vario roof switch or sensor problem - Mercedes Benz SLK Forum
New Members Introduce Yourself Here New members come here first!. Update your profile: model, year and location. Post any issues in the relevant section. The team may then post a link to your issue thread in your introduction.
 12Likes
#1 Old 12-19-2016
Danslk280's Avatar
Vehicle: 2008 SLK 280
Hello everyone,
My Name is Dan and I own a 2008, SLK280. I would like to thank this community for helping me with information’s on repair. I appreciate your help.
I recently had a problem with my Vario roof. Roof was not opening and hydraulic oil was coming out of front of roof. Thanks to this community I was able to find the thread about the ring and replaced it.
Now the roof does not operate. When I push the roof switch nothing happens, no noise, nothing. Please I need your help!!
While changing the ring in Hydraulic cylinder I made a mistake of not releasing the pressure and I had the top open in half way position for 2 days.
I did release the pressure later and could close the roof manually, but the windows are down, Trunk won’t close and there is no noise when I push the roof switch.
I checked the fuses, they are OK. I disconnected the battery for one hour and try to reset the system that did not work. I ran the car and charge the battery for 30 min and that did not work either.
Please look at some Pics I included.
1- Does the roof switch should light up similar to mirror switch when I start the car?
2- Is there any sensor that must be reset?
Danslk280 is offline
#2 Old 12-19-2016
Quoted: 6492 Post(s)
owner's and maintenance manuals great R171 info:
later year owner's/maintenance/comand manuals, top right in the link below:
Bill's Den: Documents
Lube those seals:
https://www.slkworld.com/general-disc...tml#post226839
your brochure:
https://www.slkworld.com/general-disc...ml#post1511249
mods you should do:
smarttop
https://www.slkworld.com/general-disc...ing-about.html
clear or tinted side markers
shorty antenna
led license plate bulbs
led parking lights
carbon fiber on the C pillars https://www.slkworld.com/general-modi...cf-plunge.html
carbon fiber center caps
oem windscreen or lighted/etched windscreen
See my mod albums for more ideas
FREE GIFT! Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car). If looking for a car, get the options before you buy!
@El_Toro_33809
#3 Old 12-19-2016
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Welcome from Madrid...
Check out this thread and read, with special attention to the details, the attached thumbnail/pdf en post #11 .
https://www.slkworld.com/slk-r171-cla...-manually.html
It's quite possible that you need to use a fair bit of force to close the trunk and also raise&reset the rear windows with STAR/DAS diagnosis...
In answer to your question about the light on the switch, no, that's for engaging the towing feature of the alarm.
curro101 is offline
#4 Old 12-19-2016
Quoted: 58 Post(s)
I was having a similar problem. Another member here suggested that I make some jumpers and install them in the connectors to the micro-switches.
I did that for the two trunk/boot lid switches on each side. I could then get the pump to operate. (I had replaced the roof latch cylinder and the two trunk/boot cylinders.)
It did take a little while to get everything going like it should as the system needed to refill and purge the air. I had to refill the pump 3 times to do this.
After I got the system to completely operate through one cycle on its own, I found that I had to bend the arm of both switches for the trunk up a little or they would not close the switch. Once I did that I could remove the jumpers, reconnect to the micro-switches and all is well.
I had tried not only pushing down hard on the trunk corners but I had sat my 230+ lb body on the corners in an attempt to get the switches to contact. That did not work.
Using the jumpers allowed me to find what switches were not operating as they should.
It doesn't take much of a wire to make a jumper. I used about a half inch of left over speaker wire for each one. Bent it into a U shape and stuck them in the connectors.
LIL DON SLK likes this.
dedgar is offline
#5 Old 12-19-2016
duserslk's Avatar
Vehicle: 2008 SLK350 MY09
Quoted: 43 Post(s)
Hi Dan, resetting the errors should get it all going again. The only way to get the boot down, is to decompress or remove the 2 cylinders at the rear.
duserslk is offline
#6 Old 12-19-2016
Danslk280's Avatar
Thank you curro101
#7 Old 12-19-2016
Danslk280's Avatar
Hi dedgar,
What switch did you have to jump?
Is that to close the trunk? and what do you mean by making a jumper?
#8 Old 12-19-2016
Danslk280's Avatar
Hi
What do I need to reset the errors? Just a code reader? I have one of those.
or special program with computer similar to dealers?
