3D printing experts? - Mercedes Benz SLK Forum
 5Likes
#1 Old 11-27-2018
Quoted: 914 Post(s)
Are there any 3D printing experts that could offer advice tó a noob? Our library has a printer; I need to know how to prepare to print. Some help with sketchup would be helpful too.
One of the plastic arms in my center AC vent is broken beyond repair.
efair is online now
#2 Old 11-28-2018
PaPa Bear's Avatar
Vehicle: 1999 SLK230
Other Toys: What ever i have in my hand at the time
Quoted: 35 Post(s)
FreeCad an option that i use, then you will need to decide on plastic to use.
Resently printed window part for my I30 using carbon impregnated nylon (not normal stuff very strong as was part of window mech)
Not sure what your lib allows you to use, or available in regard to material (PLA ,ABS)
But all the details needed are under 3D sites, not as simple as you might hope but very much doable
Steep learning curve, but worth it.
best of luck and cheers from down under.
P.S search thingiverse someone might have already made the part
Edit: STlfinder.com finds some SLK models if anyone is interested
PaPa Bear is offline
#3 Old 11-28-2018
Quoted: 914 Post(s)
So do most printers accept most plastics? Or do I need to ask about the printer before buying the plastic?
This arm is attached to the center vent control, when you turn the control this arm opens and closes the vent. It has two small ball joints on the ends that press into plastic bits. It doesn't see much force but will see slight friction. Does that help with material selection?
efair is online now
#4 Old 11-28-2018
cyberdrakon's Avatar
Vehicle: SLK55 2006 widebody
Chats: 7
Quoted: 55 Post(s)
efair, the first step is to learn to model before you even get started with the 3d printer.
If you have a rough model, I can give you some tips on how to improve it.
55russamg and Avel Du like this.
cyberdrakon is offline
#5 Old 11-28-2018
Quoted: 914 Post(s)
Luckily for me, I've used solid modelers since the early 1990's (CATIA). I found tinkercad.com to do exactly just what I needed with a minimal of head-scratching.
My STL is here if you have the means - please review. This is the first time I've designed something for printing, it's not clear to me if just drawing "the part" is enough, or if I need to add anything else to facilitate the printing.
efair is online now
#6 Old 11-28-2018
55russamg's Avatar
Quoted: 681 Post(s)
Question 3D Printing
Who invented the idea of 3D Printing?
Was it the kids....?
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is online now
#7 Old 11-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
You'll want to check the nozzle size before buying material. usually its .4mm or .8mm. also the spool will come in 1.75mm or 3.00mm. So check and see what the printer takes. since your using this part on an air vent, I'd use ABS material because it will take heat better than an ASA or something softer without warping
looking at your model, it will be difficult to print something this small with a machine that has a .8mm nozzle. I'm about to switch my home printer over to .4mm and maybe I can do a quick run and see how it turns out. You will probably need to do some mild sanding on the balls in order to get them smooth enough.
Turdo2 is offline
#8 Old 11-28-2018
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 257 Post(s)
Hi All
I have had some very good prints from Catia SLT files with designing our Paddles , But I found the strength of 3D printed parts from normal printers is not up to much . I had some prints from a SLS printer in ABS just the same . If the part is not a part that's going to be touched a lot & is like a vent etc I think you should be ok , I'll need to seal the surface to stop the sun damaging the raw surface. We were always hoping to 'print to market' but prices & strength of the parts does not allow this to happen.
I would look at a company called Carbon & envisionTEC
https://3dprinterchat.com/2017/01/3d...acturers-2017/
Good luck
Andy
2005 Obsidian Black 55 AMG
Black Power Coated Rims with Diamond Cut Edge
Magnaflo Xpipe kept all 4 Cats (now two removed)
Shorty Antenna (no signal type)
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
AMG Puddle Projectors
Kleemanns Headers
Eurocharged tune
Spyder Black Headlamps
AMG Logo Lower grille
G Paddles
ZeroZero is offline
#9 Old 11-28-2018
Quoted: 914 Post(s)
So given the small part size (the balls are only 4.42mm in diameter) what nozzle size would be best? If I use a 0.4mm nozzle do you recommend any particular spool size (filament size?).
The original part is stamped "PC/ABS" so that is the material I will try to find first.
