The World's First LS Swapped SLK! - Mercedes Benz SLK Forum
 77Likes
#1 Old 04-05-2018
revmatchtv's Avatar
Vehicle: 2000 SLK, V8 swap project
Quoted: 13 Post(s)
Cool The World's First LS Swapped SLK!
My GTO - Mercedes SLK unholy union is a thing!
I've started a brand new build. I'm swapping an LS2 from a Pontiac GTO into my 2000 SLK.
My SLK is pretty trashed so it's time to do something pretty unique. It's totally inspired by Aaron who posted his 4.3L swap here.
Iíve got Frankenstein vibes and Thorís hammer mechanic skills. This canít be good!
This is a huge project for me and I'm putting tons of work into it and documenting every step. I sincerely hope you enjoy it and let me know if there's something you'd like to see or know as I work on this!
Eric
revmatchtv is offline
#2 Old 04-05-2018
Quoted: 187 Post(s)
Very cool! It will be a blast when done. LS swap all the things!
jet_fl is offline
#3 Old 04-05-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
I hope it works when I'm done with it! I'm actually super stoked to do this build. I'm looking forward to the fabrication and creating something no one has done before. It's all about the journey!
#4 Old 04-05-2018
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 332 Post(s)
So is this the official build thread??
It looks like you could use the steering rack from that GTO... except for the part where the steering wheel spins on it's own?.... depending how that engine fits in there, you might be able to keep the steering box.. I would say test fit the engine and see.
Should be fast if you can keep it between the ditches!
Turdo2 is offline
#5 Old 04-06-2018
Vehicle: 2009 CLK 350 cab
Quoted: 126 Post(s)
Why are you starting with such a POS for a donor car? You're gonna spend a ton on the interior, body work and top etc. You're in LA and surrounded by tons of cheap slks. Here's a few: https://losangeles.craigslist.org/la...544005705.html
https://losangeles.craigslist.org/sg...544000033.html
https://orangecounty.craigslist.org/...523826381.html
Even if you're donor car is free, these would save you money. Not trying to be negative. I completely dig the idea. I did some of this stuff back in the 70's. Stuffed some 215 cu inch olds aluminum v8s into MGBs. It was a lot of work but big fun.
7 1/2%Solution likes this.
Mn car guy is offline
#6 Old 04-06-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
This is the official build thread yup.
I’m starting with a POS donor car because it’s a manual and it’s just a little bit easier to do the swap with the pedal box already in place. The car came with a spare dash so it’s not too difficult to fix the interior.
Turdo2 what steering rack did you use for your swap? The GTO rack is damaged so that’s probably not an option. The Mercedes has a really oddball rack to begin with and is not like most other cars I’ve seen.
#7 Old 04-06-2018
Turdo2's Avatar
Quoted: 332 Post(s)
Iím starting with a POS donor car because itís a manual and itís just a little bit easier to do the swap with the pedal box already in place. The car came with a spare dash so itís not too difficult to fix the interior.
Turdo2 what steering rack did you use for your swap? The GTO rack is damaged so thatís probably not an option. The Mercedes has a really oddball rack to begin with and is not like most other cars Iíve seen.
Your SLK has a steering box with rolling-ball type steering. It protrudes into the engine bay a decent amount. The rack I'm currently using is from an E320/430 sedan. I used it because the 2 mount points were in front of the rack and i knew it cleared because the 4.3L came in those cars. But I'm learning that it feels a little too lazy on the car and am contemplating finding a better rack from another car.
Turdo2 is offline
#8 Old 04-06-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
Sounds like you're finding the steering ratio too slow? I assume that this will be one of my biggest challenges with the swap. The engine is nearly as wide as the engine bay, but I plan to use block hugger headers. They are common on the LS.
Let me know what you find with the steering rack. It's going to be one of the early things I tackle.
#9 Old 04-06-2018
Moderator/RoTMorganiser
Quoted: 2130 Post(s)
Looking forward to seeing how this goes.
I love builds.
Such threads are places for learning, whether you agree with them, or not.
Good luck.
Oh, see my pm.
#10 Old 04-06-2018
Turdo2's Avatar
Quoted: 332 Post(s)
I Think the LS will fit perfectly fine. pushrod engines don't have as much height or width due to not having camshafts above the cylinders. That's why i'm thinking maybe you'll be fine with the current steering box.. just put that engine in there and see how everything fits!
Turdo2 is offline
#11 Old 04-07-2018
1978L82's Avatar
Vehicle: 1998 MB SLK230
Quoted: 111 Post(s)
I too will be intently watching this. I've been absent from this forum for a while because a few months ago my SLK went out of commission. Long story short.... my Mercedes had to make the ultimate sacrifice .
