New Glass roof 172 - Mercedes Benz SLK Forum
General Modifications R172 Details that make your car different
 12Likes
#1 Old 11-22-2014
Vehicle: SLK 350 2012
Quoted: 21 Post(s)
New Glass roof 172
Ok so my SLK 350 has a standard roof, and I am tempted to get the top section changed for a glass section. Does anyone have an idea of cost or at least a part number?
I might want to get this done if not crazy money.
Any thoughts?
SLKomatic likes this.
Stark9 is offline
#2 Old 12-02-2014
obi
Vehicle: R172 250 cdi
Other Toys: 2014 all black mini clubman + my little fella ollie the white miniture schnauzer
Quoted: 7 Post(s)
hi mate i have a 2014 slk and mine had the glass roof already on it just came with a full inner roof liner the dealer charged me £224 to remove old line and fit the new liner only took them 15mins to fit
hope this helps
obi is offline
#3 Old 12-02-2014
obi
Quoted: 7 Post(s)
i believe all new slks come with the glass roof now
obi is offline
#4 Old 12-09-2014
Vehicle: Had a 2013 SLK 250 Cdi in F/O red, now have 'Woody' a 2017 A*** TT Coupe in tango red (what else?)
Other Toys: Mini Cooper in Red
Quoted: 152 Post(s)
All new SLKs now come with the glass (polycarbonate) roof. It depends on what roof option you spec. The Std spec just has a solid headlining.
A couple of weeks ago I swapped the solid headlining in my 2 year old car to the one from the pano roof, it's a really easy DIY job.
Part No. A172 790 00 45 9H23
The last part of the number above is the colour code, my local dealer couldn't find the part until they had it.
£195.60 inc VAT
A couple of things to note:
The panoramic headlining comes complete with all the plastic clips, so no need to order new ones seperately or re-use the ones from your old headlining.
The box it comes in is pretty big i.e doesn't fit in a SLK!
bastivock is offline
#5 Old 01-11-2015
Vehicle: SLK 250 AMG CDI (2015) daily driver
Other Toys: BMW M3 cab E93 V8, BMW X5, Ferrari 360
Quoted: 11 Post(s)
£195.60 inc VAT
If it's any help I can confirm that all of the above is exactly what needed. I used the part number to order the panoramic roof lining from my dealer, it came into stock in just 2 days and I collected it yesterday.
My new car is due to arrive tomorrow with the fixed headlining in, my first job will be carefully pulling it out and replacing it with the panoramic lining.
I've taken pictures of the panoramic lining and the box that it comes in, if anyone's interested on more than happy to post them up.
I will also take pictures of before and after from both inside and outside the car.
intothevoid likes this.
jetski jezz is offline
The Following User Says Thank You to jetski jezz For This Useful Post:
#6 Old 01-11-2015
JiminFL's Avatar
As an option on the 2015 cars, the panorama roof is a $2500 MSRP option. This is for the electrically dimming one. I'm not sure about the regular glass (polycarb) one. Seems a little pricey to add afterwards. To me anyway...
JiminFL is offline
#7 Old 01-11-2015
Quoted: 11 Post(s)
In the UK there are 3 different roof options:
1. standard roof which is the clear polycarbonate, but fitted inside with a solid roof lining. From the outside this looks exactly the same as option 2.
2. Panoramic vario-roof - this is the clear polycarbonate but this time fitted with a roof lining allowing you to see through the polycarbonate. This is a cost option at £410.
3. Lastly there is the magic sky option, the one that can turn from frosted to clear in the press of a button. This is a cost option of £1955.
If you buy a second-hand car with the first option or like me if you lease a new car but without ticking option to then you can replace the solid roof lining with a roof line from the Panoramic vario-roof so that you can see through the polycarbonate panel. In the UK the cost including tax £1195 and by all accounts it takes only minutes to swap them out.
#8 Old 03-18-2015
Vehicle: SLK 250 (172) 2011
Any thoughts?
I have a 2011 250 SLK with UK spec. It came with the standard steel centre roof section. I would love to change just the steel centre panel for the glass centre panel, but I am told the complete centre roof section has to be changed, not just the panel, and this costs around £2,500!
