2 easy (and common) mods... - Mercedes Benz SLK Forum
  • 1 Post By jameslk55
#1 Old 01-25-2011
Vehicle: 2007 R171 SLK280
Smile 2 easy (and common) mods...
Over the weekend I installed clear side marker lights and a matching pewter shorty antenna. Neither one is earth shattering and you've all seen them before- but I think they both offer modest, tasteful improvements in the looks of the car. While I was snapping pics in the garage, I couldn't resist taking another of the nose of the car too. Ahhh..... beautiful! It became my avatar!!
Boompa Steve is offline
#2 Old 01-25-2011
Just a regular guy
Gmonslk's Avatar
Vehicle: 2007 SLK 280
Other Toys: 2015 Tacoma Prerunner SR5 (towing and shuttle activities) 2015 Lund fishing boat
Quoted: 30 Post(s)
Where did you get the shorty pewter antenna? I did the side markers last summer, as well, very easy with a good effect, I'd say.
Living a dream..........
Part 2.
Gmonslk is offline
#3 Old 01-25-2011
Quoted: 344 Post(s)
It's an SL-type antenna (R230). IIRC, there are aftermarket ones at ebay but don't know how good they are. Prop Dr also posted some photos and links I recall. Also, check the DIY section on modifying the shorty R170 antenna, there are some photos of the SL type antenna too in that thread.
#4 Old 01-25-2011
As etyu suggested, this one came from Ebay...
http://cgi.ebay.com/ebaymotors/Merce...ht_1686wt_1167
This is an OEM Mercedes antenna for SL cars; fits SLK perfectly.
Many have suggested the shorty antenna will never offer as good a reception as the full-length but it really doesn't matter to me. I haven't tested it yet (car is in the garage with 8" of snow on the ground outside. ARGH!) but I actually don't EVER listen to the AM or FM radio in any of my vehicles- only Sirius, XM or CD so I don't really care how well it works- purely cosmetic in my case.
#5 Old 01-25-2011
Just a regular guy
Gmonslk's Avatar
Quoted: 30 Post(s)
Same for me, including the snow. I am modding my way through winter.....lets call it therapy. Thanks
Part 2.
Gmonslk is offline
#6 Old 01-25-2011
Ynot's Avatar
Quoted: 23 Post(s)
Remove the base of the antenna and have it painted to match the car, will look much better.
997 TPC turbo C4S
981 Boxster S
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. (Gone but not forgotten)
Ynot is offline
#7 Old 01-25-2011
Quoted: 344 Post(s)
The range for using remote key (radio frequency) will be reduced to 10 meters, unmodified. Modified, the range can reach 30 meters. I don't know how the ones from ebay perform.
#8 Old 01-25-2011
Vehicle: SLK
Looks great. My slk is black so I've been considering the smoked version. How was install? Steps? Did you have to remove the bumper?
jrs650 is offline
#9 Old 01-25-2011
Quoted: 6296 Post(s)
there is a diy for the procedure
https://www.slkworld.com/diy-section/...procedure.html
Wavetrac LSD thread here:
#10 Old 01-25-2011
Thumbs up
I read one or more of the helpful "how to's" here on SLKWorld which helped, but in the end only getting in there with a trouble light and a dirty hand makes sense of it all.
First one (passenger side) took about 20 minutes total as I unbolted 2 bolts to loosen the inner fender liner and removed the single Torx bit holding the light in place. Twist and remove the bulb/wiring and then POP out the light and lens to the outside of the car after releasing the single tab lock. Then the lens "hinges" and opens like a clamshell. Reverse and you're finished.
The second one (driver's side) I didn't even use a shop light or look up in there- just sat cross-legged next the sidemarker light and reached around/in with my right hand did it all by feel, after having "seen" it all the first time. 10 minutes max for the 2nd light.
From getting out tools to washing hands afterwards was no more than 40 minutes- piece of cake.
Just don't FORCE anything as you can break plastic tabs and brackets!!
#11 Old 01-25-2011
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 17 Post(s)
Clear sidemarkers (w/ chrome amber bulbs) are a first great mod but I think the smoked sidemarkers on eBay would've looked better-especially with your headlamps. I have them on my SLK-they're a lighter smoke color than my old clear sidemarkers with colored tint film.
Minstrel likes this.
jameslk55 is offline
#12 Old 01-26-2011
Chats: 4
The antenna looks really nice! We have the clear marker lights for both the R170 and R171 model SLK's in both clear and tinted and the modified short antenna for our new members.
http://www.slkstore.com/home.php?cat=273
SLKStore is offline
#13 Old 01-26-2011
Quoted: 344 Post(s)
Think about the "aluminum foil" method to cover the 3 holes that are still evident on the clear side marker. Only if you're bored on a Sunday afternoon.
#14 Old 01-26-2011
Oooohh.... wish I'd thought about THAT while I was in there. Well... should be easy enough to do!!
#15 Old 01-26-2011
Vehicle: 2006 SLK55 AMG (SOLD) & 2006 SLK 280 (SOLD!!!)
Other Toys: 2006 SLK55 AMG (SOLD),2015 Lexus RC-F, 2013 Lexus LX570, 2013 Lexus RX450h,2013 Lexus CT200h, gla250
I second this. I bought two of these from eBay (I don't remember which vendor, but it was a lot lower than the one mentioned here).
The range on the remote is MUCH reduced and so was the radio reception. I don't really care for the radio reception. But the remote range is only like less than 5 feet!!!!
I remembered there was a post on how to modify the shorty antenna? Anyone know??? Thanks.
netmiami is offline
#16 Old 01-26-2011
do a search for 'modify antenna' 2 hits for r170 antenna
#17 Old 01-26-2011
Quoted: 344 Post(s)
Here's the link by Brent: https://www.slkworld.com/diy-section/...html#post54385
Just be careful of the tiny tube that mates with the central wire at the antenna base. The tube on the OEM SL antenna is very soft and prone to break easily when one screws down the antenna too tight or if it gets misaligned by just 1mm. I still prefer the R170 "shorty" antenna.
Mods on my SLK 350 : need your help... kalani General Modifications R171 3 05-13-2009 01:00 AM