#9 Old 12-19-2016
duserslk's Avatar
Quoted: 43 Post(s)
You need to have either a ODB2 reader which can reset the errors, or the DAS/STAR which most dealers have
duserslk is offline
#10 Old 12-20-2016
Dave54's Avatar
Vehicle: 2009 SLK 350
Chats: 2
Quoted: 80 Post(s)
Welcome from Portland, Oregon. Enjoy the forum and the top down driving.
Dave54 is online now
#11 Old 12-20-2016
hasontour's Avatar
Vehicle: In between slk's!!!
Quoted: 37 Post(s)
Hi from London,
Welcome aboard!
hasontour is offline
#12 Old 12-20-2016
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
Hi Dan, and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us and posting an intro!
I can't add anything to the suggestions that have already been made above... I hope you manage to resolve the roof issue soon.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
#13 Old 12-20-2016
LeonardoDaBenz's Avatar
Quoted: 1039 Post(s)
Welcome from Canada Dan
___________________
Len
LeonardoDaBenz is online now
#14 Old 12-20-2016
Jules555's Avatar
Vehicle: 2013 SLK 250 CDi AMG
Other Toys: Aston martin DB9 Coupe 1/18 Aston Martin DBR1 1/18
Quoted: 223 Post(s)
Welcome from Northamptonshire, England.
Life is too short to drive a boring car!
Jules
Jules555 is offline
#15 Old 12-20-2016
Quoted: 2244 Post(s)
Hi Dan,
Welcome from Wirral, England.
It's probably best to post a separate thread for questions as not all members read intros.
That said, you've been given some good places to start.
You're in a good place for regional meets/local info:
U.S. California - Mercedes Benz SLK Forum
Good luck with your fix.
#16 Old 12-20-2016
Danslk280's Avatar
Thank you everyone!
I have 2 questions about the site:
Since this is a intro section where do I post a tread?
also is there a place where I can search by zip code and find Ind. shops near me?
Best regards,
Dan
LIL DON SLK and Avel Du like this.
#17 Old 12-20-2016
At hockey game
You have a r171
Post new questions in the r171 general discussion section
Don't post the one in your intro
#18 Old 12-20-2016
Google
Mechanics file
Car talk
#19 Old 12-21-2016
LIL DON SLK's Avatar
Vehicle: 2009 SLK 55 AMG White 8 cylinder
Quoted: 143 Post(s)
Welcome from the Sacramento Valley SLK Enthusiasts!
Don Owen AKA LIL DON SLK
916/489-6936
If you live in Northern California you can join us for a drive. We meet monthly for drives, road trips lunches. Feel free to call me or email me and I can add you to our email list. I always post events under California here on SLKWORLD.
LIL DON SLK is offline
#20 Old 12-21-2016
Quoted: 58 Post(s)
Originally Posted by Danslk280 View Post
Hi dedgar,
There are two micro-switches for the trunk lid. They let the system know if the trunk lid is fully closed or not. One on either side of the trunk behind the lining on the sides.
The micro-switch for the roof locking/unlocking the also in the trunk behind the lining on the right side forward of the trunk closed switch.
The system must know that the trunk lid is closed to either start opening the roof or to start closing the roof. If the system does not have closed trunk lid indications, nothing will happen except you most likely will get a rapid flashing red led in the actuating switch in the center console.
The jumper is just a piece of wire. You disconnect the wiring connector from the micro-switch and stuff the wire in the two wiring holes on the connector. That makes the system think that the trunk lid is fully closed because it thinks the micro-switches are closed.
If you decide to go this route you will figure out what size wire you need when you remove any of the micro-switch electrical connectors and look at the two holes. I just used some speaker wire.
I had to use the jumpers because the switches were out of adjustment and the system didn't know the trunk lid was fully closed. Once I determined that was the problem the fix was easy. Just bend the metal arm up a bit and retest without the jumper and the connector reattached to the switch.
This was after I got the roof to actuate and go through a full cycle with the jumpers in place.
Closed to open and open to closed. That way the hydraulics had pressure holding the lid fully closed.
dedgar is offline
Go Back   Mercedes Benz SLK Forum > General Discussion about Mercedes Benz SLKs > New Members Introduce Yourself Here
Tags
vario roof problem
r170 vario roof odd issue ii3 SLK R170 General Discussion 23 08-20-2016 02:00 PM
SLK 250 CDI glass chip in vario roof DanSherbs SLK R172 General Discussion 10 12-26-2015 01:20 AM
R171 Vario Roof Boot Partition Microswitch Issue leastwell SLK R171 General Discussion 9 11-10-2015 05:29 PM
Vario roof operating sequence Tslick SLK R170 General Discussion 6 08-31-2006 10:39 PM
