Stealth dash mount for Smartphone - Mercedes Benz SLK Forum
 28Likes
#1 Old 04-16-2017
savcom's Avatar
Quoted: 604 Post(s)
I wanted to mount my Smartphone at the top of the dash - and cable it for power etc. but in a stealth way that meant I could hide everything for short journeys and when I park the car.
I'd looked at some mounts that were built into the tray but these would only work with the tray out - something I didn't want as it vibrates too much and I'm sure would harden and splinter the tray plastic. So, on my third attempt this is what I came up with:
It's an amalgamation of two different car mounts. The first was a triple-hinged device that I converted into a Z-fold unit that worked, but wouldn't lie with the drawer fully closed because the middle section was 5mm too long. The second was a sticky magnet that I attached to the Z-fold after converting it to a simple hinge. The result is that I can hide cables and the mount in the drawer (including any USB sticks for audio) and slide the mount out and up and then park my smartphone on it whenever I need it. The mount is made out of mild steel and is less than 2mm thick so it doesn't mark the dash or the drawer. I've cheated though and held the mount in the drawer with some gaffa tape.
etyu, DesignoSLK, Dave54 and 12 others like this.
Also
Previous :
savcom is offline
#2 Old 04-16-2017
Pictor's Avatar
Quoted: 217 Post(s)
That's really a neat concept.
I know the coin trays are expensive, so I am loath to modify mine, but I saw a price for the front cover piece that looked quite cheap, and it had me thinking about screw into it from inside or outside for mounting devices. Scavenging this part from broken cupholders/coin trays is another possibility.
Pictor is offline
#3 Old 04-16-2017
savcom's Avatar
Quoted: 604 Post(s)
The only 'break' I've done is to make a hole in one corner of the tray to get the USB cables into the tray area. Apart from that the tray is not touched (remember the mount is stuck down with Gaffa tape).
If you want to do away with the cables the the tray remains untouched.
Also
Previous :
savcom is offline
#4 Old 04-22-2017
snoopykissedlucy's Avatar
Vehicle: 2004 Mercedes SLK230
Quoted: 8 Post(s)
Did you run your cables down the inner side?
And where did you get the power from? Tapping the fuse box or splicing into a hot wire? Where?
Thanks!
snoopykissedlucy is offline
#5 Old 04-24-2017
savcom's Avatar
Quoted: 604 Post(s)
When I was running the Becker head unit I crimped a 12v to USB power source and plugged in two extender cables. Now, I use the Pioneer head unit which has two USB sockets in the back, so those leads are run up the left hand side of the dash.
Sent from my Xperia while my back was turned
RLander likes this.
Also
Previous :
savcom is offline
#6 Old 04-24-2017
DesignoSLK's Avatar
Chats: 2051
Quoted: 55 Post(s)
I'd love to do this. Problem is, I still use my cup holders. I'm experimenting with a Nato Smart Mount right now, but nothing as cool and conclusive as what you've done here. Very nice!
Kevin ><>
DesignoSLK is offline
The Following User Says Thank You to DesignoSLK For This Useful Post:
#7 Old 04-25-2017
Ami
Vehicle: White 2003 SLK32
Other Toys: Race-tuned 2009 Yamaha T-Max
I used Pro-Clip custom mount.
No screws, the thing clips-on and is solid..
Mercedes Benz*SLK-Class*2003*Dashboard Mounts*-*ProClip USA
Ami
DesignoSLK, savcom and RLander like this.
Ami is offline
#8 Old 04-25-2017
savcom's Avatar
Quoted: 604 Post(s)
Ami
They're a neat idea - but I wanted the phone within reach and at the top of the dash. I also often have a passenger and I wondered if the mount would impinge into their part of the footwell
Also
Previous :
savcom is offline
#9 Old 04-25-2017
DesignoSLK's Avatar
Chats: 2051
Quoted: 55 Post(s)
Ami
I have a leather covered Kuda mount for my MP3 player, but I could maybe figure a way to mount both on it. Hmmm...
