Why Mercedes Fires Its Spark Plugs Five Times per Stroke - Mercedes Benz SLK Forum
  • 1 Post By Berliner Heckflosse
#1 Old 09-27-2018
Vehicle: 1999 slk 230
Quoted: 531 Post(s)
[IMG]https://hips.hearstapps.com/hmg-prod.s3.amazonaws.com/images/roa080117dpt-drive-amg-03-1501860896.jpg?crop=1.00xw:0.754xh;0,0.0518xh&resi ze=768:*[/IMG]
t's a method called "Multispark" ignition, and it makes engines more efficient at low loads.
In its latest generation of engines, Mercedes uses a technology called "Multispark ignition," where each spark plug is fired multiple times (five, to be exact) when igniting the air-fuel mixture inside the cylinder. Why, you ask? Well, it all has to do with efficiency. Jason Fenske of Engineering Explained is here to tell us all about it.
Under low engine loads, it's more beneficial to use a lean air-fuel ratio (that is, there's a lot more air in the mixture than there is fuel). In this situation, it can be difficult to start ignition quickly because of how spread out the fuel is within the cylinder. Mercedes's Multispark ignition system alleviates this problem by simply firing the spark plug more than once per stroke. This creates a bigger flame from the plug, which means less ignition delay, and faster combustion overall.
more
https://www.roadandtrack.com/new-car...ech-explained/
This post brought you by FLOSSY ...the KING of unimportant OFF TOPIC Posts.
Berliner Heckflosse is offline
NGK Tech Bulletin on not greasing spark plugs ! ! Delucas SLK R171 Class DIY 35 01-31-2018 02:35 PM
Mercedes and the change of Times Berliner Heckflosse Off Topic 5 08-05-2013 01:23 PM
question about spark plugs... Sad_dc Performance MODS for the R170 7 08-22-2011 01:55 PM
Lasers for Spark Plugs Swagman General Discussion 4 04-26-2011 10:34 PM
