Do tire gels/aerosols dry rot your tires? - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By REB_TN_06
  • 1 Post By frogfoot
  • 1 Post By Stinger
#1 Old 07-23-2012
Quoted: 6604 Post(s)
Found this good response on a search for the damage that 'might' be done to tires when using tire gels/aerosols to make em shine!
Discussions with the VP of R&D of Meguiar's via their detailing forum:
"As most of you know, tire companies build their tires with anti-ozonants build into them. These components are designed to leach to the surface when the tire is under load and in motion in order to protect the rubber from the ravages of ozone exposure. It's ozone that is the main threat to tires, not UV. Ozone levels can vary around the world, but it tends to be greater in and around large industrial cities and at higher elevations. So it looks like Los Angeles and Denver have more in common than they thought! As these anti-ozonants come to the surface and are exposed to oxygen, they turn brown; and this browning of the sidewalls is known as "blooming". Once out and on the surface, they've served their useful purpose and aren't really doing anything any longer - except maybe making the sidewall look less pretty than we'd like. It's a naturally occurring situation ("naturally occurring" as in "it's designed into the tire") and not caused by anything you've applied to the tire. Each tire company has their own recipe not only for the tires but the overall anti-ozonant blend as well. Yes, certain key ingredients are common to most, but it's how their combined, in what ratios, etc that will determine the level of blooming on a given tire.
I can tell you, from personal experience, that when we had 4 different cars at home, each with a different brand of tire, all four cars got the same treatment. That means the same cleaner used on the side walls, and the same dressings used on them as well. None exhibited any cracking that I ever noticed, but one brand of tire showed a noticeably higher level of blooming; ie, those darn sidewalls were always brown. How does this happen when four different brands all got the same cleaning and dressing? It's the tire. That's not good, bad or otherwise, it just is. That's the way the tire was designed. The tires that showed this high level of blooming were Michelins. The other brands were Falken, BF Goodrich and Continental, just for the record. In our VP of R&D's experience, Michelin and Pirelli tires seem to exhibit this to a higher degree than most. Again, that's not good, bad or otherwise, it just is. Both companies make some of the finest tires you can put under your car, no question about it. It's how they construct the tires and what they have in their anti-ozonants that creates this.
Now, fine cracking of the side wall of a tire is due to ozone attacking the side wall. It's quite common for a tire to be taken off a car and the same cracking to be found on the inboard sidewall, the one that never gets any dressing at all. Heck, it never really gets any cleaning either.
So, where do petroleum distillates come into play? Petroleum distillates (let's call them PD's) range from incredibly powerful solvents all the way down to FDA approved lubricants used in food processing plants. That's a pretty broad range. Some petroleum solvents are used in cleaning solutions that will strip that brown off the side of a tire in no time. Some of those might be a bit more harsh than what the tire really wants, or likes. Some might bet a bit deeper into the sidewall and strip out the anti-ozonants that are supposed to be protecting that outer reach of the side wall. Aromatic hydrocarbons, as they're called, are the type of PD's you don't want hanging around your tires as they are very potent. That's not a good thing at all. Meguiar's essentially has two tire dressings with PD's; Hot Shine and Endurance aerosol sprays. But here's the kicker with those - the PD's are basically the stuff that makes an aerosol an aerosol. They're the propellant that moves the ingredients out of the can and onto your tire. They are literally gone in a matter of seconds; they don't stick around on the side wall of the tire.
But what of silicones? Again, silicones encompass a huge variety of materials. We all know that silicones are a bad thing to have in a body shop because any little bit of it getting onto a prepped panel just before paint is sprayed will cause the paint to form fisheyes, a situation where the paint is literally pushed away from the bit of silicone on the surface. But body shops will sometimes use a product called fisheye reducer, which actually contains a type of silicone! Silicone in and of itself, especially in the context of car care products, is an inert ingredient, meaning it doesn't react with anything. Silicones are used to enhance or alter the characteristic of other ingredients - they can make application and/or removal of a product easier; they can help it spread out more readily; they can add gloss. When applied to the sidewall of a tire, they actually prevent - at least to some degree - the ability of ozone to penetrate to the rubber. That means the silicone can actually help protect the tire. Admittedly, this is stretching the point a bit because you're not putting that much product on anyway. Let's face it, we all know that heavy application of a tire dressing is a sure fired way to cause sling, and nobody likes that.
