Trunk Wont open - Top doesnt go down already tried s69/10 grnd - Mercedes Benz SLK Forum
New Members Introduce Yourself Here New members come here first!. Update your profile: model, year and location. Post any issues in the relevant section. The team may then post a link to your issue thread in your introduction. User Name must be in plain text, NOT ASCII
  • 1 Post By jassmix
#1 Old 09-05-2014
Vehicle: 2000 Slk 230
2000 Slk 230
The trunk doesnt open and top wont go down already tried the S69/10 ground but no go - all windows roll down and thats about it
can I ground S69/12 ? is there a DIY or color code?
There is some oil leaking from Top / windshield hydraulic cylinder so Ive tried to open the lock manually with a hex key I can push the Top out of the lock but there is no point because the trunk is stuck
at this point I need to get the Trunk open somehow
the keyhole / push button doesnt do anything and the key doesnt turn
The car doesnt lock / unlock with the remote either -the lights blink probably cause of the trunk
what are my choices? I've read about drilling a hole behind the license but what am I looking for?
really need to resolve
thanks
LIL DON SLK likes this.
jassmix is offline
#2 Old 09-05-2014
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Welcome to SLKWorld.com: The #1 Mercedes-Benz SLK Forum from NE England!
Please update your location/vehicle (model and year) in your profile as it helps the members answer your questions which usually are based on that information. Click on ‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’.
Thank you,
Woolly - Founder & Super Moderator.
Woolly is offline
#3 Old 09-05-2014
Thanks!!
I have been searching for days with no luck hopefully this forum will get me a solution
thanks again
jassmix is offline
#4 Old 09-05-2014
Welcome from New Hampshire, did you check the fues that controlls the PSE?
#5 Old 09-05-2014
I have checked all fuses possible - but which one control's the PSE ill double check.
I tried Wd40 into the trunk lock but the key doesnt turn eitherways
When I press the lock /unlock button on the remote the turn signal lights flash / Dome light goes on/off (3secs) as usual but the car doesnt lock/unlock.
Locking the drivers side door with key only locks that door and not the passenger side. looks like the Pump to me.
but the question comes back how can I open the trunk to get access to everything
jassmix is offline
#6 Old 09-05-2014
There is a small accsess panel located on the drivers side of the dash, ( open door to see panel) remove the panel and look for the 20a fues or just read the card if there is one guled to the back side of the panel.
#7 Old 09-05-2014
There is no 20a fuse its either 15 or 7.5 but they all look ok
jassmix is offline
#8 Old 09-05-2014
Do you see one for the PSE? If you have a new one replace it, i had this issue over the summer and what looked like a good fuse turned out to be bad. If your problem is not solved by replacing that fuse then you can at least cross that off the list of possibilities.
#9 Old 09-05-2014
On the left of the Dashboard there is no fuse 20A - only 15A or 7.5A - but I found central locking Fuse under hood on drivers side fuse box.
I took it out swapped it with another still the same
jassmix is offline
#10 Old 09-05-2014
Sorry my bad, its the 15a should say pse on the card
#11 Old 09-05-2014
I have these two
1 ) this is on the side of the Dashboard ( what you refereed to) but does not say PSE anywhere
2) This
is under the hood left side ( this one has a 26 Central locking fuse )
All fuses look Ok and I swapped a couple
jassmix is offline
#12 Old 09-05-2014
#2 list is what i have, the #1 list is different than mine
#13 Old 09-05-2014
List 1 is from the console side when you open the door #2 has the Central Locking which I swapped already
what now?
jassmix is offline
#14 Old 09-05-2014
hasontour's Avatar
Vehicle: In between slk's!!!
Hi from London,
Welcome aboard!
hasontour is offline
#15 Old 09-05-2014
Quoted: 6604 Post(s)
#16 Old 09-05-2014
LIL DON SLK's Avatar
Vehicle: 2009 SLK 55 AMG White 8 cylinder
Quoted: 146 Post(s)
Welcome from the Sacramento Valley SLK Enthusiasts! I would tow it to a MB dealer and let them figure it out!
Don Owen AKA LIL DON SLK
916/489-6936
If you live in Northern California you can join us for a drive. We meet monthly for drives, road trips lunches. Feel free to call me or email me and I can add you to our email list. I always post events under California here on SLKWORLD.
LIL DON SLK is offline
#17 Old 09-05-2014
Dave54's Avatar
Vehicle: 2009 SLK 350
Chats: 2
Quoted: 82 Post(s)
Welcome from Portland, Oregon.
Dave54 is online now
#18 Old 09-05-2014
jassmix is offline
#19 Old 09-05-2014
I got the trunk open it was stuck so I sat/pushed down and magically the key turned and it opened - the Hydraulic Pump was empty so i filled it
I tried to lower the roof but oil came out of the roof hydraulic, would the trunk open or not regardless of the roof hydraulic leak?
or is it a step by step that it unlocks the roof first then goes to step two of opening the trunk etc
thanks
jassmix is offline
Go Back   Mercedes Benz SLK Forum > General Discussion about Mercedes Benz SLKs > New Members Introduce Yourself Here
Trunk Rattle Solution! B55 SLK R171 General Discussion 100 02-19-2017 08:54 AM
Stopping the top operation before windows go back up phd gator SLK R170 General Discussion 15 11-12-2015 01:34 PM
How to open top to remove the headliner to fix top? Arachnyd SLK R170 General Discussion 5 03-30-2012 01:06 PM
Open side trunk paneling Zeiser50 SLK R171 General Discussion 2 08-18-2007 03:27 PM
