Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas - Page 13 - Mercedes Benz SLK Forum
 188Likes
#241 Old 04-02-2019
Mensra's Avatar
Other Toys: Wellcraft Scarab
Quoted: 306 Post(s)
There are two different versions of Techron. There’s the complete fuel system cleaner and the fuel injector cleaner. Decisions, decisions. I’m asking our guru of all things Techron. @jbanks15 Which one should I feed my Garbage Scow?
Mensra is online now
#242 Old 04-02-2019
Quoted: 6187 Post(s)
I use
which includes the injectors since it is 'complete'
Wavetrac LSD thread here:
#243 Old 04-02-2019
Mensra's Avatar
Quoted: 306 Post(s)
Next question Boss: how often?
#244 Old 04-02-2019
I am going to say 'as needed'
but 55s are special...
The M112/M113 family of engines don’t typically have a lot of issues with carbon buildup on the back of valves (like direct injection engines do), since fuel is constantly spraying on the back of the intake valves, which effectively keeps them clean.
#245 Old 04-02-2019
Mensra's Avatar
Quoted: 306 Post(s)
That is an effective non answer. How do you know “as needed“? If it has symptoms, isn’t that too late?
#246 Old 04-02-2019
see my post 1 and start over
#247 Old 04-02-2019
Mensra's Avatar
Quoted: 306 Post(s)
Rinse, dry repeat!
#248 Old 04-02-2019
You are acting like a troll now...
See post 1
I had the symptoms
got the cure.
End of story
#249 Old 04-02-2019
Mensra's Avatar
Quoted: 306 Post(s)
Not trolling, I apologize if I appeared that way. No actually, since my injector became “defective“ and entailed some rather significant machinations to get rectified, I was concerned with proactive steps I could take to avoid a repeat. I did not have symptoms until it was too late. My vehicle apparently functioned correctly until it did not. By then the damage was done and I had to have the vehicle flat bedded 100 miles and a rather costly injector replacement. I do not know what caused the injector to fail, but it was at a relatively low miles and the car had been operated on top tier fuel for several thousand miles prior to its malaise. It had exactly one tank of offbrand fuel put in it prior to injector failure. The injector failed two tanks later. I don’t know if it was coincidence, and I’m wondering if I should have a bottle of TECHRON in the car in case I have to put non-top tier fuel in it.
#250 Old 04-02-2019
never put non top tier fuel in bottom line.
bad/cheap gas is just that...bad and cheap....something even techron won't cure.
#251 Old 04-02-2019
Mensra's Avatar
Quoted: 306 Post(s)
It was either that fuel, or walking.
#252 Old 3 Weeks Ago
JG26_Irish's Avatar
Vehicle: 2006 SLK55 AMG Red with Black int. 31k mi.
Other Toys: C32 AMG, Harley Davidson FLH-FSE, Ducati 900M, MR2 Turbo, Anschutz M54 Super Match
Quoted: 24 Post(s)
Techron
I had a independent Porsche Tech tell me years ago to use Techron about every 3 months in my P-car. I use it or the Lucas injector cleaner periodically in all of my vehicles except for the Diesel. With Techron the prescribed method is to put a full bottle (small one) into 1/4 tank of fuel and drive normal for the rest of the day. Overnight the car will cool. Next day, warm up the car and then run the $#!t out of it. i.e., full throttle, hard acceleration to redline in each gear. Full autobahn experience. The product works overnight to loosen, soften and help dissolve the hard deposits and varnish from the injectors, intake valves, and other important moving parts. Depending on how junked up your engine is and the lighting conditions, you my see an white/lt grey cloud of gunk blowing out of the exhaust for a short while. Not to worry, that is normal.
When you get tired of being a hooligan, go fill the tank with top tier fuel and drive normally for the rest of the tank. If you can get in some fast interstate that is better. The Lucas product and I think the Techron also have a slight octane boost effect also which may help with elimination of the knock/ping/wheeze right away. Depending on your driving style and normal daily route, you may need it more often.
Irish
JG26_Irish is offline
fuel pump no-way Where to get R171 SLK Items 2 02-07-2009 08:53 AM
Road Rage Knock Out FishtailnZ Off Topic 4 04-15-2008 03:08 PM
What fuel do you use? in2dwww SLK Videos 11 04-29-2007 08:10 AM