Kevin ><>
#10 Old 05-13-2017
Vehicle: SLK 200 Kompressor (R170) 2002
Attachment 392025 Attachment 392033
Attachment 392041 Attachment 392049
Hi, this is great. I've been thinking about doing something like this for ages but wasn't exactly sure how to go about it. Where did you get the sticky magnet from? Is there a risk at all that the magnet will interfere with the electronics of the phone?
Silverado77 is offline
#11 Old 05-14-2017
savcom's Avatar
Quoted: 604 Post(s)
Hi
Thanks for your comments.
I found the sticky magnet by searching for 'Magnetic Mount Car Dashboard' and choosing one that is intended to be mounted on the dashboard with a '3M sticky pad' on the back. Here's one such magnet.
Also
Previous :
savcom is offline
#12 Old 05-18-2017
Hi
Cool. Thanks for the link.
#13 Old 05-22-2017
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
I like this. I'm stealing it
Bits already ordered and mouse wire inserted for pulling the USB lead through to the radio.
Thanks for the idea
I already have twin USB power ports on the passenger side of the center tunnel/footwell, piggy-backed off the fag lighter. Untidy for the phone but good for charging the tablet/GPS.
Avel Du, savcom and Silverado77 like this.
Shalesy is offline
#14 Old 05-22-2017
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Personally use a CD slot mag mount from Okra along with an AUXMIC cable and stand from Scosche. Did need to tape over tongues of mount to get enough grip, cover seems to be rubber. Velcro does not stick well either.
Also replaced the butterfly screw with a long Allen set screw with the mag mount adjusted down to clear the cup holder tray. I use mag mounts because have had the phone pop out of a clamp mount on a hard shift.
Finally have a HUD with speedo and clock because in bright sun and with dark sunglasses on I have trouble seeing the dash gauges. GPS HUD does not have as fast a response as a OBD based one but already have an ELM327 dongle there.
Have mounts in both my 170-clone and 171. Clone shown.
savcom likes this.
Padgett is offline
#15 Old 05-22-2017
savcom's Avatar
Quoted: 604 Post(s)
Be my guest!!
Also
Previous :
savcom is offline
#16 Old 05-23-2017
Ami
Saw this mount today on Amazon
Haven't tried it, but seems nice... There are other sellers from china that sell the same thing for $4.
https://www.amazon.com/Simulating-Universal-Adjustable-Dashboard-Smartphone/dp/B06XXHHYRK/
Silverado77 likes this.
Ami is offline
#17 Old 05-24-2017
That's a great holder, very clever. Thanks for the link.
Makes you wonder if you could build a similar holder made out of large bulldog clips.
#18 Old 05-24-2017
savcom's Avatar
Quoted: 604 Post(s)
Like this you mean?
I did look at that but I wanted the phone mounted at dash level and the vents look too flimsy on the R170 to support a large smartphone.
Also
Previous :
savcom is offline
#19 Old 05-24-2017
savcom's Avatar
Quoted: 604 Post(s)
That's a great idea! Not sure I'd like the phone in my direct line of sight though. Running cables to the phone cleanly may be a bit problematical too.
Also
Previous :
savcom is offline
#20 Old 05-28-2017
Quoted: 29 Post(s)
I agree. Your solution puts it in the perfect place without obscuring any windscreen area.
Mines done and "I'm Lovin' it".
I used a few blobs of polymer adhesive to fix the mount and hold the usb cable in place. I did drill a hole for the lead.
Many thanks for the idea.
I now have a cup holder to ebay
Shalesy is offline
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 55 03-22-2019 12:58 PM
R170 Manual Transmission Mount Confusion TrooperSlick SLK R170 class DIY 3 02-02-2019 07:23 PM
Tablet Mount, IPad or Nexus 7 Stinger SLK R171 General Discussion 44 02-15-2014 10:13 AM
Prestigio RR 300 Dash Cam + Tetrax Fix Magnetic Mount randombloke Off Topic 2 09-03-2013 08:13 AM
