Need help finishing Spyder headlights - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By Shalesy
  • 1 Post By Shalesy
  • 1 Post By jbanks15
  • 1 Post By Avel Du
  • 1 Post By KoltSupa
#1 Old 05-27-2017
Vehicle: 2001 SLK 230 R170. Silver with Black interior
Other Toys: Computers
Quoted: 7 Post(s)
Does anyone know what I need to do next? Six wires from the lights,. The harness they supplied. The four pin socket on the SLK.
kjl257 is offline
#2 Old 05-27-2017
Quoted: 7 Post(s)
Better picture
I have three pairs of wires coming off the light, and an adaptor the provided. The cube from the SLK has three contacts.
kjl257 is offline
#3 Old 05-27-2017
Quoted: 7 Post(s)
Spyder headlights
Got them installed. High and Low beams are working, but need help with the rest.
kjl257 is offline
#4 Old 05-27-2017
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
The adapter is for pre-facelift cars. I have that adapter on one light....
Indicator used the existing wires.
The 6 wires (3xR and 3xB) are for the DRL halo's. Soldered the 3 sets together and connected into the low beam circuit.
My wiring was a mess as a PO had fitted a light unit from an older model.
Avel Du and WoZ53 like this.
Shalesy is offline
#5 Old 05-27-2017
Quoted: 29 Post(s)
My MB plugs have:
Right light has 4 wires. White, Yellow, Brown and Grey/red (2003)
Left light has 4 - Brown, Grey, White, Yellow - the G W Y have a black trace and are from a pre facelift car.
Shalesy is offline
#6 Old 05-27-2017
Quoted: 7 Post(s)
Originally Posted by John Shales View Post
My MB plugs have:
Thanks, that adaptor confused the heck out of me!
Would you happen to know which of the three on each side goes where?
Also, when you say pre facelift, is that before 2001?
Thanks.
kjl257 is offline
#7 Old 05-27-2017
Quoted: 7 Post(s)
High and low beams are all that work. Two three socket cubes too connect each side.
Does anyone know parking lights, turn signals etc. ?
kjl257 is offline
#8 Old 05-27-2017
Quoted: 7 Post(s)
Again, sorry for multiple posts.
I'm new here and don't know when I respond to a member, if others can see it.
kjl257 is offline
#9 Old 05-27-2017
Quoted: 6435 Post(s)
If you respond, everyone see is! the world sees it!
prefacelift for the r170 is 2000 and earlier
kjl257 likes this.
#10 Old 05-27-2017
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Please bear in mind that some of those that can help may not be online today,
or even the next few days.
Responses are often not immediate on this type of enquiry.
Although Jeff et al do try to make it quick.
Idiot101 likes this.
#11 Old 05-28-2017
Quoted: 29 Post(s)
Turn signals are your original units. They twist into the hole provided in the AE's
Just pop off the upper right cover in the first pic of your original post.
Shalesy is offline
#12 Old 05-28-2017
Quoted: 29 Post(s)
You are correct ref pre-facelift.
Mine is a 2003. Photo is of the MB connector into the AE connector, R/H light:
Colours. (top down) MB = Grey + red trace, Brown, yellow, White.
AE = White, Black (x2), Blue, Red.
The white + 1 black are sidelights, Red = dip & Blue = Main. Blacks are earth.
Shalesy is offline
#13 Old 05-28-2017
Quoted: 7 Post(s)
If there were four contacts on each cube, I'd assume one was common ground, but having three pairs of red and black I'm lost!
kjl257 is offline
#14 Old 05-28-2017
Quoted: 29 Post(s)
I didn't see that you are in the US. I do not have those "cubes". Are they to connect fender lights? We don't have those in Europe
The 3 pairs of thin wire, R & B are just for the "halo's" and you should just connect the 3 red together and the 3 blacks together. Find a feed that is hot with the ignition for the reds and ground the blacks.
Does this help? Install projector halo angel eye headlights on 1999 SLK - Mercedes-Benz Forum
Shalesy is offline
#15 Old 05-31-2017
Quoted: 7 Post(s)
Yes, that does help.Thanks!
kjl257 is offline
#16 Old 05-31-2017
Quoted: 7 Post(s)
I'm still not done with the wiring, but the fit is better.
Spyder contacted me. I need to give them the item number off the box they came in.
I'm down to the tree pairs of read and black on each light, and these tree contact cubes on each side.
kjl257 is offline
#17 Old 05-31-2017
Quoted: 7 Post(s)
Apparently, my H key needs a harder press ;-)
kjl257 is offline
#18 Old 06-05-2017
savcom's Avatar
Quoted: 604 Post(s)
I've a PDF showing the facelift headlamp wiring (probably a bit late to the party but posted nevertheless...) It may help you regarding the colour codes and the lamps, but don't forget the US lighting has different requirements to the UK/Euro wiring.
Let me know if this helps.
Also
Previous :
savcom is offline
#19 Old 06-18-2017
KoltSupa's Avatar
Vehicle: 2002 Mercedes Benz SLK 320
Other Toys: 2005 BMW X5 and 1979 Chevrolet Monte Carlo (Base)
Quoted: 8 Post(s)
Wish I had taken photos of the process I did to install mine, but I will share how awesome they look after you successfully install!
savcom likes this.
KoltSupa is offline
#20 Old 09-25-2017
Vehicle: 2002 SLK230 black
Did you connect the 'halo' rings to your parking lights?
misterb is offline
Help with Spyder LED headlights! Oszy General Modifications R171 112 1 Hour Ago 08:54 PM
SPYDER Headlights Durkatlon General Modifications R171 374 08-27-2018 08:33 PM
SOLD - UK: Spyder Headlights R171 Xenon Geoffo SLK Parts For Sale 17 07-07-2017 11:22 AM
Spyder headlights install/problem solved AndreSlk General Modifications R170 0 06-26-2016 01:41 PM
Spyder Headlights w/ HID Kit on Factory Xenon SLK? Shake15 SLK R170 General Discussion 4 04-05-2015 09:10 PM