Harrington is offline
#9 Old 07-21-2015
pano roof glass for 250slk
Hi! Do you know what the part number is for the glass?
neishb is offline
#10 Old 07-21-2015
Quoted: 6421 Post(s)
I do but you have to update your profile and post an introduction thread
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
#11 Old 07-21-2015
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
Gosh I'm confused. My used 2012 had a plastic tinted roof panel which was changed for free by Mercedes to glass (as fitted to later models) when water leaks couldn't be eliminated.
oldmercman is offline
#12 Old 07-21-2015
yuri's Avatar
Vehicle: 2012 250cdi
Other Toys: 2012 E250 cab
Quoted: 50 Post(s)
I don't get the point of having a glass "sun"roof in a roadster ? Man up and get the roof down guys , I don't include ladies as most I encounter will have the roof down if there is even a slight glimmer of sunshine
jbanks15, wja96 and godfather like this.
yuri is offline
#13 Old 07-22-2015
I understand that MB found it was cheaper for them to fit clear glass roof panels, rather than painted steel ones, to all new SLK's. So the glass roof panel became standard equipment, rather than an option.
If you have an early SLK with a steel painted roof panel, it will cost you around £2500 to have it changed to a glass panel.
#14 Old 07-22-2015
But I'm in UK where it rains every other day and I'm going bald on the back :-(
obi and bastivock like this.
neishb is offline
#15 Old 07-22-2015
Neishb,
#16 Old 09-20-2015
Vehicle: SLK 250 CDI AMG Sport
Other Toys: SL600 R129
Hey, that's great news - I found my perfect car and bought it yesterday. The only option it doesn't have is the pano and I thought I could live with that, but it there is a reasonable-cost option to get that as well I will be very happy
Would love to hear how your swap panned out and if you have the pictures you mentioned would love to see...
Thanks for posting the details about this.
mach2point0 is offline
#17 Old 09-20-2015
Vehicle: 2018 SLC 43
Other Toys: 2013 Lincoln MKT
Quoted: 134 Post(s)
Same boat, my 2012 350 was missing one option I really wanted, the Magic Sky roof or at least the Panoramic roof. But as a special order car, it had everything else, plus a great color. Also a local car with compete history. I gave some thought to a roof swap, but from this looks like you need the roof plus a lot of labor. The Magic Sky would also need wiring done, and IIRC the control is in the windscreen-attached panel, so all that would have to be replaced as well $$$. Such is life when you buy a used, er, pre-loved car. But any lower cost way would be of interest. Maybe the junkyard? That would be pure luck - what are the odds? At least I still have my first aid kit delete option (previous owner must have been pretty confident).
Yeah I know you can drop the top and that's my fallback/rationalization/salve, but a sunroof would really open it up. Why not both?
SLKomatic is offline
#18 Old 10-22-2015
Vehicle: SLK 250CDI AMG Sport 2014
Thanks to the advice on this forum, I've just changed the solid headlining on our 2014 SLK, and we've now got a pano roof. Really simple job and well worth the £200 for the new headlining.
Kubota is offline
#19 Old 12-21-2015
Vehicle: SLK 250 CDI 2013 Palladium Silver
Other Toys: past toys 2 TVR Griffith 500 Le. 1962 Tvr Vixen. 2 Porsche boxsters.BMW Z4MC.
SLK Roof
I'm new to this forum and trying to get my dealer to fit this to my 2013 SLK that I'm picking up on 1st Jan 2016, he says is a big job. can anyone help (I get the feeling he doesn't want to do it and is fobbing me off)
ianm100 is offline
#20 Old 12-21-2015
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > General Modifications R172
jammersp
Glass Roof as standard chrisgorry SLK R172 General Discussion 46 03-31-2014 11:58 PM
Door window mechanism strip-down Tolak SLK R170 class DIY 6 09-13-2013 08:57 AM
New Glass Roof Fitted Rotatus SLK R172 General Discussion 19 08-24-2013 08:17 AM
Driver Window Sticking When Going Up (Video) mgconcierge SLK R170 General Discussion 7 06-03-2013 06:51 PM
