R170 Bose system upgrade - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By dchantry007
  • 1 Post By savcom
  • 3 Post By Mn car guy
#1 Old 11-09-2017
Vehicle: Silver R170 230 98R
Quoted: 8 Post(s)
Newbie here. Recently purchased a 98/R170 and want to install the Bose kit out of an upgraded slk320. I have the 4 speakers and the amp but no wiring so wondering as this was an upgrade kit, if the cables would already be in there as a part of the loom? Also looking to upgrade the head unit to a more modern mp3/bt unit. Any recomendations or idlers about the wiring before I commit on the Bose?
LIL DON SLK likes this.
dchantry007 is offline
#2 Old 11-09-2017
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Lots of threads on upgrading the R170 HU including schematics. Hard part might be that you said four speakers - Bose in a 170 has six speakers, woofer and tweeter in each door and two subs behind the seats. Two subs are not in stock system so mounts/covers may not be there - are they in kit ?
Have heard of many upgrading the HU not of anyone trying to add the amp when not already there.
Padgett is offline
The Following User Says Thank You to Padgett For This Useful Post:
#3 Old 11-09-2017
savcom's Avatar
Quoted: 604 Post(s)
Hi @dchantry007
Welcome to the forum.
You've lots of options but let's start with the basics:
  • If you haven't got the Bose system at the moment you won't have the wiring or the amp - or the holes in the rear carpet!
  • The wiring to the Bose amp is twenty six wires (why???)
  • The Bose system itself is under powered and expensive - and pretty much relies on the stock headunit.
  • The Bose amplifier requires balanced inputs. Most aftermarket headunits provide screened unbalanced outputs - which are not the same thing and you'd need a module to convert one system to the other.
  • If you're thinking of changing the head unit you'd be better off putting together your own upgraded amp as you'd need to add the cables to the speakers in the rear (which frankly you don't really need as there's enough bass from the door, if upgraded properly)
There are plenty of upgrade threads so let me give you a flavour:
My thread (speakers and amp upgrade)
Another DIY amp upgrade
There is a classic DIY thread on SLKWorld that covers the Bose upgrade but I can't find that right now. I'll add that in a bit.
Good luck - and Welcome to the Forum!
Also
Previous :
savcom is offline
#4 Old 11-09-2017
savcom's Avatar
Quoted: 604 Post(s)
Found it:
https://www.slkworld.com/slk-r170-gen...stalled-2.html
Also
Previous :
savcom is offline
#5 Old 11-09-2017
Quoted: 8 Post(s)
THanks. I’ve been offered the amp and the speakers from the doors and behind the seats out of a breaking 320 and there are no cables. The head unit is becaus mine isn’t working. May now try option B
#6 Old 11-09-2017
Quoted: 8 Post(s)
Thank you so much for this. I shall wait until in front of the laptop so I can digest properly.
#7 Old 11-09-2017
Quoted: 8 Post(s)
Thanks. Have theamp and the speakers. Know I have to cut the holes but not sure if I have cables. May be easier to go aftermarket as I need the stereo too.
#8 Old 11-09-2017
savcom's Avatar
Quoted: 604 Post(s)
In my thread above there is the wiring needed for the amp and speakers. It's actually 14 wires to the amp on a 26-pin connector. If they're breaking the '320 and you still want to proceed with the Bose try asking for the amp plug and some of the wiring (try to get about a foot / 30cms of the loom). You can then splice to that as needed with your own cabling.
dchantry007 likes this.
Also
Previous :
savcom is offline
#9 Old 11-10-2017
Vehicle: 2009 CLK 350 cab
Quoted: 128 Post(s)
Yeah, that's what I'd do as well. The stock bose system is just okay and certainly not worth the effort to recreate when there are better options available.
kyriacos, savcom and dchantry007 like this.
Mn car guy is offline
Audio: Speaker upgrade in a facelift R170 savcom General Modifications R170 16 01-24-2019 03:39 PM
Budget R170 stereo upgrade... ($475 bucks) ImMostlyHarmless SLK R170 class DIY 7 07-05-2018 01:52 PM
Sound System & Speaker Upgrade freefall63108 SLK R171 General Discussion 1 11-11-2015 11:25 AM
r170 door mirror upgrade wineprovider SLK R170 General Discussion 7 09-14-2013 12:22 PM
New Nav/Sat?HD/Tel/Video/everything upgrade ERS113 General Modifications R171 2 12-31-2012 12:15 PM
