this golden moment, yes.
If the owners/management change their mind, you'll know it.
#12 Old 08-20-2014
Thanks!
Thank a bunch!
Thomas Mann
WCFD2509 is offline
Tags
pulley upgrade m62
DIY stereo upgrade to the '05 SLK-350 Audio20 (Hertz, Audison, McIntosh) linuxpro SLK R171 Class DIY 81 06-04-2015 09:51 AM
supercharger pulley upgrade golden bear Performance MODS for the R170 19 02-25-2015 12:16 PM
99 slk 230..about to do pulley upgrade Mayday Performance MODS for the R170 4 05-27-2014 12:20 PM
DIY Nav Upgrade SpaceDuck SLK R171 Class DIY 17 05-24-2011 05:01 PM
Pulley upgrade for a UK AMG 32 spanners AMGs 3 04-20-2009 06:41 AM
