SLK breathalyzer install - Mercedes Benz SLK Forum
 13Likes
  • 5 Post By 2006star
  • 1 Post By etyu
  • 3 Post By etyu
  • 2 Post By 2006star
  • 2 Post By etyu
#1 Old 10-29-2016
2006star's Avatar
Vehicle: 2006 SLK350
Quoted: 7 Post(s)
So I installed the SLK breathalyzer to indicate if Im impaired before I get behind the wheel a few days ago.
If you see * double * don't drive { or have someone else take the pics cause you shake to much to be behind a camera }.
Install took only a couple minutes on each door.
Well worth the time and money in my opinion.
Pic attached for your amusement.
2006star is offline
#2 Old 10-29-2016
Moderator/RoTMorganiser
Quoted: 2121 Post(s)
Great for a chuckle on a quiet night
#3 Old 10-29-2016
Quoted: 344 Post(s)
Got link to the supplier? It doesn't have to be the "breathalyzer" version
#4 Old 10-29-2016
2006star's Avatar
Quoted: 7 Post(s)
Grabbed them off Ebay from a USA supplier, figured they would arrive quicker than ordering from the China supplier.
The guy had a chart to confirm year and model of cars it would fit so it worked out ok.
2006star is offline
#5 Old 10-29-2016
Quoted: 344 Post(s)
Just ordered this version from a local California supplier (from flebay): 2x Ghost LED Door Courtesy Laser Light for Mercedes Benz C-Class SLK CLK GLK AMG | eBay
dbgrn, Avel Du and 2006star like this.
#6 Old 10-29-2016
2006star's Avatar
Quoted: 7 Post(s)
Tight fit
On my 2006 there are no screws holding it in place.
You just have to stick a small flathead screwdriver under one end and pry it out.
There is enough slack in the wire so you can get at the connection, you just have to tug on the socket so the wire can be pulled forward exposing the connection.
Once you reconnect the wires to the new Ghost light push that end in place first.
I had to use a very small screwdriver to help guide the other end in place as it is a tight fit.
Don't use too much force as it might crack the new casing.
Apply just enough force to push the wire side all the way forward while pushing down on the opposite end.
I seen a video where it stated if the light doesn't work you should pull out the bulb, rotate the direction 180 and replace it and it should work.
Let me know how the install goes ...
PS. If you ever see double circles when you open the door don't drive call a cab .
cheers
etyu and Avel Du like this.
2006star is offline
#7 Old 10-29-2016
Quoted: 344 Post(s)
cheers
I have attached some old photos:
It is a tight fit. I may use a Dremel motor tool and a small diameter sandpaper drum to shave the rectangular opening at one end to effect an easier removal and replacement.
If I experience diplopia (double vision), I will try my other pair of glasses first, and call a cab or use Uber or Lyft if it does not correct the visual problem
Avel Du and Humberto Cares like this.
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 3 1 Week Ago 04:07 PM
West Coast SLK Meet S. Lake Tahoe May 16th, 17th &. 18th LIL DON SLK U.S. Southwest Region 4 01-20-2015 05:29 PM
Alpine IVA-W505 install in 2005 SLK 55 blackdog General Modifications R171 15 10-27-2008 05:31 PM