So, needing a new motor (not really, I can rebuild this one, but I'm jealous of all these V8 guys popping up), I've decided to go either LS or SBF. Turdo2's thread has shown that fitting the Mercedes V8 on mine would require more metal work than I'd like because I have a 4cyl pre-facelift. However, his only issue was the steering box because of the motor's width.
Because of this, I will be watching your thread closely. I am very curious if the LS is thin enough that the steering box would have no interference. If not, a 302 is even thinner and maybe that would work. I can get a running 302/t5 combo donor mustang around $1000 or less and would only have to focus on mounting and wiring if the width allows it. Plus, the 302 already has a front sump pan.
So from what Ive read, an LS should be about 25" wide from manifold to manifold. A 302 should be around 24". Turdo2, can you measure the Mercedes width? I'd like to have the width for reference. Revmatchtv, check your oil sump location. I think you'd need front like the mercedes v8. Also, let me know if that trans fits. I know these cars have small tunnels. If it doesn't, you may need to settle on a t5 like me. Camaro's had T5 WC that can be adapted to fit an LS. I only have my eye on it because it's such a small trans and I anticipate fitment issues with anything larger. Good luck, I hope this goes well!
Idiot101, Avel Du and revmatchtv like this.
1978L82 is offline
#12 Old 04-09-2018
Vehicle: 2000 SLK230 Sport
Quoted: 13 Post(s)
how on earth are you going to get traction?
ikseisup is offline
#13 Old 04-10-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 519 Post(s)
Simple - Just tack in another piece of GM hardware...
Avel Du, ps33fount and revmatchtv like this.
Terminal is offline
#14 Old 04-10-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
I've measured and it will definitely fit in the engine bay. The big question of course is the steering system. I've got roughly 1" to spare with the stock LS headers. I am planning to use block hugger headers, so if I'm lucky, they will fit with the oem steering rack.
I'll see how the stock T56 fits. It doesn't look huge, but I know the Mercedes tunnel is narrow. I go the engine out of the SLK last night and i'll have a video up in a couple days on that. Next up is to yank the LS. I should be able to do that this weekend. Then the fun really begins!
Someone mentioned traction? I'm not worried about traction as I'm planning on doing some body work to get wider rubber. It's all a process...
#15 Old 04-10-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
Has anyone swapped in an AMG LSD into an earlier R170? The stock diff is pretty tiny and I need an LSD for the kind of torque the LS puts down.
#16 Old 04-10-2018
Vehicle: 2005 R171 SLK55.
Other Toys: 2019 GLC 250, 2013 SS Camaro. 2009 Renault Clio <le sigh>
Quoted: 156 Post(s)
now this certainly sounds interesting! I know that the conventional wisdom in the US is to put an 8" Ford in the back - however I'd imagine that this wouldn't really work in this application (needing an IRS and all?)
waylander is offline
#17 Old 04-10-2018
revmatchtv's Avatar
Quoted: 13 Post(s)
My donor car is a 2006 Pontiac GTO with an IRS. When I pull the drivetrain, I'll see if it it will fit. I somewhat doubt it, because the GM diff appears quite a bit bigger, but I'll certainly give it a shot. It would need some custom mounting.
ps33fount likes this.
#18 Old 04-10-2018
1978L82's Avatar
Quoted: 111 Post(s)
There is a company called wavetrac that made LSDs for SLK32s. If not, you can find similar differentials in most w202s, chrysler crossfires, and maybe a few e-classes but not sure of the years. The c-class rear is supposed to be near identical though, so that would be your best bet.
And waylander, the 8" is decent, but the ford 9" is legendary
Idiot101, ps33fount and revmatchtv like this.
1978L82 is offline
#19 Old 04-10-2018
Turdo2's Avatar
Quoted: 332 Post(s)
I don't think even the AMG cars (of this era at least) come with LSD. If you found a way to use that GM diff, that would make this car VERY strong. plus I imagine there are aftermarket LSD kits for it.
If someone wants to do some eyeballing, this is how much room on each side of the engine there is. I can actually remove the exhaust manifolds while the engine is still in the car.
Turdo2 is offline
#20 Old 04-11-2018
Elmer Fudd's Avatar
Quoted: 187 Post(s)
a bit off-piste, I know
but given the ease with which you transatlantic types both purchased and trashed r107's, the diff in a 500SL, and a 560SL came with 25% mechanical LSD as standard. The dimensions can't be too far adrift from the SLK's. Just thinking out loud, even though it is near-blasphemy to my r107-owning ears...
Elmer Fudd is offline
2008 Mercedes SLK Accessory Lineup Announced alroumi SLK R171 General Discussion 7 02-20-2008 06:26 AM
