Footwell Lighting - an alternative approach - Mercedes Benz SLK Forum
 25Likes
  • 3 Post By savcom
  • 3 Post By savcom
  • 8 Post By savcom
  • 1 Post By marvel
  • 1 Post By KoltSupa
  • 2 Post By Avel Du
  • 1 Post By savcom
  • 1 Post By Bluebadger
  • 1 Post By savcom
  • 1 Post By Avel Du
  • 1 Post By Ridgerunr31
  • 1 Post By Captain Chaos
  • 1 Post By Christopher Goodwin
#1 Old 06-05-2017
savcom's Avatar
Quoted: 604 Post(s)
I've often wondered why MB didn't put footwell lighting in the R170 SLK. A simple addition would've added a touch of class on an already classy auto. Anyhow, adding footwell lighting doesn't look to be a difficult job and there are a few people who have written up their exploits in this area on this forum, typically using a short length of 12V LED tape stuck to the top of the footwell / bottom of the dash.
So why the need for another version?
Well, I think the LED strip idea looks a little Heath Robinson if I'm honest - there are cables to hide and the glue on these tapes can sometimes weaken when it gets too warm and the LED tape will then sag or fall off - messy! Also the panels these are stuck to are removable and unless connectors have been used you will be restricted when you come to replace (for example) the cabin filter. So I looked at the project slightly differently to avoid these pitfalls and this is what I came up with:
First of all I took photographs of the underside of the dash so I could see what I was working with:
Passenger side:
Drivers' side
Concentrating on the passengers' side those holes would lend themselves to supporting a panel-mount LED housing if there was enough depth above - and this would mean minimum intrusion into the footwell and all cabling above that panel - a win/win for the passenger side (assuming you could find a suitable lamp).
The drivers' side looks a bit harder. There are no holes available and without removing the panel I can't see an easy way to install the lamp on this side. Further, I am loath to have anything below the panel in case it comes adrift when driving - not good for safety! I could drill a hole in the panel - but I'd have to then be sure any cables I install do not foul the steering mechanism above the panel.
Then I noticed the ventilation panel and I am now thinking if I can utilise this to house the lamp for the drivers' footwell.
For the moment though let's concentrate on the passenger footwell. The holes in the panel measure 15mm across. And, as it happens, on eBay there are a large number of cheap 'DRL' type LEDs of various claimed powers and brightness known as 'Eagle Eye LEDs'. These fix with a bolt into a 12mm hole so they would be perfect in the panel above. The only thing I needed to add was a washer to help hold the lamp in place.
Anyhow. I purchased some lamps on eBay to see if they were suitable. I'd already read some reviews that criticised the light output as 'too low' so I knew the 'cheap' quality of these units would make them more suitable here. Once they arrived I tested the current draw of one of them. This turned out to be around 80mA, indicating that the LED was a 1W unit. Perfect. Once lit, however, the light pattern looked poor:
But, as the lamp lens was plastic, a couple of minutes with some emery paper and the light pattern was transformed into this, which was much better!
Now the next stage is to plan how you want the lamp to work in the car. As you probably know, the dome lights turn on when the doors are opened or when the switch on the dome light is activated. On the circuit diagram below the lamps are in E15/1 and are fed from a permanent +12V on pin 4 (Red/Grey cable). They are switched on when either the Blue/Brown cable (pin 3) is taken to 0V (doors opening) or when the switch connects the lamps to ground (brown cable on pin 1).
Your choices are therefore:
  • If you want the footwell lighting to come on just when the door opens then you need to connect the footwell lamps across E15/1 pins 4 and 3
  • If you want the footwell lighting to come on whenever the dome lamps come on then you need to connect the footwell lamps across E15/1 pins 4 and 1
I chose the latter option reasoning that you may want footwell lighting at night without having to opening the door.
At this point we're in a position to carry out the installation (see following post). I'll include a list of what's needed in this post too.
Avel Du, devilman9050 and TGRZRX like this.
savcom is offline
#2 Old 06-05-2017
savcom's Avatar
Quoted: 604 Post(s)
Having looked at what's needed, we're ready to do the installation phase.
Tools needed (in addition to your normal car tools):
  • Crimp tool
  • Soldering iron and solder
Parts needed:
Method:
Most of this stage is carried out in your workshop so you can do it in advance of the main install in the car.
Step 1: Undo the two screws in the panel under the glove compartment, slide the panel to the back of the car and remove it.
