Inner wheel arches - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Turdo2
  • 1 Post By Naja
  • 2 Post By stu32
#1 Old 12-24-2017
Vehicle: 2000 230slk
Other Toys: Motorbikes
Inner wheel arches
Hi
Some time soon I'm going to get the wheels off and clean the inner wings and get all the crap off as I've only had the car a couple of weeks. Has anyone done this and whats the best thing to use to give them some protection from road dirt etc!!
Thanks in advance
Regards Rob
Strongbowed is offline
#2 Old 12-26-2017
Vehicle: 1999 SLK 230 Bahama Blue
Unfortunately they use less clear coat on the inner wheels. I went ahead and repainted mine and clear coated them with https://www.amazon.com/SprayMax-Glam.../dp/B0082LJMC6
You could skip the paint and just add more clear to cover the pitting etc I left an inner strip to eventually add the MB logo and leaves in the same blue. Just used the cut line they did
I think white would be nice on some cars.
Naja is offline
#3 Old 12-26-2017
Quoted: 2214 Post(s)
Hi Rob, Can't remember if the 230 inner wing was similar to my current 171, but this one is not a smooth surface.
It has a felt like material lining it.
@Simon cliffe @savcom @Turdo2 @stu32 @Idiot101 @Padgett @ixion
Some have the 320, others the 230, but you'll get a better answer from them.
Avel Du is online now
#4 Old 12-26-2017
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 348 Post(s)
It's just a smooth plastic multi-piece shroud.. not the fabric that new cars use.
Turdo2 is offline
#5 Old 12-27-2017
Oops sorry was tired and read 'wheels' instead of Brit term 'wings' slash fenders. They are a base coat only and not much at that. You could add some sort of under seal or paint. The most importent thing is to make sure the drains are not clogged as it will cause rust like mine... You can see the undercoat color in the fender well pic.
stu32 likes this.
Naja is offline
#6 Old 12-27-2017
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Personally I like Waxoyl to protect the bits you cannot reach. Remove all the plastic liners etc and clean off all dirt. Any large surface rust area's will need treating and painting. If you are making a big job of it then front and rear bumpers would need to come off. The original plastic/pvc type spray that MB did is quite good but if it gets damaged the water and dirt gets behind and the metal underneath has very little protection resulting in rust where it looks ok on the surface. This will also need attention if you find any. After all the prep work is done spray on the waxoyl in 2 or 3 thin coats leaving to dry inbetween and will be good for years.
Trev5 and savcom like this.
stu32 is offline
#7 Old 06-11-2019
Chippenhamged's Avatar
Vehicle: 2003 SLK 320 purchased June 2019
Quoted: 9 Post(s)
Some good advice here
Chippenhamged is offline
Changing the steering wheel, or otherwise know as I like a challenge now and then… Seanhump General Modifications R171 127 03-01-2019 07:08 PM
Rear wheel arches repair Seanie_230 SLK R170 General Discussion 2 03-03-2010 10:09 AM
