Rewriting SLK320 ecu with the M112E37 3.7 engine map - Mercedes Benz SLK Forum
  • 1 Post By Sir_Wizington
#1 Old 3 Weeks Ago
Vehicle: 2001 SLK320 auto
Over the winter I plan on buying and rebuilding a 3.7l M112E37 engine from an SL350 and swapping the stock 3.2 M112E32 engine for it.
The 3.7 litre engine only differs in bore size and fuel injector size to the 3.2l every other aspect, bolt locations, wiring loom, ecu version, compression ratio is the same.
I want to either
A: have the engine hex file for the M112E37 flashed onto my current ecu. Both cars use Bosch ME2.8 and the same TCU etc so the hardware is compatible just need the correct engine map put on to my ecu because you can’t swap different ecus into different cars as they are coded to only work with the car they came with.
B have my 3.2 engine file re written to account for the different size fuel injectors and fuel trims.
Apparently you can run the 3.7l engine on the 3.2 engine map and they ecu will adjust the fuel trims using the lambda sensors.
So basically I’m asking how do I get the ecu to have the correct info on it to run the 3.7 l m112.
My plan is to have a 300hp NA V6 r170. I don’t want to do a v8 swap because of cost and complexity. The v6 3.7 swap is much easier apart from the ecu issue mentioned above.
Yeah I could buy an SLK350 but that’s just too easy 😂
Can anyone shed any knowledge on the subject?
M4rCu5 likes this.
Sir_Wizington is offline
#2 Old 3 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
If you want to read me2.8 you need to open the ECU and read it with K-tag
https://www.aliexpress.com/item/Prom...8cf5ab0b6327-0
Then you can try to write on your ecu ( i have a hutch that you will not be able to do that due to hw error )
Or you can read you ecu and have someone do the tuning for the bigger injectors.
Or you can find someone who has an original file for your ecu, tune that and write via obd using kessv2 ( ktag is bench open ecu, kess v2 via obd ) This is a less risky option.
i860 is online now
#3 Old 3 Weeks Ago
I think that the best option is to use the ecu for the 3.2 and have it remapped for the 3.7.
The only diffrence should be fuel injector size settings. As he compression ratio is equal, cams, intake valve size etc etc is all the same the only diffrence would be more air and fuel need to go in. One the ecu has been reprogrammed to work with the larger injectors in the E37 engine surely it would just use the lambda sensors and MAF sensors to calculate the new fuel trims so it runs at the correct AFR.
So I guess if I take it to a reputable merc tuner and have a wide band o2 sensor installed they could change he ecu to work with the larger injectors and use the wideband to check its running the correct AFR. you can see all the ignition timings trough OBD2 and just check it’s running normally. Possibly a dyno run to see if is making the 245 HP ish the 3.7 is suppose to make.
Can anyone else think if any other potential issues?
#4 Old 3 Weeks Ago
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
take your 3.2L ME2.8, remove the immobilizer chip and install it in the 3.7 ECU.. then just use the 3.7 ECU.
@Dave2302 might have some ideas too.
edit:... just thought about this.. you will have some problems because that 3.7 ECU is from an SL. therefore you might need to modify Your ECU.
Turdo2 is offline
