Fitting an Android 8.0 (S200) stereo head unit Ė lessons learned - Mercedes Benz SLK Forum
 27Likes
Old 11-18-2018
mike350's Avatar
Vehicle: SLK350 r171, 2007, factory fitted sports/AMG body kit & suspension, Airscarf, S200 Android head unit
Other Toys: Triumph Spitfire/GT6, Lexus IS250
Quoted: 193 Post(s)
1st, I know this subject has been covered in many other threads but hereís my experience fitting a new head unit.
I had a standard Audio 20 (A20) head unit with a 6 disk changer (No HK and no external amp) but was very disappointed with the audio quality and so had considered fitting better speakers or a dedicated base speaker.
After talking with other members I was told that changing the head unit was easy and gave much better sound from the standard speakers with the rear speakers actually working!
I decided to go for the new Android 8.0 unit from IceBoxAuto as they were recommended by a few users. I was a bit disappointed with almost four weeks delay on delivery with them saying it was due to waiting for new firmware, their Tís n Cís say that the max delivery was 30 days and so in that sense I canít complain.. except the firmware is all from March/April and so they obviously just didnít have stock!
When it arrived, I opened the box and laid out all the part (see pic), I looked for some instructions but there werenít any! I looked again .. but no, not a thing!! Only a small pamphlet on using the unit once installed. OK I thought, Iím a practical guy and have fitted loads of tech in the past, how hard can it be?? As it turned out.. not very
Order of install.
1. Start the car, put the auto in neutral and turn off the engine with the handbrake on.
2. Lift off the gear selector cover (just pull it upwards gently)
3. Unplug the C/S wire from the gear selector
4. Lift out the centre console unit that has the roof and mirror controls (again just pull it upwards gently)
5. Now feed the gear selector plate through the hole it covered so that the console panel can be lifted to the side.
6. Open the lower tray, remove the 2 bung covers and T15 screws, pull out the tray.
7. Pull out the climate control unit and move to one side
8. Remove 2 more T15ís and remove the Hazard switch bar
9. Open the top tray or cup holder, remove the 2 bungs and T15ís, remove the tray.
10. You can now remove the 4 x T18ís that hold in the head unit.
11. Pull the old head unit out and remove the large power connector by rotating the clip that covers the plug.
Youíre now ready to start putting in the new unit.
1st you need to select the correct cable to interface with your cars wiring. Look carefully at the 2 main cables supplied with the new head unit and see which pinout/cables match the ones going into the cars socket. Itís fairly easy to see the difference and just select the one that matches the cars pin location.
Now you have the correct interface cable, move the CamBus reader onto this interface cable (they only supply one reader and plug it onto one of the main interface cables, so you need to move it onto the cable thatís correct for your car and you're using).
Plug in all the other interface cables that came with the unit (it will look really complicated but theyíre just for loads of options like rear camera etc, most donít need to be used).
The only ones I used wereÖ
1. WiFi aerial (I just tucked this under the console)
2. GPS connection (I stuck this under the dash and it gets a good signal)
3. External Mic (I fitted this above the steering wheel as I found the internal mic very quiet)
4. 2 x USB cables (one for my iPhone and one for a USB key with music on, place these somewhere you can reach. I put them in the passenger foot-well netting area).
Lastly, thereís an aerial adaptor that needs 12v ignition power on its blue wire. I connected this to the blue wire coming out of the new radio on the main plug pin 9 which is marked 'aerial wire' , this is the only bit that wasnít ĎPlug n Playí as I needed to solder this. If you donít do soldering, you could tap into the cigarette lighter as thatís also 12v ign power.
Now just put it all back together in reverse order and youíre done. (Don't forget the C/S cable .. everyone does!!)
About 2 to 3 hours work all in.
Once installed, here are a few things Iíve found out ..
1. Donít switch on the Ďloudí option if you stream music from your phone, it kills the quality! Leave ĎLoudí turned off and just use the equaliser settings to change the sound quality to your liking.
2. Others have said about the glare and reflection off the screen. I ordered a ĎMatteí finish screen protector for an iPad and cut it to size using a sharp modelling knife (donít use scissors as this will bend the plastic). This has completely fixed the issue with reflection.
3. The sound quality is SO MUCH BETTER why did Merc cheap out so much on the head unit??!
Was it worth it? Quite simply .. YES!
It really was easy to fit, but a few fitting instructions / guides really would have made it easier (This is why Iíve just written all this up!).
I now have a modern head unit with Bluetooth audio and streaming, CD/DVD/USB music options, Sat Nav and hands free phone calls plus the option to add other Apps if required.
Hope this helps anyone looking to do the same upgrade.