OK, so we've got two aerosol dressings that have a small amount of PD's used as propellants just to get the stuff out of the can. All the rest are water based - gels and trigger sprays like Endurance, M40, Hyper Dressing, Natural & Supreme Shine, etc. All do contain some level of silicone, in varying degrees, but none are harmful to the sidewall of the tire.
To our original poster here, The Dodge, have you looked at the back side of the tires to see if the cracking is there too? Do you have another vehicle with a different brand of tire that you treat the same way but does not have any cracking? Lastly, the area of the tire you describe, close to the rim, is also an area of the tire where there is less flex and movement, and therefore possibly less anti-ozonants being leached to the surface to protect against ozone.
We have every confidence that none of our tire shine products, whether trigger spray, gel or aerosol, will cause any sort of damage to your tires in any way. We have always stood behind every product we make, 100%. That means if you don't like the way it works, we'll give you your money back. It also means that if it damages a surface it's designed to be used on (when used according to directions, of course), we'll take care of you there too. It is extremely rare that we end up buying new parts or contributing to the cost of repairs - not because we fight those claims tooth and nail, but simply because our products aren't causing this sort of damage. That's true of paint care products, cleaners, vinyl dressings, and tire shine products."
The Following 4 Users Say Thank You to jbanks15 For This Useful Post:
#2 Old 07-23-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Interesting stuff. As I've put 20,000 miles on my SLK since buying it 14 months ago, I'm going to guess that my tires won't fail from " Tire Shine Rot" !
Plus I use the nice "grapey" smelling stuff !
Gene
REB_TN_06 is offline
#3 Old 07-23-2012
grapey? get your own writers!!
#4 Old 07-23-2012
REB_TN_06's Avatar
Hey I used quotes !
Now are you going to make me start footnoting all of your posts ! ? ! I guess I could ask the esteemed Helena to add superscript to the text editor, but it seems like a lot of trouble to protect your fragile ego !
Gene
#5 Old 07-23-2012
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 341 Post(s)
nice post Jeff However with all the twisty yorkshire roads we have to play with the tyres just dont last long enough suffer damage from tyre gel
:burn out:: burnout:
frogfoot is offline
#6 Old 07-23-2012
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
I used to be a tire shine potion junkie, but now I just saturate a cloth with speed shine and wipe the tires. No super shiny gloss, but a nice new tire look without any sling.
Gregg is offline
#7 Old 07-23-2012
Fanatical Member
Stinger's Avatar
Other Toys: yes
With my car being white, I find that the biggest problem with tire dressing is slinging. Nothing worse than spit-shining the SLK, taking her for a spin around the block only to find black remnants on all my white fenders from the dressing used to shine the tires. I've been using Fade2Black (Now renamed Black2Black) by the Chemical Guys. It restores all black plastics on the car to "like new" condition. It's more of a satin black shine, a little goes a really long way, no harm on anything with the over-spray and dries almost instantly. I'm very happy with the product and highly recommend it.
[IMG] Uploaded with ImageShack.us[/IMG]
CSMLET likes this.
Steven
Stinger is offline
Check your tires esp. the inner side walls etyu Tires, Wheels, Brakes & Suspension 74 07-05-2019 02:06 PM
CARiD launches Tires section! Seriously, you will love it! carid CARiD.com 1 04-06-2012 06:29 PM
Letters and Numbers QSHIP Tires, Wheels, Brakes & Suspension 2 10-30-2010 06:04 AM
Help! Major Tire Problems marypat Tires, Wheels, Brakes & Suspension 11 10-06-2010 08:48 AM
New Tire surprise, recommendations ASAP Brian_74 Tires, Wheels, Brakes & Suspension 54 09-28-2009 01:09 AM