I may end up having it professionally printed since I am not finding a 3D printer nearby. I've requested an online quote. The library in the next county can print it, but they'll charge me $30, and they won't even talk to me until I'm there in person.
efair is online now
#10 Old 11-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
You can get down to a .2mm nozzle.. and I believe the smallest filament you can get is 1.75mm. your part may be cheaper if you have it machined!
Turdo2 is offline
#11 Old 11-28-2018
Quoted: 914 Post(s)
Just curious - why do you say that? Is it the cost of the nozzle? The filament? Do I need a more expensive machine to use the smaller nozzle?
efair is online now
#12 Old 11-28-2018
PaPa Bear's Avatar
Quoted: 35 Post(s)
Prints out fine with .4m head (see photo sorry hard to see but thats what i had in the machine)
If you pm me a mailing address i will have nylon impregnated with carbon fibre in the machine this weekend and wil print one for you
The one in the photo is PLA which i use for prototype work and has had no post work. Ie straight off the printer.
Cheers from downunder
#13 Old 11-29-2018
55russamg's Avatar
Quoted: 681 Post(s)
Thumbs up
I repaired my fog lamp grill, with all the fish scale design with this stuff.
PLASTEX, PLASTIC REPAIR KITS, FIX CRACKS, REPAIR PLASTIC
https://www.slkworld.com/slk-r171-ge...5-plastex.html
Cheers Russ
SmartTop
#14 Old 11-29-2018
Quoted: 914 Post(s)
Thank you!
When I try to PM you, I receive: "PaPa Bear has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her."
I can't tell 100% from your photo but it looks like the top ball is somewhat distorted, is there something I can do to the drawing to make it better?
efair is online now
#15 Old 11-29-2018
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi All
To me it looks like they is a cut out on one side of the top blue ball , like a Pac-Man ?. what Cad Package did you model it up in. Does it look like a clean & water tight model. You could send me the model if your having trouble . I’m a Cad Designer by day.
Sent it to gpaddles.com
Andy
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
Kleemanns Headers
Eurocharged tune
G Paddles
ZeroZero is offline
#16 Old 11-29-2018
Quoted: 914 Post(s)
Hi All
Andy
Andy,
My model is linked in post#5 - in STL format. I used tinkercad.com to draw it.
efair is online now
#17 Old 11-29-2018
Quoted: 914 Post(s)
I'm wondering if I need to add two support structures for the two spheres - the deformations seen in your photo are exactly in the places where any support structures would meet the spheres.
efair is online now
#18 Old 11-29-2018
PaPa Bear's Avatar
Quoted: 35 Post(s)
Thank you!
I think that i fixed the pm problem,
The slight flat on the balls is that it has to sit on a flat bed at some point.
It will depend on how critical the fit in the socket is if we make the ball slightly oversize you could sand down ?
Am trying a print in a different direction to reduce supports.
At the end of the day we can but just try and see how we go.
Anymore detailed and yes you wil need a printer with higher resolution.
#19 Old 11-29-2018
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi All
Your model looked alright , So I re-modelled using my cad package & exported a STL file link below , setting for stl file is seg 0.0001 & step 1.0mm
https://drive.google.com/file/d/120g...ew?usp=sharing
Its about 10 meg.
Andy
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
Kleemanns Headers
Eurocharged tune
G Paddles
ZeroZero is offline
#20 Old 11-29-2018
Quoted: 914 Post(s)
Pa Pa Bear,
I have updated my model to include supports for the balls - download the new version at the same link above... if your alternate approaches don't work, and I haven't exhausted your supplies/patience/time, try my updated model in PLA.
Totally thankful for your efforts BTW.
efair is online now
You have the hot, humid workshop floor of a printing company to thank for this comfort-enhancing technology Berliner Heckflosse Off Topic 0 02-26-2018 10:06 PM
Calling all Tire Experts Look here! Melvin Byrd Tires, Wheels, Brakes & Suspension 2 08-23-2017 04:15 PM
Cars will be ripe for identity theft as shopping comes to dashboard, experts say Berliner Heckflosse Off Topic 0 08-27-2015 01:58 PM
Real challenge for experts [central locking, instrument cluster] Richardvi SLK R170 General Discussion 16 01-28-2015 01:46 PM
Medical Experts Fear F1 Champion Will Forever Remain in a ‘Vegetative State’ Berliner Heckflosse Motorsports 5 06-17-2014 01:56 AM