Mike
jbanks15, Bleen, Trev5 and 11 others like this.
Mike
It's the journey that matters, not the destination.
Modifications ..
Tinted rear lights, Chrome bonnet fins, LED DRL/fog lights,
S200 Android head unit, Paddle shift installed, dash cam,
Resonator boxes (2nd Cats) removed, smart top.
mike350 is offline
The Following 4 Users Say Thank You to mike350 For This Useful Post:
Old 11-18-2018
Moderator/RoTMorganiser
Quoted: 2113 Post(s)
Something I keep considering and will no doubt succumb to one day (even Luddites upgrade).
I need to keep my open at meets to see one of these in action.
Thanks to you, I now have a local supplier too.
Icebox are 15 mins away.
(SWMBO will be happy. No point in doing this without upgrading the phone).
mike350 likes this.
Old 11-19-2018
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 121 Post(s)
Interesting! What steering wheel controls are active? I just fitted an Android 8 from Seicane. My Dynavin went wonky and I got fed up waiting for their UK and German agents to reply. Frankly I was not going to spend £750 on their new model so I figured the Seicane at half the price was worth the risk and even if it does come from the other side of the world, they cannot be less after sales friendly than Dynavin surely. This thing is infinitely more versatile, has a higher quality screen than the newest N7 Dyn, I get album art on FLAC, station icons on DAB and you can practically tweak even the smallest detail, even the sound volume when the reversing camera comes on. With the Dynavin I realised I was hardly using the phone buttons and only used the Home button to change from music to DAB. I rather fancied the huge screen and it really is over 8" diagonally too. It's only been a week and I'm still trying to sort out the SWC. Have at least got volume control.
osi is offline
Old 11-19-2018
Vehicle: MB SLK 350 2006 Black
Other Toys: HD XLC 1200
Just bought SLK two months ago so I am going to leave everything stock until I understand how things work. I would like BlueTooth or at least an AUX IN so I leaped on your post regarding a new head unit. Thanks for the INFO. Allen
Old 11-19-2018
mike350's Avatar
Quoted: 193 Post(s)
Hi.
Itís the phone and volume buttons that work, thatís why it has the cambus reader.
BTW, that looks like a nice unit you have fitted and I like the wood dash as well 😄
Mike
Modifications ..
mike350 is offline
The Following User Says Thank You to mike350 For This Useful Post:
Old 12-12-2018
Vehicle: SLK 200 Kompresor 2005 R171
Other Toys: Motorcycles
guys does the left buttons on steering wheel work with seicane radio ?
I am thinking about next/prev station ?
Also does LCD shows what station is playing/ name of song from sd card / navi instructions are shown ?
I am thinking about buing this set up but nor really sure if everything is working
LIL DON SLK likes this.
Moro99 is offline
Old 12-12-2018
osi
osi's Avatar
Quoted: 121 Post(s)
The left button will advance or retard tracks on the built in player but not on my downloaded Poweramp app. Likewise with the inst cluster display which shows track time and number but not name and only on built in player. This is a bit of a bore on an otherwise excelled piece of kit. I'm still researching a workaround on this. Cannot change DAB stations either. Volume and phone buttons are fully functioning.
Maya via Tapatalk
osi is offline
Old 01-06-2019
mike350's Avatar
Quoted: 193 Post(s)
Three weeks later...
Hi, just thought Iíd add an update after using the new head unit for a few weeks...
1. Iím still very happy with the unit and impressed with the better sound quality.
2. Iíve found that my Ďsmart topí menu still works (mine is actually an Xcar-style unit) via the dash menu even though they say it needs an OEM head unit to enter the menu.
3. The DVD/CD, radio and MP3 all work via the steering wheel buttons for next/previous tracks after you first select the original radio menu option.
4. Out of the box, selecting reverse brought up a blank screen with a note saying Ďno cameraí... so I just had to fit one!
Was it worth fitting the camera?... no, not really as I already have the standard parking sensors and feeding the cable from the rear to the front was a complete [email protected]!! But the camera is now fitted and works very well. I might now look at a front camera as the head unit also supports this.
5. The only downside so far... the Bluetooth phone isnít as clear as the original OEM unit and this might be due to the mic supplied, which at the moment Iíve fitted between the speedo and rev counter. Iíll try moving this up into the overhead light unit where the OEM one is located.
So, overall still very pleased and well worth fitting.
Iím also getting very good at pulling the dash apart
Iíll try and post a picture of the unit soon, showing the matte screen and how there are no reflections.
Mike.
Trev5, Avel Du, RNVSLK and 1 others like this.
