Oil catch can install on my 200K - Mercedes Benz SLK Forum
#1 Old 01-25-2019
murat orhan's Avatar
Quoted: 26 Post(s)
What ever I did (including, a completely new PCV system, cleaning the oil sep, IC, intake man., hoses, MAF etc.), I could not stop oil reaching past my IC and to the MAF, which I want to keep bone dry.
Although, the engine shows no signs of wear and the compression in each cylinder is good, I have good amount of oil vapour. I think this is a design flaw with the M111 engine or it's just my heavy right foot.
Anyway, I decided to install a catch can between the valve cover breather and the oil sep. So even if the catch can does not filter %100, the original oil sep. will have to deal with very low levels of oil compared to direct connection.
Please check out the place I prefered to bolt the can. Very easy reach to empty it.
Your comments are welcome for a better place.
https://youtu.be/EX6QdzZs10A
I've to find a solution for the hoses because the original breather hose ID is 3/4" while the fittings on the can are for 1/2". I plan to use a clear tubing for the outlet to see if any oil leaves the can. I also not decided if I want to keep the small tubing from the SC which is probably for blowing over the oil mist to help it condensate.
murat orhan is offline
DIY Oil Change for SLK350 with Pictures slk350ncls63 SLK R171 Class DIY 100 03-10-2018 08:22 PM
DIY Oil Change and Lessons Learned geophysicist SLK R170 class DIY 37 10-29-2017 12:52 PM
2009 SLK 350, Mobil 1 0w40, Oil Analysis mb911 SLK R171 General Discussion 4 06-19-2014 02:34 AM
Oil catch can / oil catch tank Jayzen SLK Parts For Sale 6 07-25-2013 11:43 PM
Well known 2005 SLK350 oil consumption (continued) rubenh SLK R171 General Discussion 15 10-31-2011 02:51 PM
