Make an SLK230 1998 quieter? - Mercedes Benz SLK Forum
  • 1 Post By Turdo2
  • 1 Post By Naja
#1 Old 01-29-2018
cubwatson's Avatar
Vehicle: SLK 230 1998 Base model
Other Toys: Online Gaming
Question Make an SLK230 1998 quieter?
So I've owned an SLK 230 (1998 model) for around one to two years and I've noticed that the cabin noise is getting crazy loud. It's mainly the engine and outside noises that gets in and its very annoying to me. I know I could look up how to make any car quieter but I wanted to hear from any slk owners on how to make an slk 230 1998 (R170) quieter. Sorry for any spelling errors I was making this in a rush.
cubwatson is offline
#2 Old 01-29-2018
Quoted: 6432 Post(s)
Remember to use our search feature
There is really no question that has not been asked before
https://www.google.com/search?source....0.KJ4qA-sciEM
#3 Old 01-29-2018
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
not being facetious here - I put a 4.3L V8 in mine, and even with exhaust leaks this car is sooooo much quieter at cruising speeds.
the Kompressor really buzzes.
Some people buy some sound-deadening mat and put a whole bunch of it under the carpets, but its expensive and heavy... plus I'm not sure the carpets ever fit right again.
My first step would have been to insulate the firewall and under the hood better as I believe the exhaust does a good job of hiding noise.
cubwatson likes this.
Turdo2 is offline
#4 Old 01-29-2018
Moderator/RoTMorganiser
Quoted: 2191 Post(s)
Check your oil level.
Our 230 did not seem at all noisey.
Low oil can make them sound louder from the engine.
#5 Old 01-30-2018
Vehicle: 1999 SLK 230 Bahama Blue
Find some cheep Vinyl with thick padding at the fabric shop and run it around the car.... Think A10 Titanium Tub and you get the idea.
It will isolate the cabin from the outside and vice versa on the cheep (few $ a yard or so). That being said the location for the bose amp is where much of the sound can be shut off with some strategic padding.... That and the door panels will give you the most bang for the buck/time. The trunk has next to nothing as far as padding but I have not noticed much from that end of the vehicle as it is an open system head level to the back (hydraulic roof struts).
savcom likes this.
Naja is offline
#6 Old 01-31-2018
Delucas's Avatar
Quoted: 1132 Post(s)
Check your tyres are not contributing to road noise .
Thats a common thing .
Diff makes of tyres have diff db readings .
Delucas is online now
#7 Old 01-31-2018
cubwatson's Avatar
I don't think that's it because I had my oil changed not too long ago.
#8 Old 01-31-2018
An easy item to check and eliminate though.
#9 Old 02-05-2018
Vehicle: '03 SLK320
Quoted: 9 Post(s)
And as tires age they get harder and louder.
mko9 is offline
#10 Old 02-06-2018
dandywarhol's Avatar
Vehicle: 1999 SLK 230, 2009 SLK200,
Other Toys: 1967 Yamaha TD1C, 1996 Yamaha TRX850, '08 Renault Lunar Telstar motorhome
Quoted: 24 Post(s)
Sounds to me like the exhaust is losing it's innards. My '99 230 is on it's original system and is becoming noisier under acceleration and on start up
dandywarhol is offline
#11 Old 02-06-2018
PaPa Bear's Avatar
Vehicle: 1999 SLK230
Other Toys: What ever i have in my hand at the time
Quoted: 34 Post(s)
So I've owned an SLK 230 (1998 model) for around one to two years and I've noticed that the cabin noise is getting crazy loud............:
You say that the noise is getting louder, so as above i would be looking
At something that has worn or wearing out.
I have a 1999 230 and would not say that it is overly loud.
Things to look for (some already mentioned above)
Exhuast
Tyres
Belts
Worn Bearings ie kompressor, alternator, waterpump
The excess noise might be a warning that something
needs replacing
Best of luck
And cheers from down under
PaPa Bear is offline
#12 Old 02-09-2018
cubwatson's Avatar
Exhuast
Tyres
Belts
needs replacing
Best of luck
thanks man, ill try and check that stuff. I'm starting to think that something needs lubricating? but idk. Ill try various methods because this car is loud. impossible to go on speaker and call your partner without hearing the engine roar. oh btw its mainly the engine making the noise and the back trunk.
Tags
loud, mod, noise, r170
How Do I Remove The Headliner ? 1998 SLK230 W1KSZ SLK R170 General Discussion 13 2 Weeks Ago 03:43 PM
USA - NJ - 1998 SLK230 Compressor Blue Metallic with ONLY 87,000 MILES... slk230sale SLK Cars For Sale 1 01-22-2018 07:29 AM
1998 SLK230 runs rough on hard acceleration Basil123 SLK R170 General Discussion 2 10-02-2014 02:24 AM
1998 SLK230 Charcol Canister location? Ahnenerbe SLK R170 General Discussion 0 09-28-2014 11:21 PM
1998 SLK230, any of these faults seem alarming? CPCookieMan SLK R170 General Discussion 2 05-29-2014 08:52 AM
