AMG 55 Bumper Trim - Mercedes Benz SLK Forum
General Modifications R172 Details that make your car different
 18Likes
  • 5 Post By GriffSLK
  • 4 Post By GriffSLK
  • 1 Post By b82012
  • 1 Post By Lersy
  • 1 Post By Karlsiemieniuk
  • 2 Post By Lersy
  • 1 Post By Windinmyhair
  • 1 Post By Lersy
  • 1 Post By Avel Du
  • 1 Post By Lersy
#1 Old 05-19-2019
Vehicle: 2012 R172 SLK350 Ed 125
Other Toys: Mini Clubman Cooper S
Quoted: 21 Post(s)
Red face AMG 55 Bumper Trim
Inspired by @Wilhelm Sorban I decided to add the AMG 55 Lower Bumper Trim to my car (my car already has the AMG Sport trim pack).
Before:
After:
I love the new look
More details on fitting to follow ...
GriffSLK is offline
#2 Old 05-19-2019
Quoted: 21 Post(s)
Fitting ...
Fitting is quite straightforward, but you need to get under the car to remove the 'Under Engine Cover/Sump Guard'. I couldn't get ramps under the car as it is so low, so reversed onto some flagstones:
The part number for the trim is: A1728880273 9040.
AMG 55 Bumper Trim-101.jpgAMG 55 Bumper Trim-102.jpgAMG 55 Bumper Trim-104.jpg
8mm socket for the cover bolts, but there are so many of them! This was the part of fitting the trim that took the longest!
There is no need to remove the lower bumper grill as the trim just clips over the bumper and the fitting tabs 'push' through gaps in the grill. You reach inside the bumper to fit the 'rivets' which just push into place, and the clips slide on at the bottom:
You have the get the fittings separately, and they have the following part numbers:
Clamps, to the lower side of the trim: A0049883678 - you need 6 of these
Plastic expansion rivets: A1249900492 - you need 7 of these.
GriffSLK is offline
#3 Old 05-19-2019
b82012's Avatar
Quoted: 288 Post(s)
If you paint or wrap the bottom trim of your stock AMG front bumper, you will achieve same look as you have done here. Jus’ sayn’...
Karlsiemieniuk likes this.
Omo
b82012 is offline
#4 Old 05-20-2019
Quoted: 21 Post(s)
Considered painting but discounted as there would be a 'lip' at the edges due to extra layer of black paint.
Wrapping is an option, but didn't really want to try it myself, and I could do this myself without needing to find someone to fit
GriffSLK is offline
#5 Old 05-20-2019
Lersy's Avatar
Vehicle: Slk 350 AMG Tenorite Grey with Red Leather 2013,X Pipe,Remus Exhaust,AMG front brakes,H&R Springs
Other Toys: Mini Cooper S JCW 280bhp
Quoted: 46 Post(s)
Looks great, ive been considering this, does it just clip over the existing or do you have to remove first?
I've also considered wrapping, but theirs far too many angles for me to attempt it.
GriffSLK likes this.
Lersy is offline
#6 Old 4 Weeks Ago
Quoted: 108 Post(s)
As long as you have the AMG exterior kit, this trim will fit right onto the bumper.
You just need to remove the undershielding, below the bumper, to have access to place the plastic expansion rivets.
Having additional OEM parts > any other look-alike
Wilhelm Sorban is offline
The Following User Says Thank You to Wilhelm Sorban For This Useful Post:
#7 Old 1 Week Ago
Vehicle: Slk 200 AMG line R172 2014
I’m thinking of doing the same modification to my car looks great 👍
Karlsiemieniuk is offline
#8 Old 1 Week Ago
Lersy's Avatar
Quoted: 46 Post(s)
Just fitted the lower trim, pretty straight forward, especially with a battery socket wrench.
Now I need to decide if I want a front splitter or not?
Avel Du and GriffSLK like this.
Lersy is offline
#9 Old 1 Week Ago
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 309 Post(s)
Looking good chaps. One question - do both of the engine undertrays need to come off or can it be done with just the forward cover lowered/removed?
I have one to fit but am currently waiting for two of the spring clamps as, apparently, there are only four in the UK at the moment. Must be you folk buying them all up.
Windinmyhair is online now
#10 Old 1 Week Ago
Lersy's Avatar
Quoted: 46 Post(s)
The rear one overlaps the front, so best to take both off, only 6 bolts in rear, most are in the front any way, the clips are accessible when the covers are on, so you could fit it and slide the rest of the clips on, when they arrive.
Windinmyhair likes this.
Lersy is offline
The Following User Says Thank You to Lersy For This Useful Post:
#11 Old 1 Week Ago
Moderator/RoTMorganiser
Quoted: 2121 Post(s)
Front splitter.
Been debating that on the AMG for a while.
Decided against due to high speed bumps (you need to put one wheel over the ramp to avoid disaster)
and front in parking over kerbs.
Reinforced that decision this week.
Caught the 350 after parking.
Do like the look though.
Lersy likes this.
#12 Old 1 Week Ago
Lersy's Avatar
Quoted: 46 Post(s)
Yes this is the dilemma, as my other half drives the car too.
I think the Maxton one is too low for me, but I do quite like this one.
Lersy is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > General Modifications R172
Where to get amg bumper for r170 Big red* Where to get R170 SLK Items 0 09-28-2014 03:36 AM
WTB SLK 32 AMG front bumper cover Used/cracked xxwikkixx Where to get R170 SLK Items 0 09-21-2014 10:22 PM
Nice AMG R171 style front bumper to R170 Tolak General Modifications R170 1 01-15-2014 09:07 PM
UK R170 AMG SIDE SKIRTS AND AMG or RIEGER FRONT BUMPER vauxhallmaniac SLK Parts Wanted 0 06-16-2013 01:37 PM
