First mod...minor, but essential...USB power socket. - Mercedes Benz SLK Forum
 5Likes
  • 3 Post By jdfensty
  • 1 Post By Gimme Shelter
  • 1 Post By Avel Du
#1 Old 10-31-2018
Vehicle: 1999 SLK230 Kompressor. 4th owner. First MB.
Other Toys: 2000 Ford Mustang GT 'vert, future uncertain. 2011 Nissan Rogue "Family Truckster."
Arrow First mod...minor, but essential...USB power socket.
Heya!
So, first mod to Frau Kompressor...as far as I can tell, first mod of any kind to the car, actually.
(I did change out the factory head unit already, but that hardly counts as it was slide out/slide in and done in 5 minutes...no real modification needed.)
Minor thing, but essential considering I have a tablet for Torque readouts and an old cellphone as a dashcam...this $8.75 (eBay) dual 2.1A USB power socket install. (Like most small, generic electronics on eBay it can be had for less than half that, IF you're willing to wait on the 'slow boat from China' and take 6 weeks instead of paying for a US seller.)
I think it looks pretty good...the color is a near match for the orange dash lights (see night image, LOL) and the spot is perfect, fits exactly with no clearance issues underneath or to the sides.
If you knew me and my Dremel ability (read: none/zero/nada) you'd realize what a big deal it was for me to drill into the panel that I knew I'd never find for sale to replace for less than a couple hundred bucks....because I needed a 1 3/16" hole and the largest hole drill bit I own is 1" so I figured (since the trim ring extends another 1/8" or so and would cover any unevenness) I could Dremel it juuuuuust enough to fit without having to visit Home Depot.
Often such bright ideas lead to bitter failure and the refrain, "I'll never do THAT again" but this time...looks good, eh?
I elected to keep this one 'switched' (not much choice, since it's lighted all the time, no separate dimmer connect for $8) but while I was in there rootin' around, I did make the lighter socket up by the handbrake 'always on' since sometimes I do want to plug in a USB charger there to keep the aforementioned electronics charging overnight if I know I'll use the car again in 24-48 hours.
To do that I actually put the original cigarette lighter socket power leads on this one, and tapped into the 'constant power' for the radio for the new power to the lighter socket.
You could almost imagine it was a factory option, if I do say so myself.
Next up....headliner replacement. I should be so lucky that it goes this well....
Avel Du, LeonardoDaBenz and Coopz like this.
jdfensty is offline
#2 Old 10-31-2018
Vehicle: 2009 SLK 2Look
Other Toys: Ford Fiesta Titanium 3Dr, Porsche 944S2
Quoted: 100 Post(s)
If your 'mod' is protected by fuse/breaker/overload then well done!
Gimme Shelter is offline
#3 Old 10-31-2018
Coopz's Avatar
Vehicle: '04 SLK350 R171
Quoted: 20 Post(s)
Great job! Looks like it came like that from the factory! I can imagine it would have been pretty nerve wracking to drill that hole!
I've recently "installed" something similar. I say "installed" as I merely screwed it in to plug the hole left in the passenger footwell where my 12V socket should be on my R171. It's one I had lying around that has 1xUSB and 1xAUX. The AUX is superfluous though as I already have one wired in the glove box. I may try and find one like yours with the 2 USBs as this would be more useful, especially with them each being 2.1A.
I haven't got round to wiring mine in yet, still pondering exactly how to do it as I want to install a 12V socket too and possibly fit a USB somewhere around my centre console. I did wonder about fuses too, but I figured the wiring from the old 12V socket will already be connected to a fuse, right?
Coopz is offline
#4 Old 10-31-2018
Quoted: 2206 Post(s)
https://www.slkworld.com/general-dis...-fuse-slk.html
Coopz likes this.
Avel Du is online now
#5 Old 11-01-2018
It is, since I just re-used the 'original' cigarette lighter socket wiring, since I needed this to also be 'switched' with the ignition key off, it made the most sense and that way I know the amp rating is good/fuse is properly rated.
For the original lighter socket, I did just 'tap into' the constant power line for the audio head unit; BUT since I'm always on the safe side (and always blowing those damn lighter socket fuses in any car I've ever owned) I put an additional in-line 5A fuse in that wire which should, theoretically, blow first if (when) I drop something metal into the socket....
I went 5A since I never actually put anything with any major amount of draw in that socket anyway - except, as mentioned, when I drop something metal in the stupid thing.
JD
jdfensty is offline
#6 Old 11-13-2018
Vehicle: 2002 SLk 320. 2002 SLK32 and others that don't relate to this group.
Other Toys: 1971 Porsche 911, 1981 BMW R80gs, 1969 BMW R60/2, 2013 Smart Electric, various Mercedes.
Quoted: 17 Post(s)
The same unit is available also from Amazon with a voltage read out between the two chargers.
I got one with dual 2A USB ports and blue voltage readout and replaced the stock lighter with it.
I later began having intermittent dying issues and noticed that if the voltage on the readout dropped below about 12v that the engine would die - testing the alternator showed that it had low output under load and I replaced it. You can also see the drop as different accessories are turned on, wipers, heater blower, engine cooling fan, etc and see if any of them are drawing so much that they are draining the system...
The volt gauge is a great diag tool.
https://www.amazon.com/MOTOPOWER-MP0...harger+voltage
Christopher Goodwin is offline
Cigarette lighter/ auxiliary power socket JonB SLK R171 General Discussion 31 02-18-2018 12:30 PM
Power Pedal Mod Review – SLK 350 R171 MT Serious Performance MODS for the R171 6 10-24-2015 08:35 AM
Cheap power mod? Big red* SLK R170 General Discussion 2 11-15-2014 12:14 PM
My first mod, iPhone mount and power Wildrider49 General Modifications R171 3 07-10-2012 12:52 AM
2010 J.D. Power survey results Santamonica SLK32 General Discussion 8 06-23-2010 01:51 AM