Step 2: Take one of the LED lamps and rub it gently on some emery paper or some fine wet-and-dry sandpaper
Before:- LED - before.jpg After - LED - after.jpg
Step 3: Feed the cable through the hole and fit the lamp to the panel where shown. Add the washer before doing up the nut slightly tighter than finger tight..
Step 4: Now prepare the connectors (I've laid out how the connectors are assembled for reference here)
Step 5: Make the cable up. The red-and-black cables can be twisted together by putting one end of each cable in a vice and the other two ends in a hand drill. Rotate the hand drill keeping tension in the cables until the twists themselves twist together. Undo vice and drill and the cable is ready to use.
Step 6: I crimped the red-and-black cable to the 2.8mm socket pair as this is slightly safer configuration
Step 7: The LED lamp wires are fairly light-weight so these I soldered to the spade connectors to make sure of a connection
Step 8: Assemble the cables in the connector housings taking care to line up red-with-red and black-with-black
Step 9: Test the lamp with a bench power supply to make sure it works (if you've not got a 12V supply a 9V 6LR61/MN1604/PP3 battery will do)
That's it for tonight - if I get a chance I'll discuss how to fit it to the car later this week.
savcom is offline
#3 Old 06-05-2017
savcom's Avatar
Quoted: 604 Post(s)
Having prepared the panel for the footwell you now need to thread the power lead for the lamp from the dome light, down the passenger A-pillar and then above the dash for the lamp. Back at the dome light you will need to crimp the cable across the right two cables in the dome light to get the footwell lamp to light correctly.
Safety Warning!!
Please be aware that the dome light is permanently powered
so before attempting to connect the red-and-black cable
you may want to be safe and disconnect the battery first.
The easiest way to carry out the cabling is first to drop the roof in the boot/trunk, remove the side panel to the dashboard on the passenger side, disassemble the dome light so you can get to the connector and then using this guide on PelicanParts carefully remove (fully or partially) the panel at the top of the windshield and the passenger A-pillar.
Next, thread the 2m cable up through the side opening in the dash, into the base of the A-pillar and up to the top of the windshield.
Then feed the cable across the top of the windshield to the dome light. I've attached the circuit diagram again to make the following easier to understand.
You should now crimp the red and black cable as follows:
Crimp the red wire to E15/1 pin 4 (Red/Grey) then:
  • If you want the footwell lighting to come on just when the door opens, crimp the black wire to E15/1 pin 3 (Blue/Brown)
  • If you want the footwell lighting to come on whenever the dome lamps come on then crimp the black wire to E15/1 pin 1 (Brown/Yellow)
Before you reassemble everything you should now test that the footwell lamp lights by connecting the lamp on the footwell panel to the red-and-black lead and reconnecting the battery for a short time. If all is well you can begin the re-assembly. Disconnect the battery again for safety then reverse the sequence above:
  • Re-assemble the top of the windshield, sun visors and the A-pillar making absolutely sure you don't trap any cables.
  • Re-assemble the dome light.
  • Clip the side panel back on the side of the dash after feeding the red-and-black cable into the void above the footwell.
  • In the footwell connect the red-and-black power cable to the lamp fitted to the footwell panel and re-install the panel in the footwell.
  • Re-connect the battery (if you disconnected it) and the dome lights and footwell lamp should both light up with the door open.
  • Shut the doors and check the lamps go off after a few seconds. Try the lamp switch on the dome light and check the footwell lamp switches on and off as it should.
Don't forget: when you start the car you will need to re calibrate the steering to reset the BAS warning lamp
To let you see what it is like here is an off and an on shot in full sunshine with the roof down:
And finally at night here is a shot of the interior with the footwell lamp illuminated.
I've not yet thought out how to put in a footwell lamp in the drivers' side but with the hard work done I just need to make a loom that will plug into the red-and-black cable and run both sides footwell lamps from there. Another time.
etyu, glmce, M4rCu5 and 5 others like this.
savcom is offline
#4 Old 06-10-2017
marvel's Avatar
Vehicle: 2004 SLK 230 Kompressor Special Edition - Brilliant Silver w/black int
Other Toys: 1992 H-D Sportster
Quoted: 25 Post(s)
Very Cool!!!!
savcom likes this.
marvel is offline
#5 Old 06-18-2017
KoltSupa's Avatar
Vehicle: 2002 Mercedes Benz SLK 320
Other Toys: 2005 BMW X5 and 1979 Chevrolet Monte Carlo (Base)
Quoted: 8 Post(s)
Very detailed work. Thanks for sharing with all of us SLK owners!
savcom likes this.
