M112 Upgrade Parts - Mercedes Benz SLK Forum
  • 1 Post By TVT_design
#1 Old 03-13-2010
Vehicle: Whatever is in the shop
Other Toys: 05 Crossfire, 90 Corvette, 67 Camaro, 02 Prius, 89 Cushman Ice Cream Truck
M112 Upgrade Parts
Here is a brief list of the OEM parts you can use on your SLK320 to achieve additional power.
M112 Upgrades
  • C240/C320 Airbox: PN: A1120901501; this increases overall filter area by approximately 50%, Airbox volume by 35%, and increases intake tubes to 3", a 20% increase from stock
  • M113 MAF: PN: A1130940048; The V8 MAF is a full 3" design that allows for increased flow. NOTE: You must swap out sensors and use only the housing of the V8.
  • M113 Throttle Body: PN: A1131410125; The larger V8 TB is opened up to 74 mm and matches the inlet of the intake manifold perfectly.
  • 430/500 M113 Fuel Injectors: PN: A1130780249; These injectors are rated at 19 lbs/hr and are a great upgrade for a bolt on car.
  • C43/C55 M113 Fuel Injectors: PN: A1130780023; These monsters flow 21 lbs/hr and are perfect for a highly modified crossfire running headers, larger exhaust, cams, and head work. These injectors will support upwards of 275 HP.
  • CLK430 Fuel Pump: PN: A0004707894; The stock fuel pump is more the adequate at 160 l/hr to support up to 390 Crank HP (N/A), but for those of us that like to push the envelope and have added a little boost or nitrous, then a new pump is in order. The M113 (CLK430 used as example) pump flows a healthy 205 l/hr and will support upwards of 500 HP N/A or 380 HP FI.
Our performance products are built around these OEM upgrades. We offer a larger MAF housing, upgraded injectors, 74mm TB, and soon a cold air intake.
The best route for upgrading these engines is as follows:
  • Intake
  • MAF
  • Throttle Body
  • Injectors
  • Tune
THe above, matched with a well flowing exhaust, has produced over 265HP on the M112 engine.
M4rCu5 likes this.
TVT_design is offline
The Following 2 Users Say Thank You to TVT_design For This Useful Post:
DIY stereo upgrade to the '05 SLK-350 Audio20 (Hertz, Audison, McIntosh) linuxpro SLK R171 Class DIY 81 06-04-2015 09:51 AM
FS:R170 Aftermarket parts OEM parts sikslk99 Where to get R170 SLK Items 39 07-30-2010 01:28 AM
Parts needed after near accident. -Eric- Where to get R171 SLK Items 4 01-25-2010 05:45 PM
ECU software upgrade update fyi jbanks15 SLK R171 General Discussion 5 02-05-2007 05:51 AM
SLK350 Sport Suspension Help with Parts & Install... RacerCub68 Performance MODS for the R171 6 08-10-2006 01:20 AM