Mike
Modifications ..
mike350 is offline
Old 01-25-2019
Daniel Chambers's Avatar
Vehicle: 05 slk55 in silver
Other Toys: 86 mini
Would this unit work with the Harmon kardon speakers?
Daniel Chambers is offline
Old 01-25-2019
mike350's Avatar
Quoted: 193 Post(s)
Hi Daniel.
If you check out the website that I purchased from www. IceBoxAuto.com they say to contact them if you have an external amp.
My car was fitted with the base A20 unit and so it was an easy swap. I suggest you call them and see what they say.
Mike.
Mike
Modifications ..
mike350 is offline
Old 01-25-2019
Other Toys: 86 mini
Hi Daniel.
Mike.
OK thank you
Old 02-04-2019
Vehicle: 2008 SLK 200k
@osi may I ask where you purchased the Seicane? I just bought a 08 SLK 200k and with Audio 20 and plan on replacing it ASAP, I have been looking on ebay, icebox auto and aliexpress, the only place I can find the model you have is aliexpress and would appreciate any advice you have on where to get it or extras to purchase with it, thanks.
seamusblanco is offline
Old 02-04-2019
osi
osi's Avatar
Quoted: 121 Post(s)
Here's the link https://www.seicane.com/2-din-head-u...350-slk55-c096
Had it about 4 months now and hasn't put a foot wrong. Had a Dynavin before and it went kaput. I certainly wasn't going to pay £750 for a new Dynavin when their aftersales service is non existent. The Seicane is vastly superior in every way to the latest Dynavin and will bring your SLK right up to date I'm sure!
Seicane will ship to their UK warehouse so you won't pay duty and it came to me well packaged via DPD.
Happy to help. Good luck!
Maya via Tapatalk
osi is offline
Old 02-06-2019
Thanks @osi I went ahead and ordered that! Looking forward to getting it now although they seem slow enough in getting started
Old 02-06-2019
osi
osi's Avatar
Quoted: 121 Post(s)
Mine took over 3 weeks but I did unfortunately order right in the middle of a Chinese holiday. Their admin may leave something to be desired but the product appears to tick boxes that other manufacturers ask twice the price for. At that price I'm almost inclined to order another one as backup! There's loads of useful apps including an excellent home launcher. I'll get some pics and post.
Maya~Tapatalk
osi is offline
Old 02-06-2019
Would love to see some pics of it installed please, 3 weeks isn't too bad, just got the slk so have a service and full valet to do in it in the meantime
Old 02-07-2019
osi
osi's Avatar
Quoted: 121 Post(s)
Have put some pics and comments under General Mods R171.
Maya~Tapatalk
osi is offline
Old 03-27-2019
Vehicle: 2006 SLK280 6mt
Other Toys: 2000 Jaguar XK8, 2008 Audi A6, 2007 Audi Q7 4.2
Quoted: 24 Post(s)
Can you use the nav while listening to bluetooth?
Johns12 is offline
Old 03-28-2019
mike350's Avatar
Quoted: 193 Post(s)
Not sure who you were asking, please quote a post or use @username to direct your question.
If this was for me, then no. This seems to be the only shortcoming I’ve found. Bluetooth music from my phone will only work once the phone menu has been selected (unless I’m doing something wrong!).
I use a USB key for my music so it’s no issue.
I might have a play this weekend to see if there’s an option for Bluetooth music from any menu screen.
Mike
Modifications ..
mike350 is offline
Old 03-28-2019
Hi @mike350 sorry to annoy you with this, but I finally received my unit from seicane (6 weeks! ) and I cannot get it to power on. I moved the canbus to the correct harness that fits the default car wires block but when I turn on ignition there is no power to unit and it just displays "Audio ----" in the car display below the speedometer.
I noticed in your earlier posts you said "thereís an aerial adaptor that needs 12v ignition power on its blue wire" is this required to power on the unit? If so that must be where I am going wrong as I dont think the cables I received wire up the power correctly to the unit through the harness.
Any advice? Seicane support has been pretty poor thus far,
thanks in advance.
Replacing head unit in BOSE system goes smoothly jbkufahl General Modifications R170 12 01-18-2017 03:16 AM
Aftermarket Stereo (Replacing Head & HK): Summary and Verifications Tango SLK R171 General Discussion 8 08-29-2016 10:43 PM
Comand NTG1 Stereo head unit, from 2006 AMG SLK55 A_G SLK Parts For Sale 1 09-15-2015 05:29 AM
New stereo head unit northernlights SLK R170 General Discussion 2 08-15-2015 09:45 PM
"cool" touch screen stereo installation in less than 5 minutes for under $200 Arachnyd SLK R170 General Discussion 30 07-24-2013 06:08 PM