KoltSupa is offline
#6 Old 06-18-2017
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Martin!
Did you have to show the badger?
She was impressed.
You know what's coming next. Grr!
(So that's why she wants to return to Kent )
savcom and Jules555 like this.
#7 Old 06-18-2017
savcom's Avatar
Quoted: 604 Post(s)
Martin!
She was impressed.
Myk - If I'm honest it's a simple, inexpensive job that has a tidy result. It took less time to do than to prepare and post the HowTo. As such (no offence Debs) it's an easy win for you. You can practice on your car and get it right on hers.....
Every SLK should have one.
Also
Previous :
savcom is offline
#8 Old 06-18-2017
Bluebadger's Avatar
Vehicle: 2009 r171 350
Quoted: 188 Post(s)
Hey you don't be giving him ideas that I should do the mechanics just remember I break tonka toys
Plus I'd scratch the paint job as I'm so clumsy and it's not a cop out it's my and Myk's reality.
Debs
Bluebadger is offline
#9 Old 06-18-2017
savcom's Avatar
Quoted: 604 Post(s)
Woah! @Bluebadger If you read what I said, you'd see that I was asking Myk to practice on his car - and then do yours!
Bluebadger likes this.
Also
Previous :
savcom is offline
#10 Old 06-18-2017
Remember, she has been using mine.
I have fixes to do to the 55 first before ANY 350 jobs, including shiny bits.
savcom likes this.
#11 Old 08-19-2017
Vehicle: 2001 Bahama Blue SLK320
Other Toys: Mazda CX9, Nissan NV3500, Can-Am Spyder
Quoted: 9 Post(s)
Nice job...
savcom likes this.
Ridgerunr31 is offline
#12 Old 09-26-2017
Captain Chaos's Avatar
Vehicle: 1999 SLK230 170
Other Toys: XVS1100 Motorcycle, Pinball Machine.
Quoted: 7 Post(s)
Send a message via Skype™ to Captain Chaos
I Like , I Like
savcom likes this.
Captain Chaos is offline
#13 Old 09-26-2017
savcom's Avatar
Quoted: 604 Post(s)
Originally Posted by Captain Chaos View Post
I Like , I Like
Thanks.
As the evenings get darker I see again how effective this mod was. I must complete the set and add the drivers' side footwell light too.
Also
Previous :
savcom is offline
#14 Old 09-20-2018
Vehicle: 2002 SLk 320. 2002 SLK32 and others that don't relate to this group.
Other Toys: 1971 Porsche 911, 1981 BMW R80gs, 1969 BMW R60/2, 2013 Smart Electric, various Mercedes.
Quoted: 17 Post(s)
Couldn't you tap into these wires in the dash? It appears from the photos that the wiring runs up the right side A pillar...
Christopher Goodwin is offline
The Following User Says Thank You to Christopher Goodwin For This Useful Post:
#15 Old 10-03-2018
savcom's Avatar
Quoted: 604 Post(s)
That's certainly possible but I have to say I didn't check that. I'd run other cables up the left hand side A pillar and kinda knew my way round that way. It does make more sense to do it your way and perhaps would have been less crowded in the roof lining. Good call. Thanks.
Also
Previous :
savcom is offline
#16 Old 10-04-2018
Quoted: 17 Post(s)
I don't like that the SLK has no door lights, nothing to show traffic that the door is open and no "puddle" lights to light the ground when the door is open. I was getting ready to install lights from a later model Mercedes in the rear bottom corner of the door panels and wire them into the courtesy light circuit, this is why I looked at your post initially. In looking for the lights I found some which have a red light facing horizontally for traffic to see and they have an LED projector which projects a 16" Mercedes logo on the ground between the door and the car to light the ground. When I have some time away from working on other peoples cars, I'm installing them using your wiring idea.
savcom likes this.
Footwell Lighting Installed savcom General Modifications R170 5 05-09-2017 05:30 PM
Footwell Lighting Installed blktaz General Modifications R170 16 05-01-2017 06:43 AM
Footwell Lighting help blktaz General Modifications R170 2 01-04-2015 08:20 AM
Footwell Lighting Laurancep General Modifications R171 9 07-20-2014 04:50 AM
Ambient footwell lighting True Romance General Modifications R171 27 06-13-2010 11:34 AM
